Question about Clarion MAX385VD Car DVD Player
Can you tell me what to hook it up to
What do you hook up the illumination wire to
  • 58 Answers
You connet it to ur remote cable is usally pink or blue
Posted on Feb 27, 2009
Single Pole Illuminated switch doesn't interrupt power to fixture.
there should be two wires coming from switch both black you should hook up the hot wire to one the other to the light it self. if there hooked up right then the switch would be bad if you have a volt tester this will tell if you have a hot wire or not , good luck
Sep 08, 2011 | Leviton Illuminated Decora-Style White...
I have a 1998 saturn and i put in a new stereo all wires are connected and working fine but the power antennae isnt hooked up neither is the orange illumination wire when i hooked the illumination wire to...
Hi, not sure what model you have, but you can get the factory wire colors here: http://www.modifiedlife.com/request-a-saturn-car-radio-stereo-wiring-diagram/
page down to select your model.
It sounds like you tapped into the brake light wire rather than the illumination wire. Also, there should be an antenna wire in the car if you have a retractable antenna. Did you purchase a GM connector with the new steroe to wire it in?
Mar 12, 2011 | Car Audio & Video
I have 2 wires for 1 wire. The 2 wires are> battery/constant >illumintion/dash light
it might require the illumination to be active all the time, i would hook the illumination in the with ACC wire. to prevent battery drain.
Apr 14, 2010 | Goodmans CD / MP3 car radio GCE780MPT CD...
How do i hook up my parking brake wire on my xdvd710
The yellow/blue wire out the back of the head unit needs to be hooked up to the same wire that is responsible for illuminating the "BRAKE" light on your dash. This tells the DVD player that the car is not in motion. Where this wire is and how to tap into it is entirely dependent on what kind of car you have. You may need to trace the wire out or consult a wiring diagram.
If you wish to bypass this feature (which may be illegal in some states) try this:
** Insert a DVD
** Let it play until you hear sound
** Press STOP twice on remote
** Enter 26604
** Press ENTER
Feb 26, 2010 | Dual Car Audio & Video
I have a sony cd player wx-gt78ui can you tell me please were the illumination wire grts hooked into
If you car does not have an illumination wire don't worry just cut and tape it you don't need to hook it up
Jan 31, 2010 | Car Audio & Video
Illuminating the sub
i would assume hooking it to the remote and ground of the amp
Apr 24, 2009 | Hifonics Brutus BX12D4 Car Subwoofer
What to hook the dimmer wire & illumination wire to
Those lower end Sony models dont use a dimmer or illumination. The display is constantly one brightness level.
Simply terminate or tape off those wires from the plug.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 17, 2009 | Car Audio & Video
Radio display light
To get the back light on you need to hook up the illumination wire to the ignition acc wire
Jan 10, 2009 | Clarion DXZ375MP CD Player
Radio Blowing Tail Light Fuse
by the way you tell me that the radio illumination is the gray wire and all of the rest you are wrong. try the correct way red is key positive,yellow is constant power,black is ground,orange is illumination,blue is remote,gray is right front positive and gray black is negative,white is left front positive and white black is negative,green is left rear positive and green black is negative,violet is Right rear positive and violet black is negative,
Nov 23, 2008 | 1993 Oldsmobile Cutlass Ciera
Illumination v. Dimmer
Good day,
The illum wire goes directly to the headlight switch and tells it when to light up, where as the dimmer wire is variable meaning it would dim up or down with your dash light control. Dimmmer is usually only need on factory radio's and not aftermarket. I suggest wiring only to the illuum lead and do not connect dim. Also about the clock make sure your red and yellow wires are not crossed, yellow is a constant hot and red is only hot when the ignition is on, so if they are backwards the radio would loose it's memory when you turn the key off.
Hope this helps
Mar 12, 2008 | Kenwood KDC-MP435U CD Player
Clarion MAX385VD Car DVD Player Logo
126 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
