Question about LG Sprint Fusic LX550 Cellular Phone
No voicemail people call my phone and there's no voicemail available and after several rings it cuts out on people.   sometimes when people dial my number it just hangs up.  what should I do?  can I still recieve calls anytime soon?
    Scholar:
  • 93 Answers
Voicemail is completely reliant on your cell phone carrier, you must talk to them about fixing it. Its cutting out on people or hanging up on them, since the voicemail is not working. It also might be the problem behind how it hangs up immediately, it also could be a phone problem. But Im pretty sure its your cell phone carrier. For example I had a text message problem on my old smart phone, youd expect it to be a problem with the phone, but instead I had to get it re-setup through by cell phone provider as the settings messed up. (Settings sent to phone from the cell phone provider, not in the phone itself/originally)
This has nothing to do you with your phone, and everything to do with your cellphone provider. Give them a call, check their website, or your bill for a customer support number.
Posted on Feb 27, 2009
Voicemail number changed on samsung galaxy and can not check voicemail now
Voice mails are set up from the phone company. Your phone has no control over the voice mailing service other than assigning a speed dial to it. You should call your phone company on their customer service number and they will tell your the number to call for setting up your voice mail box.
Mar 11, 2014 | Cell Phones
My voicemail stopped working. The phone rings and rings but doesn't go to voicemail.
Press Speaker
Dial *6
Enter Voicemail # (will appear on screen if you hit your voicemail button)
Press Speaker again
Nov 27, 2012 | NEC Dterm DTP-2DT-1 Phone
How to increase ring duration
First of all you need to know the number you dial for voicemail. Make a note of this.
Then, go to the dialpad and dial:
*#61#
and press Call.
A box will popup telling you what the redirect to voicemail delay is. On my handset the default was 15 seconds.
Now, dial:
**61******SECS#
and press Call
where *** is your voicemail number and SECS is the number of seconds you want it to ring for before diverting. For example, on Vodafone UK the voicemail number is 121 so to set the ring for 30 seconds before diverting, dial:
**61*121**30#
Once the box has come up saying it was successful you can use *#61# again to check the setting.
Oct 27, 2011 | HTC HD7 Cell Phone
How can I change the number of times the phone rings before the voice mail answers? Model # KX-TG4022
The amount of rings before a call goes to voicemail is setup on the network itself and not the phone. Some mobile providers won't let you modify it and others will depending on your region. You would have to call your mobile provider for the availability of the option and the procedures. Sometimes you dial a number to change it other times it can only be changed manually by the provider.
Jul 15, 2011 | Panasonic Cell Phones
How do you put a panasonic KX-T6730 on voicemail instantly if you need to leave the office early?
Press
Dial 50(forwarding program number) on the keypad
Press or
Dial one of the following single digits for the condition you want
0-off
1-DND(Do Not Disturb)
2-All calls forwarded
3-Busy calls forwarded
4-No answer calls forwarded
5-Busy/No answer calls forwarded
Dial the voicemail access code(default is usually 500; this is the number that will ring voicemail)
Press or
Lift handset or press to end
Dec 10, 2010 | Panasonic KX-T7630 Corded Phone
How do i change the number of rings on my phone before it goes to voicemail
The change is made in the voicemail system, not the phone. Get in to your voicemail box, listen to the menu and select the option for 'setup', 'settings' or 'system options', the exact name varies according the voicemail system, and you usually have to make several choices, but the options are almost always availble with menu selections. With hundreds of voicemail systems available, that's about the best advice you'll get with the information you provided.
Jul 21, 2009 | Lands Phones
I can't find out how to set the number of rings before my phone goes to voicemail
The system CF timer is something obscenely long, like maybe 40 seconds. Each user can change it by dialing *713 and a 2 digit number from 00 to 99.
Carl
Apr 16, 2009 | Panasonic KX-T7633 Corded Phone
When I registered my magicjack, I gave my home email address and password. When I activated it, I had to give them another email address and password. (no explanation for why, so I gave my work email...
live chat is no help, best solution is to get them to send you another unit, or go to best buy, buy a unit and return your old one and tell them it didnt work. you will have to choose a new number and stick with one email and password when it comes to magicjack or your are going to be stuck in "no solution" loop.
Mar 20, 2009 | Lands Phones
Need to forward to voicemail without phone ringing.
Transfer to voice mailbox: Feature 986, dial ext. number of phone and release. Call is transferred to mailbox without ringing the phone.
Mar 09, 2009 | NorStar M7310 Corded Phone
Setting the number of rings before voicemail cuts in
This is controled by your mobile phone provider. not an phone issue
Oct 01, 2008 | LG KU990 Viewty
LG Sprint Fusic LX550 Cellular Phone Logo
97 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
