Question about CDV Software Cossacks 2: Napoleonic Wars for Windows
Internal problem with cossacks 2
I installed cossacks 2 napoleonic war and after the installation and reboot and everything i went to play the game and it came up saying error: 3.4.65.11; 300D; DrvOpen failed, LE: 1275
please can u help me it would be greatl appreciated..
Thank you..
4 Suggested Answers
  • 7 Answers
SOURCE: how to run Cossacks 2 on windows 7
Try registering for free at this website http://cossacksworld.ucoz.co.uk/ and click on their downloads folder to see if they have a patch or a workaround for this issue.
Posted on Jul 21, 2010
nonontech
  • 4737 Answers
SOURCE: i have windows 7 installed on my pc.i installed
Well, try this, we call this "compatibility" mode, most programs can be run on windows 7 with this trick.
I assume your Cossacks II Napoleonic Wars icon is on the Desktop,
Right-click the Icon (game's icon), select "Properties" and click "Compatibility" tab, select "Run this program in compatibility mode for" click the "Windows 95..." and select "Windows Xp (Service pack 2)", click "Apply" > "Ok" and try again.
If even after doing this, the game can't be played, then there's no option. The fact is that, this game is made to run on system with Windows xp and earlier version, but somehow if fortunate, it's possible, not will all software, some may work, some may not.
Good luck.
Thanks for using FixYa.
Posted on Aug 12, 2010
SOURCE: Cossacks European Wars on Windows 7
just installed cossacks ew and changed video file name as suggested and it worked the problem i have now is the graphics have a yellow,red and blue dotty shaddow where there shud b a solid black shaddow, game is playable but its just very annoying!!! pls help im running windows 7 btw
Posted on Aug 19, 2011
  • 5 Answers
SOURCE: i can't not play cossacks
The Game doesn't play because of totally different work environments than it has been designed to. Here are some solutions:
1. Rename Video folder in the game.
2. Right click on the program. Then navigate to compatibility, then select the compatibility operating system the game is supposed to be played under. Also, after you select xp sp2 and check the box that says "run as administrator".
3. Download this patch from:
http://www.downloadsource.net/v/11290/
Posted on Dec 08, 2012
Unable to play cossacks european wars 2001 , microsoft dmcr.exe
I have installed cossacks game .but it is asking when i click to play that "game cannot run without the game cd "
Apr 09, 2011 | CDV Software Cossacks Anthology for...
I've installed Cossacks(the Art of War) in Windows 7 Professional. HP-Pavilion Slimline s5710F.The game come up with double vision still can't play,everythink runs together.
I think there is a form of copy protection that installs a driver onto your computer. It was originally designed to be used on Windows XP only. In order to fix this issue, you'll need to contact the game developer for an update or patch that allows you to install the game. There is no other work-around for this, because Starforce contains a driver that Vista will not accept because it is built for another operating system. Starforce protected games are well known to be one of very few XP titles that will not work on Vista without an update or patch, due to its design.
    You can give this a go too... http://m0001.gamecopyworld.com/games/pc_cossacks.shtml
    Mar 19, 2011 | Strategy First Cossacks: European Wars for...
    I've install Cossacks (the Art of War) in Windows 7 Professional. HP Pavilion Slimline s5710F. the game come up with double vision,still you can't play with everythink running together.
      I've installed Cossacks European Wars onto my laptop which has Windows 7. However, when I try to run the game I get a dmcr.exe error. I've looked at solutions online which told me to change 'Video' to...
      1- download a direcx and install it (i put a link for you)
      http://www.softwarepatch.com/windows/directx.html
      if it doesn't work:
      1- go to control panel from start menu.
      2- select windows update.
      3- select check for updates.
      Jan 10, 2011 | Strategy First Cossacks: European Wars for...
      Crossfire game hack speed i cant see................................ LOLZ
      If you want to be able to see, you are going to have to get rid of the crossfire game hack, that is the only thing that would be messing up your UI and screen inside the game. You could either uninstall and reinstall the entire game altogether, or you can simply delete the hack out of the installation directory (if you remember where you installed all of the files, that is).
      Please give me a thumbs up if this helped you! I get cookies if you do! :)
      Jan 07, 2011 | CDV Software Cossacks 2: Napoleonic Wars...
      I can't not play cossacks 2 napoleonic wars in windows 7 you have any solution?
      Nov 02, 2010 | CDV Software Cossacks 2: Napoleonic Wars...
      I have windows 7 installed on my pc.i installed cossacks II napoleonic wars properly,and when i try to start the game,i get information that the game can run only on older versions on windows (95,98 XP )....
      Good luck.
      Aug 12, 2010 | CDV Software Cossacks 2: Napoleonic Wars...
      yo change folder name Video -> video1. You will succeed. :D
      Jan 23, 2010 | Strategy First Cossacks: European Wars for...
      CDV Software Cossacks 2: Napoleonic Wars for Windows Logo
      946 people viewed this question
      Top CDV Software Video Game Consoles & Games Experts
      Steve Mason
      EnergeeUK
      Level 1 Expert
      Bill Boyd
      Are you a CDV Software Video Game Console and Game Expert? Answer questions, earn points and help others
