Question about Meade LX200GPS Telescope
Meade LX200GPS 8" won't initialize on power up.
My LX200GPS will now power up correctly. When I connect the AutoStar hand controller then power up the scope, one of 2 things will happen: the top row on the AS display turns to white boxes, almost like a progress bar) from left to right. When the line is full, everything just stops. The other thing that sometimes happens is the display just stays blank. The scope never moves. None of the buttons on the hand controller do anything. I tried connecting to an XP laptop via the serial cable adapter that came with my LPI and the left RS232 port, and the autostar software doesn't see the it.
  • dizdale May 14, 2009
    I have the same problem.
    Has anyone have any answers?
    My controller llocks up as well
  • 3,185 Answers
Try doing either a garbage collect or a safe load-- and then reinstall the hand controller firmware--
Instructions-- depending on the type of controller
Autostar 495 or 497: You enter Safe Mode by holding the [enter] and
[scroll down] keys pressed when you power up the telescope. The
Autostar will say "Flash Load Ready"... now go start the ASU.
Autostar II: if you need to use Safe Mode to recover from a disaster,
turn on the telescope, and key 999 before it says "Initializing"
The Autostar will say "Flash Load Ready"... now go start the ASU.
LX200gps: BEFORE proceeding further, click on the OPTIONS item on the Top Bar.
Now click on "Garbage Collect Hbx" ... this will perform data cleanup
within the Autostar which will avoid potential mess-ups.
Posted on Mar 16, 2009
Can you tell me the communication setup for the xl200GPS MEADE 8 inch telescope. Like the comm Port number along with the other settings. Thank You.
If you mean the LX200GPS from Meade, http://www.meade.com/manuals/505ccs/index.html#tc gives the following settings for the AutoStar RS-232 Serial Com Port:
Baud Rate: 9600
Data Bits: 8
Parity: None
Stop Bit: 1
Flow Control: None
http://www.meade.com/manuals/autostar/apb.html has the pin assignments for the 4-pin and 6-pin adapters that connect to the RS232 cable.
Most versions of Windows from WIn95 on will automatically assign the serial port an unused IRQ port if you add a add-on card to a PCI or PCIe slot. (USB to serial port adapters should be able to do something similar with the above data.)
I hope this helps.
Sep 12, 2013 | Optics
I have an older, let's say "classic" LX-90. My
You can try Three things:
1. Do you have fully charged batteries-- or a good power supply.
2. Sometimes the cable to the hand controller needs to be replaced
3. Execute a RESET on the hand controller and reload the firmware--
If these do not fix it, the hand controller is defective and must be replaced. You can find a used 497 controller for about $80 on AstroMart.com
and Meade can also sell you a new one.
Mar 07, 2011 | Meade LX90 8 (500 x 203mm) Telescope
I am using an LX 200 GPS gimbal with no autostar control hand box. I want to be able to talk to it using my Autostar Suite and a computer. I have the USB to RS 232 cable and the connector to go from the...
1. Plug the cable into the BOTTOM of the hand controller-- NOT into the control panel.
2. Set the software to the proper COM port. Look under Telescope in the dropdown tab.
Feb 18, 2011 | Meade LX200GPS Telescope
I have a broken autostar 2 telescope controller and need a replacement but can not find one in the UK
Many Meade dealers can order you a new hand controller, either Autostar II, or the 497 controller. Contact a large telescope dealer in the UK, or you can order direct from Meade here:
http://www.meade.com/support/index.html
Oct 24, 2010 | Meade LX200GPS Telescope
My telescope/autostar not working ,will only display startup info on handbox ,then nothing happens !.
This is sometimes caused by a bad hand controller cable and or corrupted firmware in the hand controller.
Get a new cable first and try it-- if this does does work then RESET the hand controller and reload the firmware using the proper computer cable and Autostar Updater Version 5.9 available here:
http://www.meade.com/support/auto.html
http://www.meade.com/support/Win7_ASU592_Installation.pdf
Aug 31, 2010 | Meade LX200GPS Telescope
Re LX2000 GPS version 1.2b. when switched on I get the usual start menu fron Autostar 11 but it will no progress from there!
