Question about HP Photosmart E317 Digital Camera
Is there a adjustment button somewhere on the camera for taking pictures at close range? When I take a close up shot it is blurry. Let me know if any kind of adjustment can be made. get back to me at pg.malcolm@gmail.com Thanks Mr. "G"
  • 262 Answers
It's hidden, right there on the front of the unit! On the distant setting (mountain icon) it will focus down to 60cm; on the close-up setting, called "macro" by photographers, (flower icon) it will focus down to 10cm.
Posted on Feb 27, 2009
You didn't answer my question so am asking again...all my pictures are dark and blurry - help
There are two possible problems:
1. The camera is defective.
2. Operator error.
In most cases, #2 is the answer. Digital cameras are convenient, but are sensitive. They have very bright flash units and often wash out the picture that you are trying to take, especially if the item is reflective, you are close to it, and taking the shot straight on. Thus, many users turn the flash off to get the picture to look better. Now the camera has to work differently. In order to get the right amount of light to get a good picture, it will slow down the shutter response. This lets more light onto the CCD and results in a brighter picture without the flash. BUT, the slower speed means that you must be very still in order to prevent blurring, and many users cannot get the hang of it. Also, some cameras do not adjust well to lower light and thus are not only blurry, but dark as well. Try shooting different scenes, indoor as well as outdoor, short, mid and long range in different lighting conditions. If everything is dark and blurry, regardless of the situation, then as a last resort, have another person try to take a few shots. If they are no better at it, then blame the camera. Otherwise, just practice with it until you get good at it. Some cameras are more user-friendly than others.
Jan 05, 2016 | Cameras
My Nikon D60 is suddenly taking very blurry pictures when I know I've properly focussed.
since the camera has many adjustment, Read carefully the owner manual and go to the section troubleshooting and see the different adjust need for to fix it problem
If you do no have owner m. go to www. retrevo.com and download
God bless you
Aug 02, 2012 | Nikon D60 Digital Camera
When take picture in normal mode or 1x/ 2x zoom the picture clarity and sharpness is very good.but when i take picture in 3x/4x optical zoom ,picture clarity and sharpness is very poor..my camera i cannon...
Turn on auto focus and when you are taking a shot let Auto-Focus adjust the blurry image in the viewfinder beforeyou take a shot. If you do not know how to do it please let me know and I will give you detailed instructions.
Sai.
May 16, 2011 | Canon PowerShot A570 IS Digital Camera
VIEW SCREEN IS SO BLURRY I CAN'T TELL WHAT ITS SHOWING.
Is it the viewfinder (that you hold up to your eye) or the screen that's blurry?
If the viewfinder is blurry, there should be a diopter adjustment to fix it, probably right above the rubber eye cup.
If the screen is blurry, you should take some pictures and video and view them on a computer. I they are sharp on the computer but blurry on the camera screen, there may be a problem with the screen and you may need to take it in for repair.
If the pictures are blurry on the computer as well, the camera may not be focusing properly. If you can't focus manually, or the camera can't focus when auto focus is turned on, you have good light, and aren't too close to your subject, then it may need to be serviced.
Feb 26, 2011 | Sony Cyber-Shot DSC-F717 Digital Camera
Sony Cyber-shot takes lots of blurry pictures in
first thing you can do is to try reverting cam back to factory settings.to do that initialize the camera.it's under menu>setup settings>main settings1>initialize. after initializing,set cam to auto adjustment mode (green camera icon in mode dial). what to avoid when taking pictures:
1.subject too close (use macro if needed)
2.insufficient light
3.subject movement
4.camera movement (that's caused by you)
5.incorrect camera setting
5.incorrect camera operation
btw, before you take a picture,press the shutter button halfway down first to give the cam ample time to focus.you'll see a flashing green indicator on the screen that means cam is focusing.when the indicator stops blinking cam is ready for the shot.press shutter button all the way.review your picture.if still blurry, you may try changing iso (for dark or fast moving subject, note:the greater value the noisier the picture gets), metering mode and focus settings by going to the shooting menu (press menu when your in P or program mode). hope this helps.tnx:)
Apr 16, 2010 | Sony Cyber-shot DSC-S980 Digital Camera
Focus problems
There are two likely reasons for the blurry pictures. One possibility is, as you surmised, a slow shutter speed. Try mounting the camera on a tripod or other stable support. You might also try turning on the flash.
