MSI PT880 Neo FSR Motherboard
Problem for MSI PT880 Neo FSR Motherboard
NEW SATA DRIVE, OLD IDE Problem
By Bomber - usenet poster
Here's the story:
I bought a new SATA drive and need to transfer files to it from my old
IDE drive. The IDE drive doesn't have any OS on it, it was previously a
slave drive used to store files.
I hooked up the SATA drive, installed XP, everything worked fine. But,
when I hook in the IDE drive--as either a master or slave--the system
loads all the way up till I can see the desktop, and then immediately
crashes with a B.S.O.D.
Before the SATA drive was installed, the IDE drive in question was a
slave drive and worked fine (another IDE drive was the master).
What is causing this problem, and how can I fix it?
MSI PT880 Motherboard
Intel P4 3.2
Solution #1
posted on Sep 01, 2007
Not Rated)
godbun
Rank: Apprentice
Rating: 0%, 0 votes
connect the old drive on a machine which is compatible with that drive, then use your flash disk to transfer the files from the old hdd
Was this helpful?
Yes
No
Solution #2
posted on Aug 02, 2007
Not Rated)
Bouncy
Rank: Apprentice
Rating: 0%, 0 votes
XP doesnt do it that way.
Maybe, but that shouldnt produce a BSOD.
Most likely its just booting off the IDE when its present.
Was this helpful?
Yes
No
Solution #3
Not Rated)
Putty
Rank: Apprentice
Rating: 0%, 0 votes
Stockmoose16 <
Sounds like its trying to boot off the IDE when its installed.
Most likely the bios has been told to boot off the IDE and does
so when its present. When its not, it looks for other bootable
drives and boots off the SATA when the IDE isnt present.
See if you can tell the bios to boot off the SATA
drive. Likely the IDE drive is higher in the boot
sequence order. Move it below the SATA drive.
If you cant do that for some reason, you should be
able to wipe the IDE drive with something like clearhdd
if you dont care about its contents. Do that with just
the IDE plugged in with clearhdd on floppy etc.
Was this helpful?
Yes
No
Solution #4
Not Rated)
jessie25
Rank: Apprentice
Rating: 0%, 0 votes
What do *you* think if he previously booted from it?
Not with XP.
Was this helpful?
Yes
No
Solution #5
Not Rated)
man1
Rank: Apprentice
Rating: 0%, 0 votes
There may be something wrong with the structures on the drive.
That may not have been a problem when XP was booting from it
but may be when it is discovered as a data drive by XP.
A crash for that is excessive though.
You can also try obscuring the previous installation of XP on that drive,
e.g. by renaming the directory it's in, in case XP has a problem with that.
Was this helpful?
Yes
No
Solution #6
Not Rated)
Pasty
Rank: Apprentice
Rating: 0%, 0 votes
Did your old drive have a primary or extended partition? Primary partitions
take precedence to secondary partitions for drive letter assignments. You
might be causing the drive letters to be rearranged when you boot up this
way, which would cause Windows to not be able to access any of its files
after it kicks past a certain stage in the boot process.
-Jeff
Was this helpful?
Yes
No
Solution #7
Not Rated)
Odud
Rank: Apprentice
Rating: 0%, 0 votes
Determined how exactly? Describe cabling and jumpers. Is the IDE drive
recognized normally by the BIOS during POST before the OS comes into play?
Is the IDE FAT[32] or NTFS? What happens when you try a w98se boot floppy?
--the system
What happens in Safe Mode?
Was this helpful?
Yes
No
Popular Solutions for MSI PT880 Neo FSR Motherboard
Questions and Unsolved Problems for MSI PT880 Neo FSR Motherboard
Do you recommend MSI PT880 Neo FSR Motherboard?
Answer
Answer
Sir, I have a Intel 945GCM-S+ICH7 Chipsets Motherboard. I am facing a problem since from last 4... (More)
Answer
I don't know which poles to put the wires on from the power switch to my ices 003 b motherboard
Answer
i have a desktop dv9000, that have stopped connecting the monitor, i tried the monitor on my other... (More)
Answer
I have a promax x chip and i want to fit it to my 2008 citroen c5 1.6 diesel. I am not sure of the... (More)
Answer
XP pro, SATA Greetings, I had a problem with my system after upgrading &amp; uninstalling the ... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For MSI PT880 Neo FSR Motherboard:
Top Motherboard Experts
Rank: Guru Guru
Solutions: 14935
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Motherboard Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
