Question about E-Machines eMachines Desktop PC
Pc reboots automatically while starting for the first time
It reaches the operating systems start page before rebooting. no bootable drives were installed was shown after it reboots. My only solution is to turn-off the system then turn it on again. After the second turn-on, pc is good to use without interuption.
  • 32 Answers
Check in your bios make sure your hde is firt boot. send floppy down to bottom of list make your second boot your cr drive.click f10 save changes
Posted on Feb 27, 2009
Gateway ta1 starting in phoenixbios setup utility.
insert a cd/dvd/bootable flash drive with a windows/linux setup on it and reboot to install an operating system.
Sep 09, 2014 | Computers & Internet
Windowss xp professional reboot disk
http://windows-xp-pro-startup-disk.soft32.com/
Bootable disk for XP Professional.
The Windows XP start up disk allows computers without a bootable CD-ROM to perform a new installation of the operating system.
Apr 21, 2013 | HP Compaq Evo D310 PC Desktop
Several attempts to install windows 2003 on dell optiplex 780 have been unsuccessful. all i get each time is a blue screen.
Windows 2003? There is no operating system called "Windows 2003". There is Windows 95, Windows 98, Windows ME, Windows 2000, Windows Milenium, Win Xp, Win Vista, Windows 7 ect. But no Windows 2003.
If you are trying to install an operating system on a Dell computer, put the disk in the cd or dvd drive on the pc and close it. Then turn the computer off and reboot it with the disk in the drive. After the computer reboots, it should recognize the disk in the drive and bring up the installation process automatically. Sometimes you have to reboot the computer 3 - 4 times in a row with the disk in the drive in order to get it to recognize the software and boot from that drive.
If the Dell does not have an operating system on it and you are trying to install windows from a disk, it may not auto recognize the program in the drive and the above instructions will not work. If this is the case, then you need to put the disk in the drive of the pc and restart/reboot it - and watch the computer screen as the pc restarts - look at the lower left side of the screen during the boot up process to see what keys you need to press to enter startup mode, or get into the bios system of the computer. when you boot up a pc, it will display the keys you need to press on the screen for a brief few seconds before the "windows" screen appears and it completes the start up. If the pc is running windows xp, the command keys to press during start up might be F2 - F8 or "press the delete key". The commands can differ depending on which version of windows you are using - and they can also vary by brand of pc too.
You need to put the pc into "safe mode" or get into the Bios system or restore area to install windows if the computer does not already have an operating system installed on it.
To put the pc into safe mode or get into the Bios System, you need to press the right keys during the start up - and do this before a picture appears on the screen or the windows display comes up.
Put the disk in the drive and reboot the pc. As soon as it starts to reboot, keep pressing the F8 key. If the pc does not go into Bios or say "loading safe mode" then immediately restart the pc and try again. Sometimes it takes 3 or 4 attempts to make this happen. If the F8 command does not work after 4 tries, then try the F2 key. After four tries if that does not work - try pressing the delete key.
If you can get the pc into the bios system - use the arrow keys on the keyboard to scroll through the options and find the prompt that says "boot order". change the boot order to boot from the Cd or Dvd drive instead of the hard drive. Save after changing this setting and reboot the pc with the disk in the drive and it should boot from that disk to install the operating system. Try rebooting 2 or 3 times after changing the boot order to the disk drive to get it to boot from the cd. Then just follow the prompts to install the operating system and your done!
Jul 07, 2011 | Computers & Internet
Reboot and select proper boot device. what does it mean?
Boot device per see means that it is the device where you want your computer to start it may in the form of Optical drive (CD, DVD), Harddrive, USB drive (thumb drive), Floppy drive (for old computers). When get this error it also means that there are devices you have that are bootable it may be in a form of an Operating System Disk or just a simple bootable floppy drive. But the usual bootable device once you had the operating system installed already will be the Harddrive.
Apr 22, 2011 | Microsoft Windows XP Professional
Automatic reboot
http://goo.gl/KNTna
The link above is a tutorial on scheduling automatic reboots on Windows XP.
Mar 06, 2011 | Microsoft Windows XP Professional
Replaced hard drive and am getting a "Reboot and
Hi seqhdha,
The reason why you're receiving that meesage is the system is not detecting any bootable device on the computer or it is boot from a media that is not bootable (CD/DVD/USB). To fix this problem if you already installed the Operating System you can change boot priority setting and select the Hard Drive as the First Boot Device however, if you havent install the Operating System you need to select the CDROM as the First Boot Device and insert the Windows Installer.
