Question about Pioneer Car Audio & Video
Pioneer AVH-P7500DVD won't play Disc, show ''error 02''
I replaced new Lazer pickup assembly from Pinoeer, cost about $100 for the part but still show ''error 02'' and won't play any CD or DVD. Disc spinned then stopped then showed the error message. Any help would be very appreciate, thanks.
simplemitch
  • 752 Answers
SOURCE: Error message
try removing power from the unit for about 5 minutes and plug the harness back in. If that doesn't work, it will need to be repaired.
Posted on Sep 11, 2007
zzedly
  • 300 Answers
SOURCE: avh-p5900dvd... I keep getting error
Owner's manual doesn't really say what the -02-9e error code means other than a disc error. They do recommend resetting the unit as a possible solution:
  1. Turn the ignition off.
  2. Remove the faceplate.
  3. On the right side of the front of the head unit (with the faceplate removed), press the reset button with a ball point pen.
You may have to call Pioneer directly to find out what the -02-9e code means specifically. 1-800-421-1404
Posted on Apr 03, 2008
mattozan
  • 555 Answers
SOURCE: error-02-9e this code error message
Your manual is available here.
Posted on Apr 05, 2008
  • 3 Answers
SOURCE: ERROR CODE 02-60 WHEN TRYING TO PLAY IPOD.
I had the same exact problem with the 4100DVD I got on 5/01/09. I reset my Ipod via the Itunes software. This will wipe your Ipod clean and reinstall everything. I was a bit leary about this but gave it a shot and viola! It is working just as it was when I first purchased 5 days ago.
Make sure you back up your Ipod first. After the reset, it will ask if this is a new install or restore. Select restore and everything is back again, including downloaded games and app. (I have an Ipod Touch)
Posted on May 07, 2009
messstat
  • 365 Answers
SOURCE: Infiniti G35 Bose system cd jammed in player error fo message
disconnect the power supply for a moment and reconnect...then try a eject - again. I think the "fo" is a format error...burnin CD's at home are we - or possibly using CD cleaning discs?
Posted on Jun 14, 2009
AVH P3100. What does error code 02-9e indicate?
Error 02-9E Means there is a scratched or otherwise unreadable disc. The problem could be the laser as well. This error can mean any of the following:
Scratched disc
Improper media Bad burn/copy of disc
Improperly adjusted laser - requires an alignment
Dirty Laser Lens (smokers will experience this more often)
Laser failure etc.
Try changing the CD/DVD you are using and if you are still getting the same error, then try to visit you nearest Pioneer Service center and get your headunit's laser tested for allignment. How much you'd invest for repair must be below the cost of a new one or it's not worth it.
Nov 30, 2015 | Televison & Video
My pioneer AVH-p6500 shows error 02. I found out in the manual that it is from a scratched disc(so it would not play it). Problem is, I could not eject the disc it keeps turning the system off. Please...
Unfortunately the internal safety circuits are going to fight you here. The unit has detected a mechanical problem during the attempt to eject and shuts down to prevent further damage. You will need to dis-assemble the unit to remove the disc. It is possible that the lens has a dirt film on it that would prevent it from reading the disc, thus the 02 error code. This is not the easiest mechanism to work on. I would suggest that you seek a service shop for this repair.
Dan
Mar 20, 2008 | Audio Players & Recorders
My cdp-455x is showing a loading error after the lazer being cleaned
The laser eimission might have stopped. The laser pickup unit [optical pickup unit] should be replaced.
Apr 17, 2012 | Sony CDP-D11 1U professional compact disc...
I have a avh p5700dvd and when i put a cd in it reads error 02
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/212667155AVHP5700DVDOperationManual.pdf
Nov 06, 2009 | Pioneer AVH-P5700DVD Car DVD Player
Error came up while watching dvd cut off they say
error-02 is a dirty disc.
Clean disc or replace scratched disc.
Thats it
Jun 04, 2009 | Pioneer AVH-P4900 Car Video Player
Error -02-09 on my avh-p5900dvd can you please help. thanks Eddie
02-xx error can mean a lot of things.
Here are some for you to try:
Dirty Disc -- clean disc
Scratched Disc -- replace disc
Disc loaded upside down -- make sure is going in correctly
Electrical or mechanical error -- press Reset
Hope this helps.
You might have to contact Pioneer if none of these work for you.
Apr 06, 2008 | Televison & Video
Avh-p5900dvd... I keep getting error -02-9e and it wont play cd,s or dvd,s can you help.
Apr 03, 2008 | Car Audio & Video
Screen wont move
There is a guy on ebay who does that repair service on the Pioneer AVH models. I thinks its $100 and change for the service plus shipping costs. Not a bad deal, beats going Pioneer! His service is also same day. http://cgi.ebay.com/AVH-P7500dvd-AVH-P6500dvd-MORE-repair-service_W0QQitemZ180196772416QQihZ008QQcategoryZ32825QQcmdZViewItem
Dec 14, 2007 | Pioneer AVH-P5700DVD Car DVD Player
Car Audio & Video Logo
88 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
