Question about KitchenAid (KSRD22FKST) Side by Side Refrigerator
How do you level the kitechenaid side by side
How do you level the kitchenaid side by side superba?
  • KitchenAid Master
  • 4,655 Answers
Hope this helps solve your problem, Let me know. Thanks, Sea Breeze
This happens because the refrigerators of today are air tight, the fresh food door pushes the air into the cabinet as it closes and the air has no place to go but up the air vent into the freezer and "pops" open the freezer door. First thing is make sure the freezer door is capable of closing properly and is not rubbing or catching anywhere. I sometimes add a washer or 2 to the center hinge under the freezer door so it doesn't rub anything. Put a little Vaseline ( or food grade silicone lubricant ) on the hinge side of the seal. I then raise the front of the refrigerator so that the front of the refrigerator is a little higher than the back of the refrigerator. Never level a fridge with a level. Once you have the door closing properly and front slightly higher than the back...let the fresh food door close from 90 degrees on it's own and the freezer door may "pop" open a little but will close again on it's own...and stay closed once all is set up properly. We see this more often now and have no trouble with the door staying open again after setting up the refrigerator properly.
Posted on Feb 27, 2009
I need some help with a KSRB25FKSS02 Ice maker not working
First place to start is: Look at the switch on the right side of the freezer compartment, is there a red LED there blinking? KitchenAid Refrigerator Ice Level Control Board W10757851
If there is no lite, replace this part...
Jul 07, 2016 | KitchenAid Superba Architect KSCS25INSS...
Water collecting in bottom of refrigerator? where does it come from? How do you stop it? We have a Kitchenaide superba freezer over refrigerator 21.5 cubic feet total.
most common cause is condensation(fridges are not frost free).check door seals and that the kids have shut the door asap.also make sure you use a spirit level to square up the unt so that the door seals are tight allround....lastly,cover all food and put kitchen paper under salad/fruit drawer to catch water droplets(condensation)
Apr 12, 2010 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba refrigerator door not closing
have you adjusted the levelers underneath to make sure f/f is square.use a level on top.
Mar 06, 2010 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid Superba Side by side, refrigerator side not cooling
Assuming that your fridge is set at max thermostat setting, and still it cools to 8 degrees only. It only mean
one thing, and that is have your refrigerant level check,
and have it loaded. E-mail to us your comments.
Oct 07, 2009 | KitchenAid Superba Architect KSCS25INSS...
Fridge door is lower then freezer door
The #1 cause for this problem: The floor beneath the fridge is uneven, causing the refrigerator "box" to be out of square. Adjust the levelers on the fridge bottom to compensate for the uneven floor. That should do it.
May 19, 2009 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba - delay in dispensing ice cubes
be a liitle patient ,if it is a fairly new appliance be grateful it's working properly.
All laughter aside : check the ice bucket that the ice falls into and it may be that the ice is clumping up and not in line with the auger that pulls it to you.
Please rate this !
May 16, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid Freezer not freezing completley
sounds like you might have a sealed system issue(ie.compressor, sealed system. check your user guide for warr inf you might stil be covered by manufacture for this issue
Jan 06, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid superba side by side Refrigerator
take it out, wash it, and replace so that it fits
where it was intended and level. use a flashlight
Is your frig level?
there should be no splashing when a door is opened.
"The pan is only attached on one side"
this cannot be the pan must be level and secure.
Nov 02, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid (KSRD22FKST) Side by Side Refrigerator Logo
300 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
