Question about Dell Dimension E521 PC Desktop
How long is a Video Card good
I replaced the video card less than a year ago and my computer is now doing the same thing as before. Dell says the computer is out of warranty and will not replace the card a second time. Could it be something else? Additionally, on the front of the computer there's a cylinder shaped/battery icon blinking. What could this mean?
  • 75 Answers
The video card most likely has gone bad.the batterie on your motherboard needs replacement.
Posted on Mar 04, 2009
  • Charles Stillwell
    Charles Stillwell Mar 04, 2009
    videocards verie,yours should last longer than it has.
    cleaning as mentioned above might help.
No color Red, Dell XPS 400, NVIDIA GeForce 7300 LE video card
Mike,
I would recommend for you to try different monitor, so that you can isolate the problem.
If same problem occur, try to plug in your video card into another PCI slot in your computer. Cleaning the gold fingers of the video card with a clean cotton cloth might help.
Use a blower to remove some dust on the PCI slot.
Or try inserting the video card in another computer. If you get the same problem on another computer, you need to replace the card.
Mar 07, 2010 | Nvidia GeForce 7300 LE 256MB PCI Express...
MY DELL DIMENSION E521 WONT BOOT WINDOWS AFTER STARTING UP, I WAS TOLD THAT THE VIDEO CARD COULD BE BAD, WHERE IS THIS LOCATED IN MY PC AND CAN i USE ANY VIDEO CARD TO RPLACE THIS?
Hello, if you were told by an expert tha you need a video card, here what you need:
1: You do not have a slot card type video card in your system( Dimension E521) your system has on board video, which you can not remove from the system but disable it.
2: Your system has PCIe x16 slot that can be used for new video card.
3: Link below will give you a list of PCIe x16 video cards, you can pick and choose according to your needs. Do you need DVI (digital connection, does your monitor has a white port in the back or just the blue one?), or regular VGA (blue port) is enough, do you need HDMI etc...
bottom line is any of those video card will work.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=40000048%201069609641&Description=pci%20express%20video%20card&name=PCI%20Express%20x16&ActiveSearchResult=False
4: I am assuming you have never done this before so before you open up computer and start taking things apart go to the link below and download service manual for Dell Dimension E521 ( I selected the model for you so you don't have to look for it :-) )
http://support.dell.com/support/edocs/systems/dime521/en/SM_EN/index.htm
5: In the service manual link there are several Sections like:
Before You Begin
About Your Computer
Technical Overview
Specifications
Advanced Troubleshooting
System Setup
Removing and Installing Parts click on each one and read about it first to familiarize your self with the system.
6: Once you feel confident enough remove the power cable from from computer.
-> open computer cover
-> follow instructions in service manual under
->Removing and Installing Parts
-> Cards
->PCI Express Cards
-> Installing PCI express card.
-> Close computer cover
-> plug monitor cable to new card
-> power on the computer
-> if Picture quality is bad that means card was not properly recoginzed, install drivers from the CD that came with the video card.
I hope this helps, if you get stuck at any step or not clear feel free to post back.
Kind Regards,
Amar Sondhi
Feb 01, 2010 | Dell Dimension E521 (D10E16) PC Desktop
Dell computer, less than a year old, XP Pro, having problems freezing, especially when using applications like some browser-based games (my wife plays Happy Island and that stuff on Facebook), and also...
If your computer is less than a year old, you should be able to contact Dell technical support for help (support.dell.com)
It sounds like it's a driver issue - most likely video drivers. You can check the support website for updated drivers for your video card.
Jan 22, 2010 | eMachines T3604 PC Desktop
Pc powers up but no video on screen
Some computers require you to set the video output in the bios and some are auto. Take a look.
If its not the bios settings maybe you need to take out the card give the slot a blow and put it back. Sometimes they just don't quite sit right.
Sep 17, 2009 | Dell Dimension 8200 PC Desktop
Dell Optiplex GX620 not recognizing PCIe video cards
One of two things could be doing this:
1: Bad Video Cards
2: Bad PCIe slot(s)
If avaliable, I would test the video cards on a PC with a PCIe slot to verirfy if the cards are good/bad. If they work, your PCIe slot is bad and need to have the motherboard replace to correct.
