Toshiba Satellite 3 long beeps?
Attempting to boot laptop & just get 3 long beeps....cannot find a beep code that represents this problem.
  • 4,472 Answers
First off try reseating the memory see if that helps. If you need further assistance let me know. Also what is the exact model of the laptop and how long have you owned it? If you need further assistance let me know. Also please take a moment to rate my solution accordingly.
Thank you,
Lee
Posted on Feb 27, 2009
My computer does not boot
The reason with your laptop does not boot is power chord does not plug in...memory problem...operating system and corrupted hdd...
Check the power chord if properly plug to the outlet Check the memory if you heard 3 beep or 8 beep...if you hear 3 beep...the memory is not installed properly...check and install properly...if you hear 8 beep you need to replace the memory with new one...if you hear a continuous beep...the memory...discard the memory...open the laptop then off immediately...then install the memory again...
if the problem still exist...
Please go to the nearest repair center to fix the problem. Because it is very fatal and need assistance from a technician
Sep 21, 2011 | Toshiba Satellite P105-S6197 Laptop
WHEN BOOTING THE TOSHIBA SATELLITE A215-S5837 I hear two beeps and get a dark screen. I can press f1 and go into safe mode but don't know what to do next. The error message is "resource conflict...
These beeps are error code and two short beeps during start up normally refers to RAM or memory not being detected. You can try to reseat the RAM modules or ask someone who knows how to do it. If it will still be the same, it means that the RAM is defective and consider replacing it.
Cheers!
Apr 07, 2011 | Toshiba Satellite A215-S5837 Laptop
I have an IBM T20 and when I start it up, the screen does not come on, don't hear hard disk working, but the fan is working. There is beeping when started - 3 beeps, then follow by 3 beeps, and then 1...
That is likely. The beeps represent an error code. You might try borrowing an external monitor plugged into your laptop to see if anything shows on that screen when it boots up.
Sep 15, 2010 | IBM ThinkPad T20 Notebook
Toshiba Satellite m55 that will not pass post, 3-4-3 beep code
Sound like your Video Card has gone down i think it cant find the VGA bios
Nov 30, 2009 | Computers & Internet
Toshiba x205 Sli1 suddenly died. Got 3 beeps.
3 beeps usually means that either the chipset or the processor is dead. Nothing you can do, take it to a repair shop.
Nov 06, 2009 | Toshiba Satellite X205-SLI1 Notebook
I gt power to the pc but it does not boot and the
well on the satellite x205 it could be a couple things. there isnt any beep code? if there is no beep code then it would need atleast a main system board. i worked on 2 last week but they had beep codes (3beeps) which were video cards. in your case pull each stick of ram, then if thats not the case order a main system board.
Nov 05, 2009 | Toshiba Satellite X205-S9349 Notebook
Laptop won't boot up. Only 3 beeps.
listen to the beep heres some information on beep code errors
Beep Code: Description of Problem: No Beeps Short, No power, Bad CPU/MB, Loose Peripherals One Beep Everything is normal and Computer POSTed fine Two Beeps POST/CMOS Error One Long Beep, One Short Beep Motherboard Problem One Long Beep, Two Short Beeps Video Problem One Long Beep, Three Short Beeps Video Problem Three Long Beeps Keyboard Error Repeated Long Beeps Memory Error Continuous Hi-Lo Beeps CPU Overheating
Jan 25, 2009 | Toshiba Satellite X200-AA3 Notebook
I put a 1gb expansion ram in my toshiba satellite M35X-S149.  Did it with the battery out.  Put the new ram in the empth slot - - 256 mb in the other slot from the factory.  When I turned on the power, the...
Remove the 1 gig chip. Pull you battery out and unplug the laptop. Hold the power button in for 10 seconds. Put the battery back in and plug the laptop back in again and try booting it up. This should reset the BIOS and allow it to boot. The beep codes you are talking about are a memory beep code and it is normally caused by adding memory or a loose memory stick. Also try pulling the existing memory and resetting it.
Dec 20, 2008 | Toshiba Satellite M35X-S149 Notebook
Toshiba Satellite® X205-S9349 bios beeping
the beep codes you are getting are for video but if the system boots and you have video im sure it is something with the ram on the video card. unfortunatly this will require a service from toshiba. these cards are intergrated and will require the motherboard to be replaced.
Sep 07, 2008 | Toshiba Satellite X205-S9349 Notebook
Computers & Internet Logo
435 people viewed this question
David Payne
David Payne
