Question about Canon PIXMA MP600 all-In-One InkJet Printer
Intuit printing library: trying to print quicken report
Intuit printing library : could not open printer check your printer selection
5 Suggested Answers
rtrahan
  • 741 Answers
SOURCE: Won't Print Quicken Checks- Canon MP620
Here is all I could find, as it is a compatiblity issue and not a repair issue. Hope this helps. You can also get on an online instant chat at www.hp.com and they may also have some answers for you.
HP has apparently released new printer drivers for some of their
> printers that will fix at least one print problem experienced by
> Quicken users.
> If you have an HP printer and are having problems printing from
> Quicken and you use 64 bit Vista, check this HP faq to see if there
> may be help for you.
> http://tinyurl.com/89ly3u
P.S. It appears that the fix will apply to more printers than are named in
the faq; The way I understand it, if there is a version 12 driver available
for your printer model, you probably should get it.
Apparently the list of printers to which the fix applies will be updated at
some point.
Don't forget to rate this 4 stars before you log out. If I can be of any help let me know.
Posted on Feb 01, 2009
c_robertson
  • 123 Answers
SOURCE: prints photos with yellow horizontal stripes.Hv downloaded HP printing diagnostic utility and no errors were reported. If just using scanner to copy photos, prints fine but copying photos in library p
go into the printer and do a test print. start>printer & faxes>right click on the printer in question>properties>printer preference button> test print ... try the printer's own test print. This is usually caused by a poor print head, low ink, poor cartridge or the need for calibration. Look in the maintenance tab in the printer properties for head cleaner, jet cleaner etc. This also happens with refill ink cartridges.
Posted on Apr 29, 2009
nalin_elliot
  • 224 Answers
SOURCE: Printing check from Quicken 2009 Deluxe
All Printers have this issue printing from quicken you would need to download the older version of quicken from oldversion.com
Then uninstall the new version and install the old version.
all lexmark/canon/epson/brother/hp.....printers have this problem with the new quicken.
Or try calling in to us at 1800-474-6836 and provide us with a remote session with your computer we may be able to fix this issue with a basic driver.Let me know if you have connected the printer thru usb or ethernet and I will give you a resolution that works 70% of the time with the new quicken
Posted on Jun 17, 2009
SOURCE: quicken reports won't print
Go to printer under control panel and right click on the printer - select printer properties...advanced tab...check print directly to printer. Checks should print now. Downside...everything prints directly to the printer (no spooling) which can be slow at times. Also I have found printing pdf's using this option won't print so you'll have to change it back. I'm using Windows 7
Posted on Jul 08, 2010
Quicken 2002 will not print reports with windows 7. No documents pending shown in queue. How do I resolve this?
I have an HP printer and had the same problem. I went to HP.com and there was a driver I had to download and I now am printing!
Jan 07, 2011 | Intuit Quicken 2002 Deluxe (78588)
Quicken reports won't print
May 06, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Printing check error code 7224
Using Quicken Premier 2009 on Windows 7 x64 with HP OfficeJet 7310.
My check wouldn't print and was booted out of Quicken. Validated data (was OK), reinstalled Quicken Premier 2009 (per instructions above), checked printer and driver (was-OK), I still could not print checks (error code 7215 and quicken closed).
SOLUTION: I deleted the transaction I was trying to print, the re-entered it. It printed fine.
Feb 13, 2010 | Intuit Quicken Premier 2009 for PC
Quicken reports & reconciliations wont print
If your printer prints other documents properly then it is a problem with the driver for your Quicken program. Go to the Quicken site and upload the latest driver for your operating system.
http://support.intuit.ca/quicken/en-ca/index.jsp
Jan 19, 2010 | Intuit Quicken Starter Edition 2008:...
Cannot open printer from Quicken 2001 Deluxe
Check intiut's website. There have been some problems with 64-bit Windows Vista. You didn't specify whether you have 32-bit or 64-bit operating system.
Aug 09, 2009 | Intuit Quicken 2001 Deluxe (256101) for PC
Quicken no longer prints checks for me What is wrong?
Your printer DEFAULT - could be set to Intuit or Quicken PDF writer. Try to select print, and when it offers a PARTICULAR printer, see if you can designate the correctly named printer.
Also, IF there is currently a stuck or jammed job in the printer on your computer, you can find the printer queue, and PAUSE and then CANCEL the jobs entirely.
Jul 29, 2009 | Intuit Quicken Premier 2009 for PC
Have Quicken 2008 and HP J6400 printer. Can print reports but can not print checks
Check that the problem is not caused by mismatched paper size, in that case you may need to correct printer settings and adjust also settings on Quicken.
Quicken 2008 is also known for having several bugs that affect printing, if you are considering an update to 2009, that should fix the problem.
You can also check if a patch to fix the problem is available contacting quicken online, check the links below:
Quicken® Personal Finance Software: Chat
Get Help with Quicken | Quicken Help and Support Options
Regards.
Jul 27, 2009 | Computers & Internet
Won't print checks or anything from quicken but does for every other program. All I get is "spooling" and then nothing.
It won't print you have to save the file on the desktop or in documents or anywhere away from the original and then try to print.all printers have issues with quicken deluxe they will not print from quicken deluxe unless it so happens b fluke
May 29, 2009 | HP OfficeJet 6310 All-in-One Printer...
Re: PIXMAMP600 I am having trouble in some instances where I get a message on the computer that my printer is off-line. I am able to print other things without a problem. When I try to print a Quicken...
I am not too familiar with Quicken as I use QuickBooks, but if I am right Quicken uses a printer service like Microsoft Word and QuickBooks does.
Look in the Printer Folder in Control Panel and look to see if a Quicken printer icon is displayed, if there is one, right click the icon and check the properties to make sure your printer and not Quicken is the default printer. I have actually deleted the Word, Quickbooks and Acrobat Reader printers in the past with no problems.
You could also check the Options in File. Open Quicken and in the top left corner click File, check to see if there is an Options tab or any thing regarding the printer to make sure your printer is the default printer and not Quicken.
Oct 03, 2008 | Office Equipment & Supplies
Canon PIXMA MP600 all-In-One InkJet Printer Logo
1,441 people viewed this question
old marine
old marine
