Question about ATI RADEON X1650 Xt, (256 MB) Graphic Card
Radeon x1650 512mb AGP video card causes a green flash when
Switching on and off programs that use Directdraw I believe. I know it's something with Directx, opengl programs don't do this to me. Besides that games run fine. I was curious if this could be a hardware fault, using updated drivers. This card causes my old PSU to blow (my fault I was using a bare bones wattage) and i've taken it out of my pc about a week after replaying my PSU, too nervous to use it now. Is it safe? I got a power supply that exceeds recommended wattage now. (The problem persisted before and after psu blew)
  • 1,602 Answers
Lets do some basic brainstorming together.
anytime you add additional componets to your motherboard, heating is a big issue and may cause over heating of the mb, hd, ram, video.
you will need additional power or wattage out put to support additional cards, fans,
additonal with the heat needs more air flow in the system, if you do not put more cooling devices in the computer to help it stay cool you may end up buying additional parts like mb, ram, hd, because the 1 fan in the power supply doesnt have enought power to cool the system down and than they get hot and they stop functioning right, freeze ups,
shut downs, power outages and so on.
there is a web site you should look at just as a peace of mind
www.acousticpc.com
they have lots of information on cooling systems and documents to help you with this issues
i hope i helped you
rod
Posted on Feb 27, 2009
Running Windows 7 Home Premium, recently tried installing Radeon X1300 AGP video card, and computer won't display anything or boot with it installed. With card unplugged and using onboard video it still...
Hi - I believe you might be suffering from one of two (or even both) problems. The video card sucks lots of power and I believe has a separate power connector on the card that should be connected. The type of connector varies with manufacturers; from a four pin floppy disc type to a molex type connector or even something proprietary.
Secondly -- It's recommended that you have a 350 watt or higher power supply in your system.
Either issue could keep your machine from booting.
Good Luck, Mikeywaf
Dec 21, 2010 | ATI RADEON X1300 PRO, (256 MB) AGP Graphic...
I have no DirectDraw, or Direct3D or AGP Texture acceleration
Download the driver for that video card in the ati.com and it sure will work! Taah!
Nov 12, 2010 | ATI RADEON 9000 Pro 128MB AGP DDR with...
Agp cards not working
ok hmmmm maybe it only except 4x agp? is it very old? maybe the slot maybe burned out? do you have enough power source to run the card? i cant think of anything else.. good luck. my agp card did the same thing when the power source burned out. some day i would get nice veiw someday a dark screen. i though restarting would help and eventually the power source burned out.
Jan 21, 2010 | Intel D865GLC Motherboard
Flash tends to lag
I suggest using the Flash uninstall tool located at
http://www.softpedia.com/get/Tweak/Uninstallers/Macromedia-Flash-Player-Uninstaller.shtml
And then reinstalling Flash. That will clear any issues or "stuck" registered DLL's and/or registry entries. Good Luck! :)
Sep 23, 2009 | ATI RADEON HD 4650, PCI Express Video...
I have a Radeon 9200 AGP 128 mb new driver my vedeo is jerky
See if you can do a roll back on the drivers, or you may even try system restore.
If not unload the new driver and see if you can locate the old ati drivers (perhaps you still have the original cd)
May 13, 2009 | ATI RADEON 9200, (128 MB) AGP Graphic Card
Video cuts out suddenly, have to reboot
Check to see if your video card is excessively hot. It sounds as if your video card is overheating and going into thermal protection.
A lot of times, when the GPU is damaged it will overheat as one of the final signs before it's impending death.
If this is the case I would replace it.
Feb 15, 2009 | ATI RADEON™ 7000, (64 MB) AGP Graphic Card
Install Used ATI 7000 graphics card on Dell Optiplex GX270
OK, I got into Dell. Your motherboard should support an AGP card.
GX270 System Boards
Is there something in the green slot?
That is the AGP slot. If there is something in it, remove it. The ATI card should work in it if it is an AGP card.
Feb 12, 2009 | ATI RADEON 7000 PCI Graphic Card
Graphics card issue - GA-0ST800 Motherboard
Your motherboard have an AGP 4X port, you can easy upgrade whit that card since it is an APG-card. Not sure tough that your motherboard can handle all that DDR3 power witch come with the card but im sure u will notice a big improvment.
I think that a cheaper card with 512 Mb DDR2 will give u the same results.
Good luck
Nov 21, 2008 | Gigabyte GA-8ST800 Motherboard
VIDEO CARD!
Hi lorkan,
It seems your RV6DE-B3 refers to ATI's 7000 series video card. Listed here at the link below is the driver site for your
Radeon 7000 card.
If your running Window please update your operating system through Windows Update before installing the drivers for the Radeon card.
http://ati.amd.com/support/driver.html
After the above site loads, you'll need to pick your operating system. Than click on Radeon. Scroll down the list in the last window till you see the 7000 series. Click on it.
The page it will take you to is the last software package created for the Radeon 7000. Notice the date.
I suggest you save the program in case you may need to run it again at a later time.
Create a folder on your desktop and save the program in that folder.
If you have any more question or troubles, just post them here & I'll help you solve them.
Have a good day lorkan.
Feb 25, 2008 | ATI 3D Charger AGP Graphic Card
AGP 8x not supported
Just a thought, but have you tried going into the bios setup and setting bios to system defaults or safe setting, saving and rebooting?
Dec 25, 2007 | ASUS P4S800D-X Motherboard
ATI RADEON  X1650 Xt, (256 MB) Graphic Card Logo
183 people viewed this question
Top ATI Computers & Internet Experts
David
David
Computer Links
Alun Cox
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