Good Luck
C2Solutions
Aug 27, 2009 | Dell OptiPlex GX260 PC Desktop
Existing Radeon X600 card in Dell Optiplex gx620. All of a sudden in displays a black screen and just shows the graphic card info at the top. Won't boot. Just hangs there. Unistalled this card, put in a...
Check for motherboard or powersupply issues. The GX620's were in a range of DELL models that were affected by bad capacitors.
Failure of motherboards and power supplies is usually due to breaking capacitors. A few years ago a capacitor company stole the "recipe" for making capacitors from another company and tried to make their own, unfortunately they did not get the ingredients right and the capacitors started breaking after 2-3 years of use. They sold these capacitors at very cheap prices and a lot of computer companies (not just DELL) and power supply makers bought them. This is easy to diagnose. Look for capacitors (caps) (they look like little tiny soda cans) on your motherboard (mobo). They should be perfectly flat on top and not bulged or swelling or leaking anything. Make sure you look at the ones under the fan shroud (back of processor). The dead giveaway is the fact that you are getting the same thing after you switched video cards. If you listen to your computer as it starts up, a few of the devices may not start (hard drive, etc). A failed video card will usually give you the "No signal message", but the computer should sound normal when starting up. Mobos are usually expensive to replace because the computer makers have them made especially for them and only order so many. They usually do not have a lot of extras laying around. There are a few companies that will repair broken capacitor issues. Also if you add a bunch of extra components without upgrading the power supply you can suffer underpowered situations and this could cause your problem. Let us know what you find out.
May 01, 2009 | ATI RADEON X600 SE 128MB DDR1 PCI Express...
Video for a dell
What are your symptoms? What happened? Did you just start getting the No Display- Check cable message?
Loss of video is one of 3 things.
1) Bad or loose video card - But you get normal sounds (you can hear the Windows sound when starting up) and normal beeps. Do you get the normal sounds when starting up? If you do not then video is most likely not your problem.
2) Bad or weak power supply unit (PSU). Sometimes it appears that a power supply unit is working, but in reality it is not getting enough power, usually due to some bad capacitors (caps) inside. If you swap out the power supply you have to put one with the same or greater output watts in it. Output watts can be found on a sticker on the outside of the PSU.
3) Failed or failing motherboard (mobo). This is usually caused by failing capacitors (caps). Caps look like little soda cans and they should be perfectly flat on top and not bulging or swollen or leaking anything. Visually inspect those. A bunch of computer manufacturers and power supply manufacturers got bitten by a company that years ago was making poor quality (but cheap) capacitors. Seems this company stole the recipe for the capacitors but didn't quite get the mixture right and after 2-3 years these things started failing. I have seen several DELL's with this problem.
So in my opinion you could have either a weak or bad power supply or a failed or failing mobo. What is happenning is that the computer does not make it through the Power On Self Test (POST) and that is why you would hear no beeps and get no video. SO I believe that you have situation 2 or 3 mentioned above. That is where I would start looking for your problem if the clarification request from dickcanfixit does not help.
Apr 24, 2009 | 3Dlabs Dell Precision WorkStation 610 3D...
Cannot display video mode
The problem is your video card not able to communicate properly with the hardware. To solve this problem you need to install the drivers for your video card. In case you already installed it (long time ago), you need to update the drivers. Check the video card manufacturer for updates.
Good luck.
Jan 17, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
Monitor gets a blue hue
Hey Tricky Cat!
My first advice would have been the cable...since that did not resolve it it can only be 1 of two other things...the video card (might be intregrated on your motherboard)...or the monitor.
To test plug in another monitor if you have one. If the problem resolves it is the monitor...if not then the video card.
You will have to way your expenses to fix...usually a monitor is cheaper to replace...as well as a video card. If it is integrated the cheapest route is to buy a new video card and turn off the old one in the BIOS.
Good luck my friend.
Seek PC Repair
Feb 09, 2008 | LG L1520B 15" LCD Monitor
Dell computers are hard to upgrade.
hi will
yes these cards uses a lot of power. Check to see if the power supply pushes enough power to run the video card. I think these card needs its own power source so make sure you use a sepearate cable from the powersupply to the video card and not share it with other components.
if you have less than 400w powersupply thne this is morelikely your problem
good luck
smeags.
Dec 12, 2007 | ATI All-In-Wonder® 2006 Edition RADEON®...
Dell Dimension E521 PC Desktop Logo
48 people viewed this question
Alun Cox
