Question about LaCie Big Disk External USB 2.0 1TB Hard Drive
Is the hard drive on its way out? What should I do?
I have a power mac G-5, I capture video w/ Final cut pro to my lacie, it worked fine for about 8 months until 4 days ago when it suddenly started unmounting and freezing, also caused FCP and other programs to freez. The only thing that was done differently was, I pull files from a USB flash disk.
  • 463 Answers
Get your data off that thing right now before it dies.
Posted on Feb 27, 2009
Macbook pro does not find canopus acdv110
How did You connect Canopus? Canopus has 2 Firewire slots - on the back and on the front. If You connect FW cable to a front slot, then, Canopus will not work. Only with external power supply. I´m offering the next proceeding:
1. Connect ADVC with FW cable 6 to 4 to Your macbook via back FW slot. The ADVC lights will now on. On front panel by default light is on mode "digital". If the light don't work - it's a Canopus problem. If light is up and working, then next step.
2. Go to apple menu-about this mac - more info - firewire. You MUST see here Your Canopus a a device. If so, go to the next step.
3. Connect Your VCR to analog inputs, on the front panel of Canopus.
4. Run FCE. If it says "apple firewire device is missing" then is something wrong with Canopus. If not, proceed to next step.
5. On the top of the front panel of Canopus, press button. The light changes from digital to analogue.
6. Press apple+8, then capture settings. Set the firewire device as uncontrollable device. Make sure that in capture window is "vtr ok". Turn the VCR on
7. Press the play button on capture window. In the window appears the screen of Your VCR. Then press play on VCR and then "capture now" on capture panel. Voila! Must to work.
Aug 30, 2009 | Televison & Video
XH A1
Drivers link
user manual link
After reading you manual you will notice on page 11 it states, that you need to use a P.C.it is not Mac compatable!!!!!
This touch screen will not work with Apple Mac
Dec 03, 2007 | 3M MicroTouch M170 17 in. Flat Panel LCD...
Tip
Import MTS to Final Cut Pro X-Convert Sony PJ30V 60p MTS to H.264 MOV for...
The Sony PJ30V has more compression options than your average camcorder. Most of its video is recorded using AVCHD compression, which is today's industry standard. The HDR-PJ30V has 32GB of internal flash memory and it can record Full HD video using 60p, 60i, or 24p frame rates. The PJ30V comes with the same version of Picture Motion Browser (PMB) software that shipped with the Sony HDR-CX700V, which we reviewed earlier this year. The new version of the software is nearly identical to previous versions of PMB, except version 5.5 does allow you to import and work with 60p and 24p clips (something that is essential for the HDR-PJ30V). One big downside, we noticed in terms of editing, is that the 60p clips recorded by the PJ30V don't always play nice with mac editing software. Final Cut Pro version 5.0, for example. And Now <b>Final Cut Pro X</b> is available could be Downloaded from the Mac App Store. However <b>Log and Transfer was removed</b> in the X version of Final Cut. So all Pro mts camcorder owners who use Final Cut are looking for <b>HD Camcorder MTS Converter Software</b>. <br /><br />Here is the step-by-step guide to quickly use Final Mate for Mac to <b><a href="http://sony-mts-converter.com/2011/06/import-mts-to-final-cut-pro-x-convert-sony-pj30v-60p-mts-to-h-264-mov-for-editing-in-fcp-x/">Import/Convert Sony PJ30V 1080/60p MTS to H.264 MOV for editing in FCP X</a></b> on Mac. <br /><br />Step 1. <b>Capture native MTS from Sony PJ30V to Aunsoft Final Mate for Mac</b>. <br />Run Aunsoft Final Mate for Mac as the fast <b><a href="http://www.aunsoft.com/final-mate-mac/">Import AVCHD MTS to Final Cut Pro X</a></b> on Mac, and drag the .mts files already backup all mts recordings from Sony PJ30V to your computer, and can browse the .mts video path and the software will automatically show your AVCHD clips in "Resource Tab". <br /><br />Step 2. <b>Create a Movie for combine and convert Sony PJ30V AVCHD MTS 1080p footage</b>. <br />Just select one or multiple video files you would like to convert and then drag and drop them to Movie tab. In this way, a Movie for conversion will be created. <br /> <br />Step3. <b>Convert MTS files to H.264 MOV for Final Cut Pro X</b>. <br />Click the Export button. Follow HD Video &gt; H.264 HD Video (*.mov) to choose output format for editing in Final Cut Pro X. You can then adjust video parameters to keep original video resolution, bitrate, framerate, etc with highest quality. The <b><a href="http://www.aunsoft.com/final-mate-mac/">Mac MTS to Final Cut Pro X Conversion</a></b> will start <b><a href="http://www.aunsoft.com/final-mate-mac/">converting MTS to H.264 MOV</a></b>. <br /> <br />After the conversion, the AVCHD videos could be imported to Final Cut Pro X with 60fps highest quality. Of course, you also can choose <b>Final Cut Pro &gt; Apple ProRes 422 (*.mov)</b> as output format for without rendering. ProRes is advertised codecs to result in less compression and higher data rate/higher quality files for HD editing in Final Cut Pro. <br /><br /><b>Tips:</b> The Final Mate For Mac support camcorder includes but not limited to Panasonic HDC-TM900,TM90,SD90,HDC-TM700/HS700/SD700, SD60/HS60, DMC-GH2,GH1,GF2,ZS7/TZ10; Sony HDR-CX700, CX550, XR550, XR520, CX350, CX305, CX150,CX360, Alpha NEX-5,DSC-HX5V; Canon Vixia HF200, HF S100,HG10,HG20,HF R10,HF R11,HF R100.etc If you want to know more about Camcorder, please visit the <b><a href="http://www.aunsoft.com/camera/sony.html">Camcorder column</a></b> for more information.
