Question about Makita 2 Bl1830 18v Battery,dc18ra Charger Lxt Fr Drill
The charging light flashes alternately in green and red color, charging is not possible.
  • 285 Answers
You have defective batteries. Either they are old and used and can no longer take a charge and should be replaced, or they have a problem not allowing them to be charged.
If batteries are new, seek replacements. If old, time to buy new batteries.
If this happens with several batteries, and even new ones, your charger my be faulty.
Posted on Mar 01, 2009
M28 battery is flashing green and red when put on v28 milwaukee charger
Is the battery hot or cold??? either temp. extreme will do that...
otherwise the battery is shorted internally and so the charger will not charge it...the battery will need to be replaced.
heatman101
May 21, 2011 | Milwaukee Tool Milwaukee V28 1/2" Hammer -...
It wont charge it blinks three times then stops
Hi,Okay, well, I don't want to be a shill for Apple (I mean, heck, I had to buy my Shuffle, so it's not like they're sponsoring this in any way! :-) so let's talk about the color sequences and what they mean.
First off, there are a number of different functions that are denoted by different color sequences, so flashing green might mean one thing when you're listening to music, and something else entirely when it's plugged in and charging or syncing with your PC.
The primary functions are powering on, charging, syncing, and general feedback. Let's look at each.
When you turn on your ipod shuffle, the light will indicate your current charge level:
green = 30-100% charge, you're good to cruise
orange = 10-30% charge, low, but still good for a short workout
red = less than 10% charge, time to plug it in
no light = too late, you've run out of juice
If you see an alternating pattern of green-orange-orange then your Shuffle's crashed or otherwise needs to be restored. Needless to say, that's not a good thing, but probably easy to fix when you hook it up to your PC or Mac.
When you're charging up your shuffle, there are three possible light states:
orange = charging
green = fully charged, unplug whenever you're ready to go
flashing orange = busy, either syncing or in use as a remote disk
When you're playing some music, you can see visual feedback on what's happening and what state you're in:
Press play and
solid green = you're playing music
flashing green = you're in pause mode
Press and hold play and
green-orange-orange-orange = you've disabled your buttons
orange-green-green-green = you've reenabled your buttons
That's bound to be one where people panic and fear that they've broken their shuffles, I bet. If your buttons aren't working at all on your Apple iPod Shuffle 2nd Gen, then press and hold your Play button to see what light sequence you're given. This is also shown by the Shuffle flashing orange when you push a button too.
If your player flashes alternating green and orange, you have no music in the shuffle. This can be because it's fresh out of the box, or because, well, something's happened and the music has vanished. Either way, time to sync with your iTunes library.
If you're seeing a flashing red sequence, you're just about out of battery and just need to plug it in so it can charge up.
Finally, Apple has some good tech notes on the new Shuffle too that you might want to check out if you're still a bit baffled by this tiny engineering wonder: Understanding status light behavior, Shuffle Second Gen, Frequently Asked Questions and iPod Shuffle Support Overview.
Feb 17, 2011 | Apple iPod shuffle Second Gen. Silver (1...
My glowbouy flashes green and red...what does this mean
According to the owners manual for these swimming pool lights, this is what each colored indicator means. Hope this helps.
Solid green
The battery pack is fully charged.
Slow flashing green
The battery pack is almost fully charged.
Slow flashing yellow
The battery pack is half charged.
Medium flashing yellow
The battery pack is less than half charged.
Fast flashing yellow
The battery pack has almost no charge.
Fast flashing red
A charging error has occurred and the light should be unplugged and then plugged back in. If the Fast Flashing Red persists after several attempts, the battery condition is questionable.
Also in the trouble shooting guide, it mentions this:
Problem: Red Indicator Light Is Flashing While Charging
Solution:
A red flashing indicator light when charging indicates a selftest
error condition. Unplug the product and plug it in again.
Try this several times; if the indicator light continues to flash
red, unplug the GlowBuoy and take it to an authorized service
depot.
Oct 22, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
Continuous alternating one green and three flashing red battery
note.gif NOTE: Battery operating time (the time the battery can hold a charge) decreases over time. Depending on how often the battery is used and the conditions under which it is used, you may need to purchase a new battery during the life of your computer. Check the battery status light — If the battery status light flashes orange or is a steady orange the battery charge is low or depleted. Connect the computer to an electrical outlet.
If the battery status light flashes green and orange, the battery is too hot to charge. Shut down the computer, disconnect the computer from the electrical outlet, and then let the battery and computer cool to room temperature.
If the battery status light rapidly flashes orange, the battery may be defective. Contact Dell _I found this on : http://support.dell.com/support/edocs/systems/latd820/en/ug/index.htm Hope this helps and good luck. if i "fixed ya" please rate me. thanks-jmattes
Oct 22, 2009 | Dell Latitude D820 Notebook
When connecting up to charge red light comes on 'power on' button on front and no charging happens - any ideas? thanks
What does indicator light mean?
  • Steady red light: Battery is charging.
  • Steady green light: Battery is fully charged.
  • Flashing red light: Battery needs charging.
  • Flashing green light: The music receiver is switched on.
  • Flashing red/green light: The music receiver is available to be added to your phone.
Aug 24, 2009 | Sony Ericsson T303 Mobile Phone (Shadow...
Lights on printer are alternating between red and green flash
try to reset the printer by opeing the front cover and close it again.
Mar 17, 2009 | Samsung ML-2510 Laser Printer
Flashing device status light
Ok the lightning bolt is your power indicator: solid green-charging, Flashing green-fully charged, flashing red-low battery, flashing red three times the once green-bad battery. the "trash can" looking one is your hard drive activity indicator it will flash while your hard drive is reading and writing.
Nov 20, 2008 | Dell Latitude D600 Notebook
No 'green' light on bacl of my 'old' Vivitar 285
Then I'd say it's a reasonably sure thing that the green light is just burned out, The lights are supposed to be off at first, then red when there's a partial charge, then green when there's a full charge, then flashing between red and green when the "battery saver" kicks in. If you're seeing off, then red, then off, then flashing red, then that means everything in the charging circuit is working perfectly, there's just no green light.
Nov 30, 2007 | Vivitar 285HV Flash
Makita 2 Bl1830 18v Battery,dc18ra Charger Lxt Fr Drill Logo
584 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
