Question about Dishwashers
One of the lid actuator motors died on my F&P DD603 dishwasher and was replaced by the serviceman. He put the machine in a test mode and pressed a code to try the operation while the drawer was open. I witnessed the lid closing properly. Now it appears that the other actuator is faulty. To save an extremely expensive service call, how can I put the machine in test mode and verify the actuator operation with the drawer open?
  • 1 more comment
  • malthatcher Feb 27, 2009
    My F&P DD603 has a three buttons outside. Power, Start/Pause and Lock buttons. Inside it has a soft touch panel which sets the wash cycle desired. The reply to my post does not tell me in a satisfactory manner how to get into the test mode to operate the lid actuators etc with the lid open. When I do get into the test mode, how do I test the actuators?
  • malthatcher Mar 06, 2009
    Thanks for the tip about the micro switch Len. Unfortunately, there isn't one! AFter a lot of (m)ucking around and research, I found that in the front panel there is an optical device based on a LED that senses that the lid is closed. File this away for your next piece of advice!
    Thanks for your help, but you really haven't answered the question.
    President:
  • 1,952 Answers
To test the lid operation first pull the drawer forward of the cabinet by depressing the lugs on each side rail and pulling the drawer forward. Then go into diagnostic mode. Once there press power once and the lcd will display "HO" for hardware output. Then press "Start/Pause until the letters "LD" appear. Press the keylock button and then the two actuators (lid motors) should wind the lid down. If only one works or they both work but the lid does not come down properly you have found your problem. Pressing keylock again will raise the lid. If the lid appears to be snagging on one side or the other it may be the yoke (plastic arm connecting the actuator to the lid) that may be your problem.
Posted on Feb 27, 2009
  • 5 more comments
  • mohammed marika thambi
    mohammed marika thambi Feb 27, 2009
    The door
    switch is important because, if it's defective, the dishwasher won't
    work at all. To reach it, you need to remove the control panel cover,
    or sometimes the interior liner of the door. If it's defective, you
    need to completely replace it.
    The
    latch on many dishwashers is adjustable. If your door is easy to close
    but difficult to latch, adjust the latch to let the door close more
    easily. If you can't see any way to adjust the latch, yours may be
    fixed in a certain position. Check for other reasons for the latching
    problem.
    If the latch has worn out in a way that makes it
    impossible for you to close the door properly, you probably need to
    replace the latch.
    Springs
    Your
    dishwasher has two springs that counterbalance the weight of the door.
    If either or both of these are broken, the door feels quite heavy and
    you need to replace both springs.
    Hinges
    The
    hinges are important to the door closing properly. If they're bent or
    deformed, you probably need to replace them. Once bent, only rarely can
    they be straightened well enough.
    Door seal
    If
    your dishwasher is new--or if you have just replaced a door seal--the
    door may be difficult to latch for a week or two. If the tightness
    persists, though, try adjusting the latch, if it's adjustable. If it's
    not adjustable, there's probably nothing you can do immediately. But
    try running the dishwasher on the highest heat cycle to help the seal
    conform to the door. Otherwise, the seal should compress over time.
    http://www.servicetechhelp.com/index.php...
    http://repairmanual.uw.hu/ServiceTechHel...
    Went on a service call for a Fisher Paykel dishdrawer yesterday.
    Complaint was that the lower drawer would not start up. Diagnosis
    confirmed the complaint, the drawer would act as though it wasn’t
    closed all the way, would just give not-ready beeps when you closed it
    and pressed start.
    I put the drawer into diagnostic mode by pressing and holding the
    Key Lock and Start buttons simultaneously. In diagnostic mode, I could
    review the current and previous error codes. Current code showed U2,
    drawer not closed error. The prime suspect in this case is always the
    drawer limit switch. On the DD602’s, the limit switch is located on the
    very back of the left drawer guide which means, you guessed it, the
    drawer needs to come out.
    If you’ve not removed a drawer from a DD602, you’re in for a joy ride. This article
    has details on how to do it. Fisher Paykel has made several
    improvements in the DD603 models which have been gratefully received by
    Fisher Paykel servicers. The drawer linkage is chief among them. It’s
    actually not that bad, you just have to be patient and methodical.
    http://fixitnow.com/2005/06/fisher-payke...
    Brigadier General:
  • 8,619 Answers
Hi
The diagnostic mode is accessed by pushing keylockand holding it in then push and hold start/pause in that order.
Please revert if you want any error code to be removed .
Thanks
Rylee
  • Rylee Smith
    Rylee Smith Feb 27, 2009
    Dishwasher Diagnostics can only be entered in Power Off mode, ie. When there is no display on the LCD or the badge LED’s are off. Diagnostics is entered by holding the Keylock and Start/Pause buttons simultaneously for 5 seconds. Ensure that Keylock is pushed first.
    There are currently four levels of diagnostics. To move to the next level push Power. To enter a level push Start/Pause. Once a level has been entered, pushing Power will exit diagnostics completely. If no level is entered then the display will cycle through the four levels and exit after the last. On entering diagnostic mode the first level is the Display/Download Mode.
    To find the tech sheet attached to your dishwasher remove the bottom drawer, You'll find a tech sheet attached to the back wall of the cabinet. Push the tabs in at the ends of the rails that hold the drawer in. Careful when you pull the drawer out. Lean the drawer to the left to get it out of the way.
    You can also view/download your user manual from this link---
    F&P 603 Dishwasher Manual
    Please ask for any further clarifications.
