Question about Lanier 5222/27 Laser Printer
I need a nic for a lanier 5222
Pcl5e
  • Don Ford Apr 10, 2009
    I'm also looking for a network card for this printer/copier.
  • Lanier Expert
  • 393 Answers
WE can get you a Nic card but they are not free. (quennie@wcvt.com)
--Carl, let me know if this helps.
Posted on Jun 27, 2009
Problem on RADF misfeed but no misfeed at all. what should I do
please clean the sensors located in the RADF and power the machine and the problem is over
Mar 13, 2014 | Lanier 5222/27 Laser Printer
Blank streaks
Hi
You need to replace drum
or try cleanning it with a soft paper towel
Pls vote us to keep us alive
Nov 16, 2010 | Lanier 5222/27 Laser Printer
Lanier 5635 error code displaying a SC320
sc320 on the Lanier 5635 is a laser unit error code. Often if you power cycle the machine (turn it off with the orange power switch on the left side of the copier, wait a few seconds, then turn it back on) the code will clear and the copier will resume normal operation. If the error code comes back or doesn't clear, you'll probably need to replace either the entire laser assembly or the polygon mirror motor inside the laser unit. These are best done by a professional -- contact your local Lanier service company if the problem persists.
Oct 15, 2010 | Lanier 5222/27 Laser Printer
My lanier is making dark copies
One of the most common reasons for a Lanier 5222 or 5227 to make dark copies is a problem with the drum unit or developer. Fortunately on those machines, the drum unit and developer are all self-contained in one easily-replacable unit, called the PCU (photoconductor).
If you don't have a new PCU handy, you can order one from the same company you get your toner from. The PCU should generally be replaced every 60,000 copies, but sometimes it may need to be replaced sooner (especially if you run a lot of dark copies or make a lot of copies of images) and it can often run longer than 60,000.
Replacing the PCU is easy -- it sits right next to the toner bottle, and all you have to do is slide the old PCU out and slide the new PCU in (once you remove all of the tape and other trappings from it). Instructions will be included in the box with the new PCU.
Please rate the effectiveness of this solution. Thank you!
Oct 10, 2010 | Lanier 5222/27 Laser Printer
Scan routing
http://www.lanier.com/downloads/driverFrame.aspx?path=http://support.aficio.com/bb/html/dr_ut_e/lan_u/model/x22_27/x22_27en.htm
Go to the above site and download your software and a manual, the manual tells you exactly how and what to do.
May 21, 2010 | Lanier 5222/27 Laser Printer
Lanier 5527 that is displaying SC541
This is a fuser error, you will need a service call.
Feb 01, 2010 | Lanier 5222/27 Laser Printer
Modle 5222, scanner error?? any suggestions?
sure you lamp lights up when machine is powered on. open the top cover, turn power on. lamp should light and scanner should move. if either of these do not happen you will need to replace parts. if the lamp lights and the scanner moves your ccd could be bad. you may need a service tech. if the lamp does not light it is your problem. lamp, power supply, ballest, or main pcb could be the problem
Oct 21, 2009 | Lanier 1205 Copier
Error code SC302
From the Ricoh-Lanier Error Code Sheet:
SC302: Charge Corona Output Error 3 - Grid Voltage error - Charger Roller Current Leak.
I would suggest replacing first the charge roller and if that doesnt fix it, the HIgh Voltage Supply Board.
Mar 19, 2009 | Lanier 5222/27 Laser Printer
Misfed jams
First off, does the wheel indicate the proper size paper. Be sure to place close attention to the icon. Second, when you slide the drawer out, in the middle of the right edge, there is a spring loaded pad. Carefully peel the cork off, and rotate it 180 degrees, or you could switch it with the other drawer. Other than that, there might be a small wedge of paper in the lower switch, located in the middle of the paper path, between the paper guides. It may be next to impossible to see unless it is taken apart.
Feb 21, 2008 | Lanier 5222/27 Laser Printer
Unable to print more than 3 copies of anything
What error if any do you get? Sounds like your printer needs a firmware update.
Carl ( Lanier tech )
Oct 24, 2006 | Lanier 5222/27 Laser Printer
161 people viewed this question
Top Lanier Office Equipment & Supplies Experts
Adorjani Laszlo
Anthony Karuku
George Mclaughlin
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
