Question about Apple iPod touch
I can't connect to wifi - my network pops up, but it doesn't prompt me for a password and I don't see any info filled out under IP Address, Subnet Mask, Router, DNS etc. Help! I've tried to reset my settings and it still doesn't work.
  • 70 Answers
U have to go in to your router settings and change the MBPS limit to enable slower connection and u may have to add devices.
Posted on Feb 27, 2009
Find proxy server address
Changing TCP/IP settings Win 7 TCP/IP defines how your computer communicates with other computers.
To make it easier to manage TCP/IP settings, we recommend using automated Dynamic Host Configuration Protocol (DHCP). DHCP automatically assigns Internet Protocol (IP) addresses to the computers on your network, if your network supports it. If you use DHCP, then you don't have to change your TCP/IP settings if you move your computer to another location, and DHCP doesn't require you to manually configure TCP/IP settings, such as Domain Name System (DNS) and Windows Internet Name Service (WINS). To enable DHCP or change other TCP/IP settings, follow these steps:
  1. Open Network Connections by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, and then clicking Control Panel. In the search box, typeadapter, and then, under Network and Sharing Center, click View network connections.
  2. Right-click the connection that you want to change, and then click Properties. 18abb370-ac1e-4b6b-b663-e028a75bf05b_48.jpg If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
  3. Click the Networking tab. Under This connection uses the following items, click either Internet Protocol Version 4 (TCP/IPv4) or Internet Protocol Version 6 (TCP/IPv6), and then click Properties. 25e7e385-9327-4f7d-aab0-afa5aaf952ba_49.jpgThe Network Connection Properties dialog box
  4. To specify IPv4 IP address settings, do one of the following:
    • To get IP settings automatically using DHCP, click Obtain an IP address automatically, and then click OK.
    • To specify an IP address, click Use the following IP address, and then, in the IP address, Subnet mask, and Default gateway boxes, type the IP address settings.
  5. To specify IPv6 IP address settings, do one of the following:
    • To get IP settings automatically using DHCP, click Obtain an IPv6 address automatically, and then click OK.
    • To specify an IP address, click Use the following IPv6 address, and then, in the IPv6 address, Subnet prefix length, and Default gateway boxes, type the IP address settings.
  6. To specify DNS server address settings, do one of the following:
    • To get a DNS server address automatically using DHCP, click Obtain DNS server address automatically, and then click OK.
    • To specify a DNS server address, click Use the following DNS server addresses, and then, in the Preferred DNS server and Alternate DNS server boxes, type the addresses of the primary and secondary DNS servers.
    f598cd96-6bf9-47be-942d-7d0b0afdbd88_47.jpgThe Internet Protocol Version 4 (TCP/IPv4)Properties dialog box
  7. To change advanced DNS, WINS, and IP settings, click Advanced.
Mar 10, 2014 | Dell Latitude D600 Notebook
Tip
HOW TO CHANGE IP ADDRESS
To change your network IP address in Windows XP, Vista, or 7:
1. Press the Windows Key and R
2. Type command and press Enter. This loads your DOS prompt
3. Type ipconfig /release then press Enter. This disables your internet connection
4. Go to your desktop, and right-click on something called Network Place or My Network Places (If you're using Windows Vista or 7, look for the Network and Sharing Center through Control Panel)
5. Click Properties. You should now see something called Local Area Connection or something similar
6. Right-click on your connection (titled Local Area Connection if you're using an ethernet cable or Wireless Network Connection if you're on WiFi) and click Properties
7. Under the General tab, double-click on the Internet Protocol (TCP/IP)
8. A new window appears. On its own General tab, click the box beside Use the following IP address
9. Type in ones until you fill the box up (it should read 111.111.111.111)
10. Press Tab. You'll notice the Subnet Mask section automatically fill sup with numbers
11. Click OK
12. Click OK to bring you back to the "Local Area Connection" screen
13. Right-click Local Area Connection and Click on Properties again
14. Again, under the General tab, double-click on the Internet Protocol (TCP/IP)
15. Select Obtain an IP address automatically
16. Click OK
17. Click OK
18. Go back to your DOS prompt, type "ipconfig /renew" and press Enter. This restores your internet connection.
By now, the network should've assigned a new IP address to your computer automatically.
on Jul 22, 2010 | Computers & Internet
Tip
Before you start configuring the WRE54G you need to consider the following...
Before you start configuring the WRE54G you need to consider the following factors:
1. Make sure that there are no wireless security enabled on the router like WEP and wireless MAC filtering. If you have them enabled try to disable them first. Check if there is a wireless computer that is currently working on your network.
2. Make sure that the SSID broadcast is enabled.
3. Then Hit the Automatic Configuration button on the WRE54G for about 3-5 secs.
The wireless computer should be connected to the SSID of the Range expander.
The range expander doesn’t have any DHCP server. The IP address that will be assigned to the computer will be 0.0.0.0 or the Auto-configuration IP 169.254.xxx.xxx.
Assign a static IP address on the wireless card. IP address should be 192.168.1.5, Subnet Mask 255.255.255.0, Default gateway 192.168.1.1
To assign static IP address on your machine you follow the steps below:
Windows 9 xs and ME:
Go to Start > Settings > Control Panel > Network > Highlight the TCP/IP of the Wireless LAN card you’re using > Properties
Under IP Address TAB:
Specify an IP address: 192.168.1.5
Subnet Mask: 255.255.255.0
Click the GATEWAY TAB:
Under New Gateway: Enter 192.168.1.1 then click on Add.
Then Hit Ok All the way out… hit yes if it’ll ask you to restart
Windows XP and 2000
Go to Start > Control Panel > Network Connections > Right Click Local Area Network Connection that you are using > Properties > Internet Protocol TCP/IP > Properties > Use the following IP address:
IP Address: 192.168.1.5
Default Gateway: 192.168.1.1
Then click ok all the way out.
