Question about Amana ABB1927DE Bottom Freezer Refrigerator
Refrigerator will not get cold, but freezer works
2 days ago, the frigerator stopped cooling. the freezer is working fine. it is a top mount frost proof fridge/freezer. it will be 3 years old this month. the first 3 months after we bought it, it stopped working 3 times. i know of one time it broke, it was because the defrost timer was bad. (within the first month of having it) so....any suggestions? or advice? I have a top/bottom freezer on bottom. freezer works fine, fridge is warm. Unplugged for hour and plugged in... no difference ???
  • Anonymous Apr 17, 2009
    freezer works but has alot of frost build up,top refrigerator is warm . I think it is not defrosting , how do you fix that?
  • 150 Answers
Make sure your fan is working ,its located behind the freezers back wall. If it is working the vent from the freezer down to the refrigerator may be blocked (usually with ice).With out a fan you have no circulation but your freezer may look likes its working,it may last 3 days.Also if you can move everything out unplug it turn it off w/ doors open untill all traces of ice are gone this will free up any clogged tubes. Good luck.
Len West
Posted on Feb 27, 2009
2 Suggested Answers
  • 159 Answers
SOURCE: refrigerator will not get cold, but freezer works
Do you know if the compressor in the back is running? If you can check that out get back to me and we can go from there. Most times if the fan in the freezer is running the defrost timer is ok.
Posted on Jul 12, 2007
Fridge isn't staying cold, the freezer works OK.
if your freezer is working fine and you hear your compressor running you could have a frozen drain tube or more than likely the evaperator motor fan has failed.this is the fan that circulates the cold air from freezer throughout frigerator.what kind of unit is it?side by side or top mount freezer or what?let me know
Dec 25, 2012 | Refrigerators
Why are only drawers in fridge cold & not making ice?
Contact a professional. Sounds like either your damper door is not operating correctly and not letting enough cool air from the freezer enter, or there is an air leak that is making ice form .
Aug 12, 2012 | Frigidaire FRS3R5EMB Side by Side...
Frost (ice)forms on back of freezer and the refridgerator area does not get cold. If I turn off for a few hours it works for a couple of days Thanks
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 07, 2011 | Frigidaire 16.5 Cu. Ft. Top-Mount...
I have a GE side by side refrigerator, model GSL85JFPHBS. It sstopped working altogether last month. first the refrigerator stopped working, two day later the freezer part stopped working. I had someone...
I think you meant you have a GSL25JFPHBS (not 85).
It sounds like you have a defrost problem. If your refrig. was off for some time, like a day or more, or it was manually defrosted, it would work for about 2 weeks before the problem would re-occuer. This is caused by a build up of frost on the cooling coils, preventing air flow over them. Un-load the freezer and remove shelves and the back wall inside the freezer. Melt the frost with a hair blower, and replace the defrost heater (part # WR51X10055) and for good measure, replace the defrost thermistor (part # WR55X10025) located at the top of the cooling coils.
Mar 21, 2011 | GE Refrigerators
We have a lg gr-s592gt and we noticed the frezer is working fine but the fridge wasnt cold. i noticed that the two fans that controller the temp in the fridge arnt working but everything seems fine , this...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Ice build up and stops the fans...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 11, 2010 | Refrigerators
Top mount freezer won't cool, fridge works fine.
check for compresor operation. a relay on compresor could be out
Feb 10, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Warm frigerator
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Jun 14, 2008 | Frigidaire PLHS237ZD Stainless Steel Side...
Jul 09, 2007 | Amana ARSE66MB Side by Side Refrigerator
Amana ABB1927DE Bottom Freezer Refrigerator Logo
1,318 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