    Please rate this solution as FixYa if found useful.
    Thanks
    Rylee
  • 150 Answers
There should be a switch that is pressed in when the door is closed,look closely and find the switch push it in manually with a screw driver,and turn it on.
  • 744 Answers
  • Prakash Ram
    Prakash Ram Feb 27, 2009
    hi u can enter into test mode by holding all 3 programme buttons and powering on.
    Certain combinations then cause the pump to run even with door open....
    thank u!!!
    Scholar:
  • 165 Answers
Keeping the start button pressed.press the menu and functions button twice alternately.
How do I move the actuators by hand on a Fisher and Paykel DD603 two drawer dishwasher
Lid motors should rectify themselves when power is restored. Once they have moved up then push the drawer back. If they don't rectify, you can disconnect the actuator from the side frame and rotate the actuator to wind it up.
Apr 28, 2016 | Fisher and Paykel Dishwashers
How can I test the lid actuator motors
you can go into diagnostic mode by pressing keylock and start buttons together for 3-5 secs in power off mode. Keep pressing start button a few times once all lights light up and you see LS on display. Press keylock to turn on and off the actuator motors.
Dec 18, 2010 | Fisher and Paykel 24 in. DS-603 Built-in...
On 2 door dishwasher model DD603 bottom draw is very hard to slide out or in. Can i remove draw to inspect and oil draw runners?
Hi- Most likely the lid is stuck in the down, or partially down position. This is usually caused by the lid actuators (motors) not returning the lid to its full up position and therefore the drawer top is dragging on the lid gasket. Replacing the lid actuators should resolve the problem. You'll need a F/P tech to change those for you. Hope this helps.
Jul 26, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
Leaking water from bottom draw
To put machine into test mode: Press and hold keylock, then press and hold start button. Hold both in until machine beeps (if you have display, it will show all symbols). Press power button- display should now show HO. Press start button until LD shows in display- this tests lid motors. Activate lid motors by pressing keylock button- if you open drawer about 3 inches, you should see lid come down. Pressing keylock again will raise lid. Raise and lower lid several times by pressing keylock button to ensure lid is working properly- if not, lid motors need replacing. Good luck!!
Mar 18, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Can anyone help me with my fisher and paykel DD603 the top draw is showing F1. fault 1. thanks
When F1 is showing up then there is a leak. The leak is causing by the top lid seal not close down tightly to the opening tube surface groove. Pull out the tube, put in tower in the bottom housing accessing from the left side. Only this side you can have room to put your hand in drying out the bottom. Do the same thing with the bottom drawer since the floor sensor is at the bottom and when it detects water then there is some water at the bottom housing of lower tube also. After Drying it out you can use You can use the lower tube wile ordering parts for the upper tube. Need to order 2 upper actuators and a lid seal with YOKE, if you want to do it yourself. Otherwise, have a F&P serviceman come in and diagnose the problem, not any handyman since the F&P dishwasher is not like others.
Dec 27, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher Paykel DD603 Problem. Top drawer shows F1 and pump runs continuously. Lower drawer does nothing, no display. I think the Electronic Controller in lower drawer is fried and maybe the Mains Filter...
Yup, definately the bottom drawer controller, for some reason you can run a DD603 with no board in the top, so long as you have a board in the bottom, but not the other way around. This is the fault you get, constant F1 from the top drawer. If you are stuck try removing the display cable from the bottom controller, this may help, so long as you leave the chassis harness in.
Sep 26, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
I cannot open the draw something is stuck in it
Your dishwasher has a top lid to seal the tube when it in operation. The seal mode is achieved by 2 actuator valves on both side of the housing pulling your top lid down. Model from 603 to current actuators are electric motor. For previous models they are vacuum pump activation.
When the actuators are bad they are either not pulling down the top lid causing a leak, or not releasing top lid back to its original position causing the lid stuck and the tub can not be pulled out as in your case.
Let's go to diagnostic test mode to see if you can retrieve the the actuator hence the tube out.
1- Press Lock button and start/pause key until the display showing up.
2- Press Power to show HO.
3- Press start button to advance the display until you see LD or LS, if you pass, keep doing it to get it back in a loop.
4- When at LD or LS, press lock to turn on, press a agin to turn off.
5- Listen to the sound of Actuators and at the same time, try to pull the tube out.
6- When it is done, just press the Power button to get out od the diagnstic mode.
7- If you are lucky, if just the seal to replace then it is easier than repalcing the actuators. Good luck.
Sep 08, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
F1 code on fisher&paykel DD603 dishwasher
if you remove the lower drawer assembly, there is a pretty helpful techsheet/trouble shooter, that will get you intotest mode for the lid actuators. a quick way (in my experience, is color.. they now preoduce a black set of actuators that have a REAL low failure rate,,if i see that your actuators are white'off white in color, i generally reccomned replacing them with the newest set
Feb 11, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
Top drawer stuck, gaskets rubbing, no power to controls
I see the question is posted in the DD603 section, so I am not sure if I am giving the proper advice. Are you sure this is a 602/601 series? A DD603 model has lid actuator motors, not the inflatable style seal. It sounds like the lid motors are in the DOWN position. Since the machine is "dead" what may have happened is the heater plate opened up (the heater plate is a dropping resistor inline with the machine's controller) when the machine was in use and that stopped everything dead.
Double-check your model number so we know what style of lid your machine has, The difference is huge between models.
Dec 31, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwashers Logo
104 people viewed this question
Top Dishwashers Experts