on Jun 27, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Tip
Convert Sony HDR-XR550V AVCHD to Apple ProRes for FCP with AVCHD to Prores...
Sony Handycam HDR-XR550V records your memories and snap 12.1-megapixel photos directly to the massive 240GB hard disk drive (HDD). The shooting quality of the HDR-XR550V is impressive and naturally lives up to its flagship status and price. In line with Blu-ray formats in the market, recording is supported up to 24Mbps. High definition videos are recorded at 1920 x 1080 resolutions primarily to the in-built HDD. Picture quality was sharp and crisp, a result which was equally pleasing when viewing on a HD monitor or TV. <br /><br />Many people say Sony HDR-XR550V is the best hard drive camcorder from Sony at the moment and its excellent performance has won hearts of many customers. A lot of our customers use Sony HDR-XR550V for recording family videos, such as holiday vacation at east coast beach, your children?s birthday party or your pet?s playing video. In most cases, they want to do some basic editing and make great home movies to preserve their memories with highest quality. <br /><br />For windows users, it might be not such a problem as bundled software from Sony Picture Motion Browser is capable of basic editing and output videos to BD/DVD or upload to YouTube. But <b>How do you edit AVCHD on Mac OS X</b>? <br /><br />Final Cut Pro 6.0.1 update adds AVCHD transfer capabilities but is everything ok now? <br /><br />Apple's own Final Cut Studio 2 suite had a minor update for Final Cut Pro to version 6.0.1 which added the capability to transfer the AVCHD footage. But is everything really so promising for Mac users? I guess not. We?ve been receiving complaints and problems from our customers about their frustrating experience with AVCHD on final cut pro 6 or 7. <br /><br />Is there a simple and useful tool for Mac users to handle AVCHD for smooth editing in FCP without rendering? <br /><br />Aunsoft Studio nearly released product on Mac OSX <b><a href="http://www.aunsoft.com/final-mate-mac/">Aunsoft Final Mate for Mac</a></b> is specifically designed for camcorder users to easy <b><a href="http://www.aunsoft.com/final-mate-mac/">handle, convert, share, playback AVCHD, TOD & MOD</a></b> high definition videos. <br /><br />In the article, I will take Sony HDR-XR550V as an example to show how to convert AVCHD MTS/M2TS video footage to Apple ProRes for smooth editing in Final Cut Pro 6 & 7. <br /><br />1. Capture/Import Sony XR550V AVCHD files to Aunsoft Final Mate for Mac. <br />There are two ways to import videos to Aunsoft Final Mate for Mac: you can directly capture video recordings from camcorder to the program or you can browser videos from your computer. <br /><br />- Capture Sony XR550V AVCHD videos from camcorder. <br />Connect camcorder to computer via USB cable, and then launch Aunsoft Final Mate for Mac in Application folder. With built-in wizard, you can easily to capture mts video files from XR550V to the program. Select ?Import? instead of Backup to quickly capture videos from camcorder. You can find imported videos under Camcorder tab in the main interface of Final Mate. <br /> <br />- Import Sony XR550V mts videos from computer. <br />If you have already backup all your video recordings from XR550V to your computer, you can browse your video path and the software will automatically show your AVCHD clips in Resource tab. <br /><br />2. Merge Sony DSC-XR550V AVCHD files into one movie for conversion. <br />Click the drop-down button of ?Add Movie? icon and choose ?For Conversion? to create a blank movie. <br /><br />Once you?ve imported your video footage, drag and drop the video clips from Camcorder Tab (imported from your camcorder) or Resource Tab (imported from your computer) to the blank movie in Movies Tab. In this way, all video clips will be merged as one single movie for conversion. <br /><br />3. <b><a href="http://www.aunsoft.com/sony_hdr-xr550v_review_-_convert_avchd_to_apple_prores_for_editing_in_fcp/">Convert Sony XR550V MTS files to ProRes MOV</a></b>. <br />Click the Export button and choose ?Export into Editor?. Follow Final Cut Pro&gt; Apple ProRes 422 HQ (*.mov) to choose export format for further editing in Final Cut Pro. Or you can also choose QuickTime Movie Format &gt; Apple Intermediate Codec (*.mov) for editing in FCE/iMovie. Click OK to start converting XR550V MTS files to ProRes MOV. <br /><br />When the conversion process is done, you can directly import the output ProRes MOV files to FCP for editing without rendering and make your great home movies. <br /><br />The steps above are also applied to other AVCHD camcorders developed by Sony, Panasonic, Canon or JVC brands. <br /><br />Featured product from Aunsoft Studio Aunsoft Final Mate for Mac is the ideal companion for camcorder users who also use Mac machine to easy <b><a href="http://www.aunsoft.com/final-mate-mac/">convert AVCHD to Apple ProRes</a></b> Codec. <br /><br />Tip: You may also be interested in converting <b><a href="http://www.aunsoft.com/mac_convert_sony_hdr-tg5v_avchd_to_apple_intermediate_codec-aic_for_fce-imovie/">AVCHD to Apple Intermediate Codec</a></b> for editing in iMovie or Final Cut Express or <b><a href="http://www.aunsoft.com/mac_merge-join_sony_cx360v_avchd_without_conversion_for_playback_on_dune_hd_player/">merge AVCHD without re-encoding</a></b> to preserve original quality.
