Question about Pinnacle Dazzle DVD Recorder
How to use dazzler to copy records to cd
Salesman said the dazzler would copy vinyl to cd.How can I do that?
    Scholar:
  • 150 Answers
You will need a device that can read vinyls and transfer them to your computer. Thinkgeek.com sells a good one called ION USB for $99.
Posted on Feb 27, 2009
How to transfer vinyl to cd-simply-I have manual but very confusing-simple step by step needed-thank you-Al B
The popular recording software known as Audacity is a good choice for getting all sorts of sounds saved in a digital format. The easy-to-use features of this program will help you to create complex musical compositions, or just record incoming audio streams. One of the basic things you can do with Audacity is to record sound from vinyl records. Many people still keep vinyls on hand, though the production of this medium has diminished. Here are the basic steps that will help you to use Audacity to record vinyl.
Steps
  1. Get your phonograph or record player. Assemble your collection of records and make sure that your record player is in good functioning condition.
  2. Use a cable to connect your record player to the computer with Audacity installed on it. In order to record from vinyl, you'll need to make sure you have accurately connected your record player as an incoming audio stream into the microphone jack of your computer.
    • Use hardware adapters to secure your cable connection. Many older record players utilize a 1/4-sized input jack. The modern laptop computer, as well as many desktop models, use a smaller, 1/8-sized input jack. You can buy simple adapters at your local electronics store to fix this problem.
    • Make sure that your cables and adapters support stereo.
  3. Open the Audacity program on your computer. You will see the signature Audacity screen, with controls at the top, and an empty space to accommodate created tracks.
  4. Start playing the record on your record player.
  5. Hit the red circle that represents the "record" button in Audacity.
  6. Observe the sound coming into Audacity. You should see the track being populated with sound, represented by a fluctuating line as the cursor moves along.
  7. Hit "Stop" to stop the recording.
  8. Stop the record player.
  9. Repeat this process with the entire track. Reset the record player, start playing and hit the Audacity "Record" button again, allowing the entire track to populate with the sound of the vinyl record.
  10. Save your project in your desired format. Audacity supports a number of file formats for the finished product. You can select one of these when you have recorded the entire track. Make every song its own track, or simply record the entire side of the record on one track.
Aug 26, 2015 | Audio Players & Recorders
Why can I not record to a CD from the "aux in" port?
Your question has not provided enough information. Are you trying to record vinyl onto a cd?
You cannot record onto a normal cd player. You need a cd burner(/recorder).
Vinyl turntables have a quieter output signal too so unless you have a device that has a phono (vinyl) input you will not be able to record your vinyl. If you have a laptop then the easiest way to record vinyl onto cd is to buy a soundcard that has phono input. You can then use free software (programme) like audacity to record your vinyl and covert it to a format (wav aiff or mp3) to burn to cd using iTunes or Windows Media player.
Sep 27, 2014 | Audio Players & Recorders
Vinyl recording turntable
The Denon will act just like a standard tape recorder. It should have an audio in, for recording. If that socket is connected to the audio out of a tape socket on your receiver, the Denon will pick up the signals that are sent to your receiver from whatever source. All you have to do is follow the instructions for recording on the Denon then. If you have lost the user manual for it, it's free on-line.
Jun 22, 2017 | Denon CDR-W1500 2-Disc CD Recorder
When recording vinyl to cd ..when i play the cd back i can hear the cd motor on the recording
Hmm, no products identified nor connections defined.
It is more likely you're recording the turntable motor than the CD motor. Are you passing the vinyl through a PHONO preamp as required?
Sep 01, 2011 | Audio Players & Recorders
ION LP2CD LP vinyl record records to Internal Fla...
Same just happened to me. I was using SONY CD-R audio 80 min recordable CDs. One burned 3 songs, the other 4 songs before giving me the "CD write failure" message. I tried another brand of CD-R, TDK CD-R, certified plus, and it worked first time. It played on my CD player, on the Ion, etc - works. Maybe the CD burner in the device is very picky as to the brand or quality of the CD-R media? Try a TDK or other to see if that will do it.
-Good luck! Bill
May 19, 2010 | Computers & Internet
I want to record from vinyl record to CD i have the record what Digital audio CD_R DO I NEED I have bought Verbatim Digital Vinyl CD-R Recordable FROM **** SMITH Because that is what they told me to by at...
first you have to copy the records output to the PC, and then burn them to CD DVD. Those disk will be fine after you have recorded the vinyl to the PC. In audio form..
Jan 31, 2010 | Televison & Video
Problem copying from cassettes or vinyl.
CHANGE RCA JACKS ,,COULD BE A BAD ONE,, ALSO ,,TRY BLOWING IT OUT
May 15, 2009 | Aiwa XC-RW700 2-Disc CD Recorder
Where can I get an old vinyl recording repaired and converted
yes it can be done i have done this many time for many people... you will need to find someone who knows what they are doing with delecate vinyl... you could either locate a specialist on the web who will be able to take the track off the record and remaster it before it goes on the cd taking out all the clicks and cracks sounds and any imperfections in the sound caused by the damaged vinyl. this option could be expensive. Just type "vinyl to cd services" in google and the search should yeal what you are looking for.
or...
you could ask any good dj/bedroom dj you know or a friend might know to do it for you, as any good dj will know how to treat a damaged record and will certainly be able to transfer on to cd for you. although... depending on the dj's skill level he may not be able to remove any click sounds or audible imperfections? throw him a tenner and supply the cd im sure he will be happy to help!
Feb 14, 2009 | ION Audio Vinyl Recording Turntable
Pinnacle Dazzle DVD Recorder Logo
219 people viewed this question
Top Pinnacle Computers & Internet Experts
AL Schehr
AL Schehr
Level 1 Expert
Alun Cox
 Ian Kayhan
Ian Kayhan
Are you a Pinnacle Computer and Internet Expert? Answer questions, earn points and help others