Try to ping the Range expander. Go to start and then run type CMD for Win XP/2000, COMMAND for Win ME and below. On the black screen that will pop-up type PING 192.168.1.240 (Default IP address of the Range expander.
If the ping test was successful then you can access the setup page of the Range expander. If not, try to reset the Range expander for 10 seconds and then power cycle it.
To reset the range expander, follow the steps below:
Hold down the reset button for 10 seconds then unplug power while holding down reset...plug it back in after 5 seconds then wait for 10 more seconds before releasing the reset button.
To access the setup page of the expander, Open your Internet Explorer and please go to http://192.168.1.240
If will prompt a username and password box, leave the username blank password is admin.
On the setup screen of the expander, you can set the same exact settings on your router. SSID, Channel, WEP settings should be the same on the router and you need to specify the WLAN MAC Address of your router to the space provided for the WLAN MAC address on the setup page of the Range Expander.
Once you applied the settings, the lights on the expander should be both blue.
You can now set your IP address back to obtain an IP automatically and Obtain DNS address automatically.
Range expander should be working after performing the troubleshooting steps above.
If you have an Ethernet port on the WRE54G, try to connect the range expander directly to your computer with static IP address then ping the WRE54G. Make sure that you are not running any firewall and Internet security in your computer. If you were able to ping the 192.168.1.240 try to access it through the Internet Explorer and configure it from the there. Follow the steps that I gave to you to configure the wireless settings of the range expander.
Make sure that you have checked all the wireless security settings on your router. Make sure that you have those disabled. Try to set static IP address in your computer and try to ping the 192.168.1.240 and see if you can get a reply.
To set static IP follow the steps below:
Windows 9x and ME:
Specify an IP address: 192.168.1.10
Windows XP and 2000
IP Address: 192.168.1.10
Then Hit Ok All the way out.
on Mar 08, 2010 | Computers & Internet
IP Address Conflict... So I have two computers at home. Two Dell Desktop computers running Windows XP. Both have USB wireless network adapters. I don't own internet (Don't shun me. My fam...
although I don't support IP Pirates(if they can afford not to be). there is one trick that may help but not if the security on the router is strong as they can set it to only hand out 1 number. However if you know the IP(192.168.0.2) that is being handed out. then you can manually set the wireless adapter on the second system to have an IP that is +1(192.168.0.3) (instead of a DHCP setting)of the number you are given. make sure the gateway and subnet mask is exactly as is handed out to the first system.
you can easily view this info. from a command prompt and typing:ipconfig /all
GL
hope this helps
Don't forget to vote for me
Thank You
Jammer
Aug 17, 2011 | Dell Inspiron 530s Desktop Computer
WIFI
connect to wifi using my blackberry curve 8520 1. Click icon Manage Connection
2. Check/click on Wi-Fi ON
3. Scroll down and see “Set Up Wi-Fi Network”, click Next
4. And now click Scan For Networks.
On this step BlackBerry will scan all of the Wi-Fi around you. Find the Wi-Fi that you want it and save if needed.
5. If you know the SSID network, you can Manually Add Network. And now click theBlackBerry menu and click Connect.
6. If you ask for password, fill it. Usually in free Wi-Fi hotspot there’s no password needed.
7. The next step is fill the name for the Wi-Fi connection to save on Wi-Fi profie or you can just click to Connect. Click Next to continue..
8. The Menu will be back to Manage Connection. Check the Wi-Fi Options to set the UP address is it using DHCP (on BlackBerry it will said “Automatically obtain IP address and DNS”) or using static IP address. If using DHCP you can browsing to Internet but you must change the setting at the browser on the Main Menu -> Options -> Advance Options -> Browser. Change the default browser configuration with the HotspotBrowser. Good luck to surf on the net!
9. But if it’s need manually fill the IP address. You can go to Wi-Fi Options, Hightlight Wi-Fi profile which you already save previously, click the BlackBerry Menu, Edit, Highlight the text “Automatically obtain IP Address and DNS”, click BlackBerry Menu, Change Option, fill the IP one by one (default is 0.0.0.0). And click Save. And don’t forget to change the browser by follow the step on number 8.
Happy surfing on the internet using Blackberry!! But do not forget turn-off the Wi-Fi to save the battery lifetime.
Mar 26, 2010 | RIM BlackBerry Curve 8520 Smartphone
Tip
Configuring WRE54G to a wireless router
Windows XP and 2000
Windows 9x and ME:
Windows XP and 2000
on Feb 07, 2010 | Linksys Wireless-G Range Expander (WRE54G)
I cannot get internet connection, i am on wireless 1 and it is asking for a password also i don't know the ip address, subnet mask and the dns
Even if the modem/router you are trying to connect to allow 'dynamic IP' address resolution (eg. no need for coonecting device to know IP address, subnet, etc...), you will still need to know the specific 'password'/ 'Security Key'/Encryption Key for your specific modem/router Wifi coonection - I am assume that you also know the correct SSID (Broadcast system ID for Wifi) for this Wifi Connection.
Hope it clarifies a few requirements.
Dec 27, 2009 | Apple iPod touch
My 2Wire Wireless adapter connection keeps getting disconnected every 5-10 minutes(ATT U-Verse Internet Svc)Is there a better adapter to resolve my problem ? Thank you.
well!! I have an answer for you.your comp is loosing the IP address. goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jul 01, 2009 | Computers & Internet
My WL-138G cards loose connection info when shutdown
Jun 27, 2009 | ASUS WL-138G Wireless Adapter
Apple iPod touch Logo
46 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
