Question about Dell Vostro 1510 Laptop
Video connector cable required
I would like to haveĀ Video connector cable for my laptop for connection to a TV. Kindly let me know the type of cable, the where it is available in India
  • kuldeeprawat Mar 09, 2009
    it take a long time to start up window
How to connect 520 to a tv
In the Quick Reference Guide ()
ftp://ftp.dell.com/Manuals/all-products/esuprt_laptop/esuprt_latitude_laptop/latitude-d520_setup%20guide_en-us.pdf, at page 12, you can see 2 connectors that can be used to connect your laptop to the TV (4=S-Video TV-out connector and 6=video connector).
Depending of your TV (type and model), you can use one or both of theese connectors. For an analog TV you can use only the S-Video TV-out connector, using a proper cable (S-Video to S-Video or S-Video to SCART). For a digital TV (LCD, LED) you can use also the video connector (D-Sub 15 pin), if your TV is equiped with a similar video connector. If not, you must use a converter, but is more expensive.
In all cases you must use a second cable for the audio signal (see the audio connectors, at page 11).
Aug 09, 2014 | Dell Latitude D520 Notebook
How do I change the screen resolution on the TV from "standard 420" to HD?
The screen resolution will automatically change based upon the resolution of the input signal.
Are you using an RCA connector? Perhaps an S-Video connector? NEITHER OF THESE ARE CAPABLE OF PRODUCING HD VIDEO!!!
In order to view HD video, you must use one of the following:
  1. HDMI connector (optimal)
  2. DVI connector (almost as good but requires a separate audio connection)
  3. RGB video connector (also requires a separate audio connection)
If you are using one of the three connection types above, contact your DirecTV representative to find out how to switch your cable box output from SD to HD.
Jul 20, 2014 | Vizio 42"" vw42lhdtv10a 720p widescreen...
Want to know how to connect acer 3680 to tv
It depends on your TV
If your tv has a Computer VGA connection you can directly connect the VGA connector from the left side of the laptop to the connector on the tv
If there isn't then you could go buy a S-Video to RCA cable at radioshack and connect the S-Video port on the laptop to a video in connection on the TV
For sound you can connect the speaker/headphone jack on the laptop to the tv using a cable either going direct from 8mm to 8mm or from 8mm to RCA...either can be found at radioshack
Let me know if you need anything else!!
Jul 01, 2011 | Computers & Internet
How can i connect my laptop ibm R51(2887) AE3 to TV using svideo cable
Hello - It's really fairly simple. You need the S-Video cable and if you want sound a 3.5 mm stereo cable with whatever connector on the opposite end that your TV requires (probably stereo RCA male connectors.)
Here is an illustration direct from IBM about setting up the R51 to TV connection:
Enjoy and thank you for using Fix Ya.
Mikeywaf
Mar 22, 2011 | Computers & Internet
How do I connect my Logitech music system to the TV. What connection and plugs is required? Kindly advise.
If your music system is only audio,then you need two RCA type audio cables pair for left& right audio channels(male pin jacks).Connect them at Music system audio output with left & right channels accordingly while on yr TV,connect the other ends to the audio Input jacks(female type). If there is a video out also from your music system then add the yellow video cable as well in the same way.
Aug 23, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
I have a Dell computer that runs Windows Vista and I want to hook it up to use my TV as a monitor to watch a webcast. Please advise.
The first step is to inspect both your laptop and TV and identify the connections, easily located on the back of either component. There are five basic types of jacks, or ports involved:
*Composite/phono plug (RCA)
*S-Video
*Video graphics array (VGA)
*Digital video interface (DVI)
*High-definition multimedia interface (HDMI)
*An RCA connector, sometimes called a phono connector, is used for analog audio and video components. Three round, colored sockets are standard — left audio is white, right audio is red, and composite video is yellow. These are standard jacks on older TV’s and laptops. A three-prong cable, readily available at any computer or electronics, is the easiest way to make an RCA laptop to TV connection.
