Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
My refrigerator not pump water - KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
  • KitchenAid Master
  • 4,654 Answers
On the back of refrigerator is a water valve this is possibly your problem and is it is will need replaced. Let me know, Thanks, Sea Breeze
Posted on Feb 27, 2009
Why the water pump is not pumping water?
HI SORRY THE BEST I CAN OFFER IS CALL THEM CAUSE I SUSPECT THEY CONTRACT OUT TO MANUFACTURER FOR FRIDGES THEY ARE INTO ELECTRONICS AND COMPETE WITH LG
Jun 20, 2014 | Refrigerators
No water comming into machine
On a portable AC, the only way water can be distributed is by a pump which pumps the water out of the collector tank. Chances are that the impellor inside the pump has stripped or is slipping, therefore not pumping the water. ( that is , I am assuming , this model is an evaporative type cooler?? ) if it is a refrigerated type, there shouldnt be any need for water , however , it will have a condensate pan which catches the water produced by the refrigeration cycle.
Jun 18, 2011 | Midea MPM-08CR-BB4 Portable Air...
In door water dispenser of ED25QF will not dispense water. New filter, cannot detect kink in supply line, pump does not sound, still making ice, light in door works, dispenses/crushes ice. What is the...
The pump motor on the dispensing water is the problem. Pump motor problem is cause by no voltage power to motor, burnt motor winding, switch faucet on dispensing water, water supply line has jam, check it if you can if not, call a refrigerator service technician to do the job.
I hope I help you with your problem. Thanks!
Jun 11, 2011 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Water dispenser does not work. However, the ice maker does work so there is water availabe. Could this be a pump problem, if yes how do I replace.
It is not your pump, because despenser and ice maker both get water from the same pump.
Water despenser is activated by a small plunger when you press your water glass against it
to release the water. This is your problem, bad plunger.
Feb 03, 2011 | Amana ARS266ZBS Side by Side Refrigerator
I have a Kenmore Refrigerator: Model Number 106.50254001, Purchased 1-24-2001. It has a water and ice dispenser on the front. I purchased a Rainsoft Water Softening system, with a Reverse Osmosis System...
The water pump probaply is switch on by a flow switch. So the solution is to install a pressure tank after pump so to have stable pressure and not a pulsing one.
Sep 27, 2010 | Kenmore Refrigerators
Ice maker and water dispenser do not work. is there a switch or did something shut off?
  1. check water comming to fridg
  2. check filter(if you got one) new
  3. check if water come out of pump when you press water switch
  4. check voltage get to pump when you press for water.
  5. most likely the water got stuck and you need to replace : pump , filter
Jan 01, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water flow out of the door water dispenser is low nothing seems to be wrong
you have a water valve that pumps water for the door. need to check pump and replace if needed . most of the time it is the problem the water valve.. you might have two pumps on this fridg so make sure you get the right water valve.. one is for door and one is for the ice maker
Aug 12, 2009 | Maytag MSD2660KES Stainless Steel Side by...
Kenmore coldspot refrigerator
checked the pump action????its a water valve powered by 110v.se if you can rig a test cord and plug into the valve itself see if you get water then. also check to tubing leading to the ice maker for possibly being frozen, as a result of poor water flow in the first place
Mar 15, 2008 | Kenmore 62232 / 62234 / 62239 Bottom...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
65 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
