Question about Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas
Teledyne Laar 400k btu heater heater fires but wil not stay on
The heater will cycle light and gas will run as ssoon as full gas flow starts it turns off. the cycle repeat for two or three times then nothing
  • Anonymous Mar 28, 2009
    Same here
The most likely cause is a defective limit switch on the header. There are two limit switches, a "high limit" and a "low limit". They are mounted in wells next to brass plugs in the thermoplastic header just below where the water outlet is. They have shiny metal covers over them and you can see the wires going into the wells just below each cover. With time and use the brass plugs begin to seep pool water, corroding the sensors. If the sensors are open circuited the ignition controller will not allow the hot surface ignitor to fire the gas. Even though this is a failure of the limit switch it will show up on the diagnostic panel as "AGS" (automatic gas shutdown) because it is not a temperature limit problem but an "ignition problem."
Posted on May 18, 2009
  • 463 Answers
Flaky thermocoupler.
Posted on Feb 27, 2009
My laar hot shot natural gas pool heater pilot says lit but wont fire any more replaced pilot generator pilot that whole unit nice pilot but wont fire
problem isnt with the pilot generator. you have either an open safety withing circuit, lose wiring connection, or tstat issue
Aug 17, 2013 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot light stays on but burners will not come on.
open safety within circuit, poor electrical connection or tstat issue
Oct 21, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
Teledyne Laars LD250 Propane Pool heater cycles on and back off
Do you replace the thermopile or check the milivolts?
Check the Pressure gas
You need replace all of them terminals and check again the milivolts at the gas valve
Apr 01, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Laars 400k won't stay lit
sounds like dirty flame sensor,clean with fine emory cloth
Jun 17, 2009 | Teledyne Laars Laars Lx Pool Heater /...
Pilot light on but heater will not start
check the high-limit switches. Under the inlet/outlet header. if either is open it will not allow you to fire up. my 150 degree switch was corroded and after jump9ng out, bam it worked.
May 25, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Pool heater cycles off and on
check pressure switch if ok check for loose wires if ok check copper tube to pressure switch
Mar 16, 2009 | Raypak Pool Heater Covers for Teledyne &...
MY Teledyne Laars is 20 year old +
check pressure switch (looks like space shuttle copper wire one side 2 wires other side) need 24 volts ac both sides if not need new
Dec 18, 2008 | Teledyne Laars Laars Lite 2 Pool Heater...
Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas Logo
684 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Bill Jordan
Craig Butler
Craig Butler
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
