Question about Whirlpool LSQ8000 Top Load Washer
Whirlpool LSR5132PQO not working
My washer machine is not washin ,not drawing not spins it wilpoor general electric model lsr5132pqo?
  • sheyla_fonta Feb 27, 2009
    if some vary now about whirlpool LSR5132PQO my washer is not working not washer thet all i need solution please
  • Whirlpool Master
  • 3,361 Answers
Check the lid switch with a volt/ohm meter for continuity.
If no continuity, replace the lid switch.
Check the direct drive coupling on the motor.
If it will not drain, bad lid switch.
If it will not agitate or spin bad drive coupling.
Posted on Feb 27, 2009
Whirlpool wtw5700sw0 won't spin and motor hums
Please check the motor capacitor, use a capacitor in parallel to confirm. check the motor spindle and paddle for free run., Please check this link;
http://www.espares.co.uk/advice/washing-machines/a/7/1379/how-to-replace-the-carbon-brushes-on-a-washin.html
Mar 14, 2012 | Whirlpool WTW5700S
Hello, after the first fill it will trip the circut, I have tried what I believe to be a different circut with the same result. Washer still full of water, please help.. Thank you for any help. Model# ...
Check to see if this may be caused by a Ground Fault Interrupter. If water has gotten into the electrical system of the machine, this will continue to trip until the fault location has dried out and no longer causing electrical leakage. If this is a standard breaker that is tripping, this would mean you have a shorted motor causing it to draw excessive current.
The combination breaker/GFI can itself fail; I replaced several of these after only a few years of service.
Aug 08, 2011 | Whirlpool Washing Machines
My washine machine stops at the rinse cycle
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
May 09, 2010 | Washing Machines
NOT FULLY SPINNING
if the spin speed is slow it could be the clutch is worn out.
Mar 21, 2010 | Whirlpool LSQ8000 Top Load Washer
WASHER MASHINEWHIRLPOOL LSR5132PQO IT NOT WORKING
timer and motor, timer cost about 68USD and motor 130USD you need a qualified repair person to look at it
Feb 27, 2009 | Whirlpool LSR5132PQ Top Load Washer
and also the "drive motor to transmission coupling" is probably broken. You need a repair person.
Washin machine won't spin
hi the problem you have is with the lid switch. located under the top replace this lid switch thanks the appliance doc
Oct 16, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool LA6800XSNO won't spin
I never posted a problem about a Whirlpool Duet GHW9150P. My model is LA6800XSNO, a completely different product that is 21 years old..
The service manual I purchased with the washer is completely wrong as well - the manual is for a belt drive model and this washer is a direct-drive model. Thanks, retailer; wish I could remember who you are.
There is supposed to be a solenoid, or as Whirlpool calls it a "control magnet" for the spin cycle. This part is not shown in any online parts breakdown online. The part is probably not available.
Here's how I solved the problem: I tossed the Whirlpool washing machine out the side door and sent my wife off to find a new one. It won't be a front-loading Whirlpool, because I don't need my clothes stinking of mold. I'd like to save water and electricity, but not at the cost of spending over $1,000 for a machine that doesn't do its basic job.
It won't be a Maytag because Maytag is very proud of not offering service manuals. As much as I hate GE (because of their **** refrigerators with always fail compressors and never-work icemakers) we'll probably end up with another top loader, maybe a GE.
HERE'S THE SOLUTION: POLLUTE THE LANDFILL WITH ANOTHER JUNK APPLIANCE THAT CAN'T BE REPAIRED.
Oct 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
LSR5132PQO Whirlpool Washer (Top Loader)
John, it's possible that it could be the basket drive. It sounds more like the clutch assy. Take the agitator off and look at the drive block. The two ears from the basket drive should be tight into the drive block, I will attach a picture of how it should look. If that looks ok, then I would suspect the clutch. They are not hard jobs, either one of them. 96d31f5.jpg
Aug 17, 2008 | Whirlpool LSQ8000 Top Load Washer
Whirlpool LSQ8000 Top Load Washer Logo
307 people viewed this question
Dan Webster
Dan Webster
Sal De