*S-Video, or Super-Video, a more advanced analog video connector, uses a four-prong round plug, like those used in TV cable installations. Separate audio cables are the same as for the RCA connector, left audio/white, and right audio/red. S-Video is commonly found on older TV sets and some laptops.
With S-Video on both TV and laptop, connecting a laptop to a TV is a simple matter of a single S-Video cable. If your laptop has a great sound system, you won’t need audio cables, but for better quality you’ll also want audio cables.
RCA to S-Video cable, a special laptop to TV cable, is available when you have RCA jacks on one device and an S-Video port on the other.
*A VGA connector and cable are used to carry analog video signals plus display and graphics data. The VGA is a 15-pin connector commonly found on laptops and other devices. With this port you need a PC-to-TV Convertor to connect laptop to TV. You simply plug the VGA cable from the source into the convertor, and use an S-Video or RCA cable out to the TV. The converter is USB powered, so there’s no external power adapter to carry around, making this laptop to TV connection entirely portable.
*A DVI port is rectangular with 24 pins arranged in three horizontal rows of eight pins for digital video; separate RCA analog audio cables fit into white and red plugs. DVI ports are found on Macintosh laptops; sometimes they are smaller than normal DVI ports and require an adapter, which usually comes with the laptop.
*The HDMI port, one-half the size of the DVI port, is also rectangular with 19 pins. It provides digital audio in addition to digital video, despite it’s smaller size, for a complete TV to laptop connection. These ports are found on new HDTVs, and sometimes there are two or more. TVs with HDMI ports are the only ones that do not require additional audio cables.
TV’s with a single digital port labeled HDMI/DVI require only one cable when the source is another HDMI component. But when source is a DVI laptop, you need a DVI-to-HDMI cable for the video and a separate pair of RCA analog stereo cables.
NOTE: Whenever ports do not match, you can by adaptors and/or cables to make any connection.
NEED MOre HELP check this link for video :
http://www.online-tech-tips.com/computer-tips/how-to-connect-your-laptoppccomputer-to-your-tv/
Jan 20, 2010 | Computers & Internet
What cable do I need to connect latitude D600 to a hdtv ?
*S-Video
Nov 22, 2009 | Dell Latitude D600 Notebook
S-video problem for inspiron 6000
You will have to look at your TV to see what type of interface it has for PC connectivity, this is because there are 2 types of Video out on the laptop, first the s-video and secondly VGA (D-SUB).
I would recommend the VGA connection as the quality of the picture will be much better than s-video, so you will need a male to male VGA cable if your TV takes that interface (a male to male mini stereo cable is also required for audio)
If your TV only supports s-video then you are stuck with that interface until you upgrade your TV.
If you need anymore help in this matter please don't hesitate to post back.
Regards
Jun 29, 2009 | Dell Inspiron 6000 Notebook
I want to hook up my laptop to my HDTV 42"
to connect your laptop to your tv you will require a connector wich would first convert your vga to svideo
you can get this converter at any good electronics store
this site will give you the type of connection required check your tv for the connections it will accept and choose the right cable
http://www.svideo.com/sv3rca.html
Mar 01, 2009 | Tivo Series2 TCD649080 Video Recorder
Connecting Dell Precision Laptop to Samsung 29 inch Easy View (CRT) T.V
dear sir.
here u have to chek cable yr laptop is not support with a same s-cable u need to connecter for s-vadio to audio vedio connector and it's convort yr s-cable to comosite cable afer that it's automaticly dosply thru composet.... yeah one thing have to chek with different cable then selacet display propatise to set output setting is set in to s-video.. it's help u...:)
Thanks
please vote
jo_chinmay
Mar 16, 2008 | Samsung CW29M64NS 29" TV
Dell Vostro 1510 Laptop Logo
76 people viewed this question
Alun Cox
