Question about RCA Televison & Video
I have an RCA converter box hooked up to an RCA TV and a Sanyo VCR. The TV and VCR are set on Channel 3. The converter box is set on Channel 4 and the TV is also switched to CH 4 when viewing digital stations. I can record from the TV to the VCR on analog stations only. When the VCR is on the digital stations don't come in. How do I cync up the VCR to view and record from digital stations? RE: RCA DTA800B1 Box Converter; RCA 1991 Standard TV; and Sanyo VCR Model VMM-710
    Problem Solver:
  • 12 Answers
Basically, you cannot use the coax connections for both the VCR and the RCA converter box. I would hook up the phono/cinch connectors from the VCR to the TV if you can (these are also called RCA connectors, but I'm avoiding using that name so we dont confuse the digital receiver with a cable/connector name that is the same here). There should be a yellow one for video and red/white ones for left and right stereo. I believe the RCA converter comes with a three headed cable that can do this for you. With this configuration, you can set the TV to input on these connectors and the VCR should always output there. Once that is set, you can still use the converter box to receive the signal from your antenna, then run the coax to the VCR. Now, the VCR will always have to be set on channel 4 in your setup and you will need to manually change channels on the converter box for it to record a show. Does this make sense so far?
Posted on Feb 27, 2009
Hooking up old Sanyo box tv with old magnavox vcr
You need a TV cable though ANY cable might work. But definitively the only way to connect a VCR co a TV is through the antena setting TV to channel 3 or 4.
Even if you can't see it, all old TV sets must have an antena input.
If you can't find it, call a TV repairman, should help to make a connection.
Jul 03, 2016 | Sanyo Televison & Video
How Can you record tv show using a converter box
Hook the converter box cables to the input RCA jacks on the back of the VCR, then hook the output RCA jacks to the input RCA jacks to the TV, Keep the VCR on channel 3 or 4, on the TV in menu scroll through the source settings to find the what source the vcr is using
May 05, 2014 | GE Vg4261 Vhs Tape Vcr Plus 4 Head Hq...
Hook up analog vcr to hd tv
You must have a converter box for the tv and for the vcr. Set the vcr to receive chanel 3 and set the converter box to the digital chanel you want to record. Put a splitter on the antenae out and route one to the tv converter box and one to the vcr converter box. GOOD TO GO.
Apr 11, 2009 | Sanyo Televison & Video
I have an old sanyo vwm 710 vcr. I have a new hdtv. I can play tapes on the tv if I change the input on the tv. I have selected line 1 on the vcr, but cannot get any channels to come on to record. The...
Not really a solution....RCA customer services (from India, I think), says that there is no way with that VCR because both the front and back (red, yellow,white) ports are input, and the only other jack on the tv is the one for the antenna. Since the digital converter is inside the tv, a splitter would do no good.
I would still have to get either a new VCR with the digital converter in it or get another converter box. An atmosphere of bait and switch is covering this hdtv scheme....
Feb 19, 2009 | Sanyo DVW-6100 DVD Player/VCR
Want to continue to record on my VCR after digital hookup
You have to use the RCA plugs on the back of the converter box and the tv (red,yellow and white). Or you can attach the antenna wire to box and then attach the wire that comes with the converter that is listed as to the tv and instead attach it to the antenna in on the vcr. The converter box will determine which channel your vcr will get a singal to record from. Your VCR for every program will be set to channel 3 or 4 (depending on what your converter box is set to broadcast on). Make sure the power saver on the converter box is turned off as if you want to record a program in say 4 hours, if the converter box turns off in 2, your vcr will have nothing to record.
I ran seperate coaxible cable to the tv from vcr and unplug the tv converter box everytime I want to watch the vcr. You can also use the RCA cord to send the signal from the vcr to the tv and use the input signal to watch your recorded programs. I had static showing up everytime I played it through the second converter box thus I solved it by running a seperate coax line. I don't know if you will have this problem, just wanted you to be aware.
Jan 12, 2009 | Insignia Digital-to-Analog Converter for...
How do I connect an analog VCR + converter box to a digital TV?
first of all does your television and/or vcr have a cable connector and/or a set of rca outlets? if they have a cable connection in the back all you have to do is hook the cable from the antenna to the "in from antenna" on your cable box and then connect a cable from "out to tv" to "in from antenna" on the vcr and a cable from "out to tv" on the vcr to "in from antenna" on the tv. then you need to make sure on the converter box and the vcr and look for a channel selector and see what channel they are on. most vcr's have a selector for either channel 3 or 4, look at what channel it is set to and if your converter box has the same thing then match it with the vcr. then tune your tv to that channel and you should be able to work your vcr as long as the vcr/tv button shows that you are on the vcr. now if your tv and/or vcr have rca outlets and your converter box has the same then just hook the cable from the antenna to the cable box and substitute the rca cable for the regular cable and tune your tv to video or line input.
Jan 01, 2009 | Televison & Video
Connect tv vcr and dvd player to digital converter box
Yes you can first connect the converter box to the antenna first. Next hook the tv out on converter box to vcr in on vcr. Next hook the vcr out to the tv in and watch vcr and converter box on channel 3 sometimes channel 4.on the actual tv and of course change channels with converter box remote. For dvd player hook it straight to tv with red,white,and yellow cables that come with your dvd player. Then to watch dvd player if it's hooked up that way you have to put your tv on a input like video 1 or input 1. This can be done by using the tv remote and looking for a button that says tv/video or input or source button. This is some common names for that button on tv remotes.
Nov 02, 2008 | Insignia Digital-to-Analog Converter for...
Convertor box and Sony Wega with PIP (2 Tuners) and new Digital DVR/VCR
I wonder if the RF interference from the digital tuner. That box will only allow ouput either through the coax or the AV ports. If you do both you will not get a picture.
If you switch them you have to tell the box what your using for output by going through the setup process.
Is the Zenith 901 converter box for your cable TV.
Aug 17, 2008 | Insignia Digital-to-Analog Converter for...
How to connect my dvd & vcr with the converter box
Here is my setup.
1) Separate DVD player 2) Separate VCR 3) Digital to Analog Converter box 4) Analog TV 5) Rabbit ears (UHF/VHF) antenna
The antenna goes into the converter box.   The RF-output of the converter goes into the RF-Input of the VCR The DVD output goes into the front input jacks of the VCR The VCR RF-output goes into the TV RF-Input The VCR Line output goes into the front of the TV
To watch DVDs, we turn on the DVD player, turn on the VCR, and set the VCR channel to L2, and tune the TV to channel 3.  The converter is off.
To auto record on the VCR, the converter must be tuned to the station being recorded.  The converted must be turned on, the TV can be off.
To watch VCR tapes, turn the TV and VCR on.  The TV is set to channel 3.  Just press play on the VCR.
To Watch TV.   Turn the TV and converter on.  The TV is set to channel 3.   Change the stations using the converter.
May 06, 2008 | Insignia Digital-to-Analog Converter for...
Televison & Video Logo
520 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