The other reason is focus, or lack thereof. You didn't specify what cameras you have, but if they're Coolpixes, they most likely have a close-up or macro mode that will allow the lens to focus closer. If you're using a DSLR, you will need some other way to focus closer. Macro lenses, extension tubes, and close-up filters are three ways of achieving this.
Jan 20, 2010 | Cameras
Pictures are appear blurry when reviewing them. I focus the camera object appears clear after I snap the picture it becomes blurry as it is being save for review.
Question : Why are my pictures out of focus (blurry)? Answer : This problem can occur for one or more reasons. Here are some common causes and suggested solutions.
  • The lens is dirty. Use a soft brush to remove dust and dirt. Wipe the lens gently with a soft, lint-free cloth or an untreated lens-cleaning tissue. Do not use cleaning solution unless it is designed specifically for camera lenses.
  • The subject was too close to the camera. Make sure that you are far enough away from your subject. Each camera has a recommended distance for normal, telephoto (zoom), wide-angle, and close-up pictures.
  • The subject was not within the effective range of the flash. Each camera has an effective flash range.
  • The camera did not focus or expose the picture correctly. For the best possible pictures, press the shutter button halfway and hold. When the Ready light or framing marks turn green, press the shutter button completely down to take the picture.
  • The LCD screen Preview feature was not used to take a picture in Close-Up mode. Always use the Preview feature in Close-Up mode to confirm focus and to frame the subject properly. If the Preview feature is not used, the LCD will not display an accurate view of the subject.
  • The subject or camera moved. Hold the camera very steady when taking a picture, or place the camera on a flat, stable surface. You may want to consider using a tripod or monopod.
Dec 08, 2009 | Kodak EasyShare Z740 Digital Camera
Pictures are out of focus on screen and when taken i cant seem to reajust the focus camera has been working fine untill i went to take a close up shot and now completely blurry .
If you are focusing On a subject make sure first that you are two feet away,
You can also try to turn On the blur reduction under setup menu. make sure also that your on auto mode or smart scene.
when taking picture indoor turn of the flash, you can do this by pressing the flash button On the camera
here are some basic troubleshooting
try to put your camera On a tripod or on the table to stabilize the camera then try to take a picture.
the technique of taking a picture Is first you need to half press first on the shutter button and you will noticed camera will adjust Now if the camera already adjusted pull press on the shutter button.
Blurry picture may caused if camera is not stabilized and may cause also if the flash will not fire correctly.
you may call tech support for further support toll free 1 800 235 6325
Nov 12, 2009 | Kodak EasyShare V550 Digital Camera
Ixus 750 Blurred photos shot at a distance greater than a meter.
Check to see that the camera is not in "macro" mode, which would only allow focusing at a close range, but not allow focusing at beyond about 2 meters (look for the "flower" symbol to tell you that macro is activated). Could also be an out of adjustment lens, due to impact or force. Also check to make sure it's not as simple as a dirty lens. Digital cameras are more succeptable to blurry pictures from a smudged lens than film cameras were. Of course, that wouldn't explain why close shots are OK but distant ones aren't. Probably the first two suggestions.
Oct 06, 2008 | Canon PowerShot SD550 / IXUS 750 Digital...
Camara won't take pictures, screen shots look black and white blurry
Hello, please try to reset the camera and check your settings according the user manual. If you need more info please advice. Arpi
Jun 14, 2007 | Sony Cyber-shot DSC-W70 Digital Camera
HP Photosmart E317 Digital Camera Logo
93 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
