Question about HTC Touch P3450 Smartphone
My HTC has been dropped in the water for a brief second but its been a long time. it worked great after that, even. fixed it with that plugging it to charger without battery and it worked. now its been a couple months and that trick isn't working this time. the white screen doesn't go away. i have tried everything!!
    Problem Solver:
  • 10 Answers
First thing when any electronic equipment is in water, we need to remove its power source like battery until its completely dry. to save it from more damage to circuit. You need to get it repaired @ HTC Service center.
Posted on Feb 27, 2009
I dropped my phone a couple of times(htc touch pro)
if you have disassembly skills and your phone is not in warranty, you can dissasemble it and check connection of LCD flat cable, if you have warranty, put it to service
Jul 08, 2009 | HTC Touch Diamond Smartphone
Tip
I have an HTC s640 and it just stopped charging the last time the battery ran...
Your battery has been depleted past a chargable state.  This is a due to a bad design in the phone that doesn't monitor the battery power state well enough.  It actually allows the battery to be taken under the minimum amount needed to recharge the battery.
You can fix this, but do so at your own risk.
You can simply purchase a new battery, that will work, just been sure not to let it deplete the battery totally anymore.
Now, on to the fix
-Take out the battery.
-Get any usb cable you can find sitting around. (any usb wire will do, an old printer cable, anything with a usb end that can plug into your computer)
-cut one end of the plug off. You need to leave the side on that connects to your computer. Cut off the side that plugs into a device (printer, camera, web cam, etc)
-Strip the rubber off the wire and expose the wires inside.
-Separate the wires from each other. You will only be using the BLACK and RED wires.
-strip the very end of the black and red wires carefully using a wire cutter exposing the metal wire inside the red and black covering.
-Plug in your home made battery charger to your computer. Careful not to touch any exposed metal, as it will give you a small shock.
****WARNING****
DO NOT UNDER ANY CIRCUMSTANCES ALLOW THE RED AND BLACK WIRE TO TOUCH EACH OTHER
****WARNING****
-now carefully hold the black wire to the negative terminal on the battery (it should be noted with a black circle with a - in the middle). Then touch the red wire to the positive terminal (it will be noted with a red circle with a + in the middle).
Hold the 2 wires there for 20 seconds. Then quickly plug the battery back into the phone, and then plug it into a regular charger. Give it little bit of time, if you've done everything correctly the charge light should come on.
I had to repeat the last step again to get the light to turn on indicating it was charging.
You must not hold the wires to the battery for too long, 20 seconds should do it. You can overload a battery with this trick and actually make it explode if you hold it there too long. You are well within the few minutes needed to detonate the battery due to overcharging by sticking very strictly to 20 seconds.
Just be careful and you'll be fine.
One you get a charge light give it a few minutes in the off position, then try powering up the device and keep it plugged in until you get 100% charge.
Good luck,
Peter
on Apr 04, 2010 | T-Mobile MDA
Water damaged htc tytn2 help
buy a tin of electrical cleaner strip phone take away screen spray all parts with cleaner saved a few nokias like that
Apr 08, 2009 | HTC TyTN II Smartphone
Htc touch diamond black pc suite
when u plug u r USB cable to u r PC it ask for two options
1. Active Sync
2. internal storage
select second option and drag and drop what ever u intrest
Feb 03, 2009 | HTC Touch Diamond Smartphone
Htc s710 display black out
I have the same problem .... but my solution was to take the battery off and apply some presure on the are where that B (from Bluetooth) and that bin .... this solves the problem .... but just for a few minutes or days ..... depending on how much presure you apply.But be careful ..... too much presure and you will get in my situation .... crack the LCD :((
Jan 13, 2009 | HTC S710 Smartphone
Dropped in water and won't start????
in this case don ever try to turn on the phone in this case and the circut will  get jammed. dismandle for the water to get dry. this solution might sound funny but  it will work, bury in the phone in the rice ,as it has nature absorb water , may be bury it atleast an hours time.try with hair dryer to dry the water content and while blowing air keep in distance and try as the hot air will jam the circuit again
Nov 03, 2008 | HTC S620 Smartphone
HTC touch phone not working
You kow how many second hand nokias you can buy for the same price as a new HTC???
Well plenty to really use them as a disposable phone.
with one HTC you only have ONE disposable phone which won't last as long as 10 second hand nokias. (or other phones as long as they ar not HTC
HTC = old chinese proverb
How to TRICK Customers
Sep 24, 2008 | HTC Touch P3450 Smartphone
Hanged
I read another entry and you have to hold down the red and green button and click your stylus into the bottom little button beside where you plug your phone in to charge.
It didn't fix my problem though which is similar to yours.
Sep 21, 2008 | HTC Touch P3450 Smartphone
HTC S 710 dropped in pool
will the buzz you herd was its insides of the battery was geting power to it but the battery was hit by water so the buzz was the water sizzing and so what I wood do is by a new HTC S710 battery and get rid of the old one!
by: nick houle
Jul 11, 2008 | RIM BlackBerry Pearl 8100
Lock code
HTC X7500/7501-(ATHENA/ADVANTAGE/Dopod U1000/T.Mobile AMEO)
Slide the Volume slider down and at the same time, use the stylus to press the RESET button at the back of your
device. After a brief period of time, two choices will appear on-screen. Press the CENTER OK button to perform the
hard reset. (Otherwise, if any, press the CAMERA button to exit.)
or try with this link...
http://www.efsoft.it/resetdev.htm
Jun 09, 2008 | HTC Advantage X7500 Smartphone
HTC Touch P3450 Smartphone Logo
1,195 people viewed this question
Top HTC Computers & Internet Experts
Justin
Justin
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