Here are the steps on how to access the BIOS Page.
1. Restart the computer and while it is booting tap DELETE button.
2. On the Bios page look for the BOOT tab then set the priority to either Hard Disk or CDROM depends if you already installed the OS or not.
3. Follow the instruction on how to install the Operating System
4. Rate me if this helps so i can help others.
Thanls for using Fixya.
Jan 31, 2011 | Gateway 550GR PC Desktop
I am running vista. About every 4 - 5 time I launch Quicken 2008 it lock up my PC and has to be rebooted. This all started about 1 month ago. Before that everything worked fine.
Very easy problem to fix. Reboot your computer when it's in the boot up stage just keep hitting the F8 Key. This will bring up the repair menu with a list of options. The hard drive in the Vista operating system is partitioned. This replaced your operating system disk from all previous operating systems as it is in a safe section of the hard drive out of the reach of viruses. You access it by hiting the F8 key during boot up. Start at the first option and work your way down until the problem is solved. Should take all of about 2 minutes.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
May 22, 2010 | Intuit Quicken 2008 Deluxe Full Version...
My ascer aspire 3680 has windows xp on it. I had
go to advanced option by tapping f8 while starting the computer, go to disabled automatic restart, now this time onwards if it crash again it will tell u the err , then u can talk abt the resolution. by the time u can do a system restore.
Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore.
2.
On the Welcome screen, click Restore my computer to an earlier time, and then click Next.
3.
On the Select a Restore Point page, select the date from the calendar that shows the point you'd like to restore to, as shown in Figure 2, and then click Next.
Figure 2
4.
On the Confirm Restore Point Selection page, verify that the correct restore point is chosen, and then close any open programs.
5.
Click Next if you are ready to proceed or click Back to change the restore point.
6.
The computer will shut down automatically and reboot. On reboot, you'll see the Restoration Complete page, and then click OK.
After reviewing the stability of your system, you can choose another restore point or undo this restoration. Just open System Restore and make the appropriate choice. After you use System Restore, you'll have an additional task, Undo my last restoration, on the System Restore Welcome page. Remember that you'll have to reinstall any programs that were installed after the restore point.
If System Restore doesn't work in Normal Mode, it might work in Safe Mode. To use System Restore in Safe Mode, press the F8 key during reboot and choose Safe Mode. When your computer starts in either Safe Mode or Normal Mode, System Restore can be used to capture a working previous state. System Restore can't be opened unless the system is bootable into one of these modes.
http://bertk.mvps.org/html/restoresysv.html
Mar 30, 2010 | Acer Aspire 3680 Laptop
Rebooting windows vista back to when i first got without a disc
You might try system restore option and restore it to a date you know it worked well
1.
2.
3.
Figure 2
4.
5.
6.
Oct 22, 2008 | Computers & Internet
I cant identify the prolem
It looks like you may have a boot sector virus. A boot sector virus is one that infects the first sector, i.e. the boot sector, of a floppy disk or hard drive. Boot sector viruses can also infect the MBR. All disks and hard drives are divided into small sectors. The first sector is called the boot sector and contains the Master Boot Record (MBR). The MBR contains the information concerning the location of partitions on the drive and reading of the bootable operating system partition.
When disinfecting a boot sector virus, the system should always be booted from a known clean system disk. On a DOS-based PC, a bootable system disk can be created on a clean system running the exact same version of DOS as the infected PC. From a DOS prompt, type:
    SYS C:\ A:\
and press enter. This will copy the system files from the local hard drive (C:\) to the floppy drive (A:\).
If the disk has not been formatted, the use of FORMAT /S will format the disk and transfer the necessary system files. On Windows 3.1x systems, the disk should be created as described above for DOS-based PC's. On Windows 95/98/NT systems, click Start | Settings | Control Panel | Add/Remove Programs and choose the Startup Disk tab. Then click on "Create Disk". Windows 2000 users should insert the Windows 2000 CD-ROM into the CD-ROM drive, click Start | Run and type the name of the drive followed by bootdisk\makeboot a: and then click OK. For example:
    d:\bootdisk\makeboot a:
Follow the screen prompts to finish creating the bootable system disk. In all cases, after the creation of the bootable system disk, the disk should be write protected to avoid infection.
Once the OS loads, run your anti-virus software and it should clean the virus.
Should this not help, I'm afraid the only other alternative would be to reformat the HDD and reinstall XP again from a bootable disc.
Hope that helps..
May 07, 2008 | Computers & Internet
E-Machines eMachines Desktop PC Logo
32 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
