Question about Jenn-Air 30 in. CCE3401 Electric Cooktop
Jennair ceran top problem
Good day,
I have a Jennair downdraft range with 4 burner ceran top. Several weeks ago, on one side of the top both burners would stay on regardless of temperature setting. This morning, the other side is doing the same. Turn them on Lo, they stay on full blast. Help me please!! I have 11 year old Jennair ceran and upper left knob does not work properly. Burner would stays on even if the knob is at off position.
  • 150 Answers
SOURCE: Burner knob wont turn
appliance repair and yes you can fix it you likely need an infinite switch
Posted on Apr 23, 2008
SOURCE: Downdraft Slide-In Range
I have the radiant cooktop (i.e., glass top) version of this range. I've had this same problem since I first purchased this unit. I wondered why no one answered this question, as I check back to see from time to time. I finally contacted Jenn-Air's online support. My conversation was as follows (I'm not entirely sure that the tech support knew what she was talking about, but here you go anyway):
message.gif?p_db_name=whirlpool Cidalia C: Hi, my name is Cidalia C. How may I help you?
message.gif?p_db_name=whirlpool You: Hello!
message.gif?p_db_name=whirlpool You: I have a question regarding my "Downdraft Radiant Cooktop"
message.gif?p_db_name=whirlpool Cidalia C: Thank you for contacting Jenn-Air today with your inquiry. What is your question please?
message.gif?p_db_name=whirlpool You: None of my burners can simmer-- no matter what the setting, they will boil water!
message.gif?p_db_name=whirlpool You: Is there an adjustment that can be made to attenuate the heat?
message.gif?p_db_name=whirlpool Cidalia C: What is the model number of your cook top please
message.gif?p_db_name=whirlpool You: JED8430ADB
message.gif?p_db_name=whirlpool Cidalia C: Thank you. In looking at your burner configuration, the smallest wattage on your unit is 1200. And, unfortunately, there is no way to get a small wattage for your burners. We apologize for the inconvenience.
message.gif?p_db_name=whirlpool You: Yes, but the dials are supposed to prevent the full 1200 watts from reaching the burner unless it's on maximum heat, correct?
message.gif?p_db_name=whirlpool Cidalia C: Yes, but the burners do not get low enough to be considered simmer burners.
message.gif?p_db_name=whirlpool Cidalia C: Did you have any other questions or concerns today?
message.gif?p_db_name=whirlpool You: I suppose not.
message.gif?p_db_name=whirlpool Cidalia C: Thank you for contacting Jenn-Air. Have a good day!
Posted on Jul 29, 2008
aborcass
  • 2651 Answers
SOURCE: Burner temperature is always on high heat even at low setting
not related any further then sounds as if you have 2 burner switches gone bad,and actually the front right burner is controlled by a electronic control circuit board part retails for about $160-$200 part number 12002723, and left rear switch about $30 part number 74007841 . uint needs to be uninstalled from counter and parts changed by removing the bottom panel
Posted on Nov 04, 2008
jtbjtb
  • 135 Answers
SOURCE: Jenn-Air electric burner goes to full no matter what the setting
This would be a faulty switch. Hope this helps!
Posted on Feb 17, 2009
  • 222 Answers
SOURCE: problem w/ plastic knobs on JennAir electric downdraft cooktop
NO METAL KNOB FOR THAT MODEL COZ IF USE METAL EVERY TIME U USE IS HOT THATS WHY DESIGN FOR PLASTIC,MUCH BETTER TO U REMOVE THE KNOBS AFTER U TUNN ON THE HOBS TO LESS MELT THEN RETURN IT IF U TUNR IT OR ADJUST.
Posted on May 29, 2009
Where can I buy the stovetop burner gaskets?
  1. Gaggenau Range/Stove/Oven Parts - RepairClinic.com
    www.repairclinic.com/Shop-For.../Gaggenau-Range-Stove-Oven-Parts Huge selection of Gaggenau Range/Stove/Oven parts in stock. Same day shipping. Open 7 days a week. ... Door hinge, top/bottom. OEM Part - Manufacturer # ...
Jul 11, 2015 | Gaggenau Cooktops
Large electric burner will not turn on
you need to check the wiring to that burner it appears that there has been a short to the burner
Apr 04, 2010 | Jenn-Air 35 in. JEC9536ADS Electric...
Should I buy a two burner unit if available? Or a new cooktop?
Yes you can as long as there ae two heat controls for the grill side of the stove/cooktop. That allows one burner control for each of the burners. You should be able to order directly from GE but I would also check out repairclinic.com since they normally sell OEM GE parts cheaper than you can buy them from GE. At least check out the price at both sources beforw purchasing.
Dec 29, 2009 | Cooktops
How do i replace my burner on my jenn air ceramic cook top . it has the down draft feature in the centre
1) turn off power at the breaker. 2) remove hold down screws 3) pop up cooktop out of counter top 4) remove knobs and downdraft grille 5) remove ceramic top (screws around outside and also in side grille opening) 6) unplug burners replace with new burner
Sep 17, 2009 | Jenn-Air JED8430 Electric Cooktop
Broke glass on electric genn-air
Please do not use the stove if the element is viable because of broken glass, this could become a danger to yourself.
Look at the cost of a new stove, you should be able to get one for
around 400.00. One of my customers had a glass top with 4 burners,
they had the same thing happen, the cost to replace the top was
1,200.00. So I would assume that you can get a new stove with 4
burners less then it would cost to replace the part on a stove you don't like. Maybe there is a LOWES around you to look at stoves,
they seem to be everywhere,like death and taxes.
As for putting a 4 burner top on a stove that has 2 with grill, I don't think it can be done without the extra cost of adding the parts to run the other 2 burners, so like I said in the long run,it just might be cheaper to but a new stove. It should not be a big deal to remove the exhaust from the grill part of the stove.
I looked at the model# you put down,and it does not have a grill,
from what I see, there are 4 burners and a downdraft vent in between the 4 burners, there are 6 models with this part # and none have a grill,only the downdraft vent.
If the model# is right, the cost would be around 300.00 for the glass, and then the cost of having it replaced. So I would say over
400.00, In which case for the same amount you could have a new one, but you must weigh the difference for yourself and see what you think is the best way to go.
If you have any more questions,please post back and everyone is more than willing to help you. I hope I have helped a little.
Mar 24, 2009 | Jenn-Air JED8430 Electric Cooktop
Jul 08, 2008 | Jenn-Air JED8430 Electric Cooktop
Apr 17, 2008 | Cooktops
Ceran stock top chipped and cracked
most of thoose ceran tops have a five year parts only warrenty read your owners under 2-5 years warrenty if it does call ge cust assistance to see what you can do
Jan 20, 2008 | GE 30 in. JGP328 Gas Cooktop
Whirlpool Oven, Ceran stove top
I want to say that since I posted my original problem with black spots appearing on the Schott Ceran top, I took pictures of the top and attached them to a complaint sent to Maytag. Approximately 3 days later, a Maytag representative phoned and offered a brand new top-basically stating that there is a fault with the tops. They would not pay for the labor to replace the top. My husband downloaded the instructions from Maytag website and installed it himself. These spots actually appear from within the surface and are not the result of a boil over, etc. The spots on my burner grew to the width of the burner. If you search the internet, you will see many others with the same problem with the Schott Ceran tops. I will never buy another!
Nov 20, 2007 | Cooktops
Jenn-Air 30 in. CCE3401 Electric Cooktop Logo
429 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
