Question about Kenmore 73952 Gas Dryer
110V dryer doesn't heat past 107 degrees
We bought a used 110V portable dryer for our apartment. The dryer doesn't heat past 107 degrees. Bought a new heating element, that wasn't the problem- both heating elements have the exact same ohm reading. Bypassed the hi-limit on the heater. That still didn't raise the temp past 107. Any suggestions?
    Problem Solver:
  • 17 Answers
It may not be your heating element. Your dryer lint vent pipe out the back of the machine or maybe out the side may be plugged. You have to pull the machine out and clear that pipe or rebuild it out to a soffit vent or static vent if it is in the attic, or out through your crawl space. This will make a huge difference. If that hot air and moisture doesn't get out of the machine it just goes back into your clothes.
Good luck!!
Posted on Mar 25, 2009
  • Kenmore Master
  • 4,655 Answers
Make sure the vent on the back of dryer is not blocked. Most dryers use 240 volts. Read the data plate on rear of dryer to confirm this. Example number 912.25879
  • Beneath Or Inside door Compartment On Cabinet Frame
  • On Plate Lower Front Or Rear Of Cabinet
  • Beside Door On Right End
  • Near Rear Of Cabinet
  • Inside Liner At Top
Let me know Thanks, Sea Breeze
Posted on Feb 27, 2009
The belt will not stay on the pulley can someone help me
I put a thin spacer behind the tension pulley , just enough to correct the alignment.
Jan 19, 2016 | sonya Portable Compact Laundry Dryer...
I have a MicroExpress laptop model FL92 that I bought several years ago. Ever since I got it, I've had problems with it suddenly quitting without warning. It appears to be heat-related and has p
depending how computer savey you are, you could open it up . clean heat sink and apply new thermal paste to the processor. not too moch, but not too little
Jan 30, 2013 | Computers & Internet
Ventilation question regardingHAIER HLP140E
Hi I own this dryer and you have two choices for venting it. One reason I originally bought it is because you can run it safely without venting it to the outside. That's a huge plus for many small apartments or a dorm room etc. For that option you purchase a 'ventless' kit from Lowe's or Home Depot, can't remember the exact cost but definitely less than $20. It works very well, but will add some heat to your living space (nice if you're in NY, less nice in Miami). It didn't add a lot of heat to the space, but later on I ended up installing a vent through the outside wall (which was much easier to do than I thought) because I was doing some drywall work in that area anyway. That vent is also very inexpensive, maybe $10. The standard vent kit opening will be for 4" whereas this dryer's vent opening is 3" - but the dryer comes with a piece that makes the 3" to 4" transition for you. This is a very convenient unit because it only needs 110v (standard household outlet) instead of the usual 220 (or is that 240?). The main thing that will help you be happy with it is just to have the realistic expectation that it takes about twice as long to dry clothes (60-90 min) because it's on lightweight power. But it does a very nice job, and we love the little washing machine we got with it too!
Mar 23, 2009 | Haier HLP140E Electric Portable Dryer
Kenmore Portable dryer, shocking
To me it sounds like you could have the polarity reversed on the wiring. Also is the outlet that it is plugged in to grounded that alone will cause a shock to be given off, Have goods holiday, biigg53566+
Dec 01, 2008 | Kenmore 82722 Electric Portable Dryer
Using dryer in 220volt country
Bombay is 240v single phase, the three wires in the socket are active neutral and earth, not as the 2*110v90degree two phase American circuit active1 active2 and neutral
If the transformer is designed for American use, it does not step down 220v,
it instead takes a 2*110v90degree 2 phase supply and produces a high current 110v single phase output, by setting both input phases electrically 90degrees apart on a common primary winding.
This is not compatible.
replace the dryer, cheaper faster safer
should have left in Houston
Sep 09, 2008 | Kenmore 62602 Electric Dryer
Indesit dryer IS70CS
sounds like the heating element or thermostat has gone in the dryer these parts can be bought from www.indesitservice.co.uk or www.espares.co.uk
Aug 02, 2008 | Zanussi TC180W Electric Portable Dryer
Kenmore 73952 Gas Dryer Logo
122 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