on Jun 15, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
LACIE 500 GB HARD DRIVE
i use my external hard disk many times but now when i connect my lacie external H.D to PC it dose not recognized
Jan 30, 2009 | LaCie (300951U) 500 GB Hard Drive
Tip
Put and Play Canon HF S21 HD 1920x1080 AVCHD MTS on iPad Canon Vixia HF S21 is...
Canon Vixia HF S21 is the new AVCHD camera in 2010 for capturing Hi Def 1920x1080. The 64GB internal flash drive enables long time video recording for more than 8 hours with Full HD 1920x1080 recording at FXP profile. It enables double slots for SD memory cards.
The video captured with Canon HF S21 is stored in AVCHD .mts file format with MPEG-4, AVC/H.264 as video codec, and Dolby Digital 2 channel (AC-3) as audio codec. If you get the with optional Canon SM-V1 5.1-Channel Surround Microphone, you can get Dolby Digital 5.1-channel for the audio.
To transfer Canon Vixia HFS21 AVCHD to computer hard drive:
You can use the bundled Pixela ImageMixer 3SE Video Editing Software, and it is easy to transfer Vixia HF S21 AVCHD movies onto computer hard drive with this software. If you are using Mac computer, you can also use iMovie to download videos to Apple hard drive. Just connect the camcorder to iMac/MacBook Pro with Mac OS X like Snow Leopard, and HF S21 could be recognized by iMovie for loading videos.
To put and play Canon HF S21 AVCHD videos on iPad:
Even though iMovie mentioned above could recognize Caonon HF S21 for loading videos, there are also problems for importing Canon HF S21 .mts to Final Cut Pro (FCP) or Final Cut Express (FCE), even iMovie. Aunsoft MTS/M2TS Converter for Mac is the recommended Mac Canon HF S21 MTS to iPad converter for you to easily edit Canon HF S21 videos and transfer edited video to iPad.
Below are the simple steps for transcoding Canon HF S21 to iPad.
Step 1. Load Canon HF S21 video to Aunsoft MTS/M2TS Converter for Mac.
After transferring Canon HF S21 AVCHD videos to Apple hard drive, run Aunsoft MTS/M2TS Converter for Mac as Canon MTS converter and click the "Add" button to load .mts videos.
Step 2. Edit Canon HF S21 MTS videos.
Select the video clip and click the "Edit" button to trim and crop videos, to flip video, adjust brightness and contrast.
Step 3. Choose iPad HD output format.
Click the "Format" option and choose iPad > iPad HD Video(*.mp4), and the Mac Canon MTS to iPad converter will convert AVCHD Hi Def 16x9 to 720p MP4 videos for iPad.
Step 4. Convert Canon HF S21 MTS to iPad.
Click the convert button under the preview window, and the conversion from Canon HF S21 MTS to MP4 for iPad starts immediately.
After the conversion, connect iPad to iMac/MacBook Pro and sync the editing videos to iPad. It is that easy to transferr edited video to iPad. Give it a try and enjoy AVCHD videos on iPad.
on Jul 29, 2010 | Cell Phones
Audio probelms
You can doremisoft man sansa video converter that can cut your noisy part of your videos.
http://www.doremisoft.net/Sansa-Video-Converter-Mac/
Mar 19, 2008 | Formac Studio DV/TVR (FS 1142-48) Video...
Lacie 1TB external hd won't mount!
check wires connecting them together first, ok?
then, turn off the LaCie, connect to your MacPro, and then turn on the drive..
that should show as a mounted drive.
need printer drivers update?
Mar 09, 2008 | LaCie Big Disk Extreme with Triple...
Lacie drive won't mount
I solved the problem. It was a power supply problem. It seems after searching boards on the net, this is a common problem with the lacie hard drives. Just replace the power if your hard drive is clicking and not mounting. I think many people must be throwing the drives away thinking they are lost when it is just the power supply. Try this first before trashing it or spending a lot of money on data recovery programs/
Nov 13, 2007 | LaCie 250GB Ext/Firewire 7200 250 GB Hard...
Open Questions:
LaCie Big Disk External USB 2.0 1TB Hard Drive Logo
266 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