Do a re-load of the firmware in the hand controller, also replace the hand controller cable.
Aug 08, 2010 | Meade LX200GPS Telescope
Lz200gps doesn't boot and I can't communicate via com1
Before you panic, try a new hand controller cable. You can buy these from Meade or for a better one from www.scopestuff.com
"Autostar II: if you need to use Safe Mode to recover from a disaster,
Read this page all the way through--
http://www.weasner.com/etx/autostar/guide-asu3x.html
Jun 02, 2010 | Meade LX200GPS Telescope
Autostar when energy is on only shows the lx200 gps sign but does not initialize
Do a RESET on the hand controller. Then Train Drives. Make sure TIME and DATE are correct, and Daylight Savings is YES
Aug 09, 2009 | Meade LX200GPS Telescope
Autostar 497 freezes
When warm and indoors (!) connect Autostar to scope and by serial lead to a PC, allow Meade Autostar suite to update the Autostar Firmware to the latest version (2009!!)
Frome www.meade.com/support/auto.html :
How To Upgrade Your Handbox
To upgrade your Autostar first click on the link below to download the Autostar Update (ASU) Client Application for Windows. If your web browser allows you to open the installation file, you may choose that option when prompted. Otherwise, just save the install file to your local hard disk drive. When downloading is complete, double click on the saved file to start the installation. Follow the instructions provided to install Autostar Update (ASU) on your machine. When installation is complete, start ASU by selecting "Start Menu" -> "Programs" -> "Meade Inst" -> "ASU". If you have an active Internet connection and your telescope with Autostar is connected using the appropriate cable as listed above, ASU will detect and install the correct Autostar code directly from Meade's web site via the "Upgrade Autostar Software Now" button.
Autostar Update
Autostar Update is an application that functions to transfer the event files and software updates from your computer, through the serial port, USB or Connector Cable Set depending on your telescope model. The Autostar Update application is available as a stand-alone client application for Windows. The most recent versions of AutoStar Update automatically check for the newest versions of the AutoStar Updater and download it if necessary. It is critical that you use the most recent AutoStar Updater to ensure that you get the proper software updates for your system.
06/02/09 Autostar Update (ASU) Client Application for Windows, Version 5.6 (1,654 KB). This is the latest Autostar Update. Rev. 5.6 is compatible with the ETX-LS and #497EP Hand Controllers. This version is compatible with all versions of AutoStar II and #497 AutoStar computer controllers. This installation will automatically update the Update Client Application in AutoStar Suite™ Software. If you have previously installed the Autostar Update (ASU) Client Application for Windows, Uninstall the old version before installing this new version. 07/27/09 #497 AutoStar hand controller software update. Version 5BE2 (1,039 KB).
General update. Fixes many known bugs. Real time clock corrections. LXD75 polar alignment. Various LX90 pointing and tracking fixes. Adds new magnetic/true north alignment.
REQUIRES VERSION 5.6 AUTOSTAR UPDATER.
Jan 17, 2008 | Meade Autostar Suite Autostar Suite...
Can't upload data from computer
Check and define/ assign your com ports thru autostar and consistantly use the same port everytime you connect.
Also some usb to serial adapters are unsuitable ; dont ask me why but some work with autostar and some just dont, belkin adapters almost never work but the keyspan brand works reliably. I had the same problem and the kspan adapter plus comport set up sorted it.
Hope this helps
Aug 31, 2007 | Meade LX200GPS Telescope
Meade LX200GPS Telescope Logo
838 people viewed this question
Top Meade Optics Experts
Greg Cann
Greg Cann
Jerry Greenberg
Jerry Greenberg
Eric Hidle
Level 1 Expert
Are you a Meade Optic Expert? Answer questions, earn points and help others
