Back to:
Tags:
Cakewalk Project5 Version 2
Midi keyboard octave problem
By paulrmc - usenet poster
I have a 61 key Yamaha PSR-310 so I can play soundfonts on my computer. I'm
trying to get the keyboard to go down an octave. The keyboard manual says
the octave button on the keyboard is not transmitted through MIDI so its
inoperable. I tried using the 'course pitch' on Vienna to set the soundfont
down an octave but doing that dulls the sound of the font. Is there a way I
can reassign the keys to go down an octave? My keyboard is stuck in that
middle range (keys 37 - 98).
I'm hoping I won't have to buy another keyboard.
thanks
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 02, 2007
Thanks for Trying (70)
lawyer
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
"Mike" < ...
Are you using the Creative "keyboard" application to play the soundfonts?
Or Vienna? If I use, for example Steinberg Cubase, using my MIDI keyboard as
the input and the SBLive card as the output, Cubase can handle transposition
in real time.
Maybe you can find a cheap or freebie MIDI sequencer which has this
feature (I guess it should not be so uncommon) to use when playing with
soundfonts. It would also let you record what you play...
Vienna is designed more as a soundfont editor than anything else
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Midi keyboard octave problem:
I don't want to Accept this solution
Solution #2
Not Rated (0)
Hart
Rating: 0%, 0 votes
"Mike" < ...
Hmmm - thats a lot of money to have spent on sequencers that you dump in
favour of Vienna
Thank You!
Solution #3
Not Rated (0)
pawa
Rating: 0%, 0 votes
"Jeffery S. Jones" < ...
Right - my keyboard works kind of like that. The message from the octave
button itself is not sent via MIDI but if I press it, it changes the note
information sent from the MIDI output by one octave when I press keys.
Thank You!
Solution #4
Not Rated (0)
Brad
Rating: 0%, 0 votes
I thought that the octave button changed the key range on the
keyboard? It isn't transmitted through MIDI, it merely changes a
parameter on the keyboard itself. If I remember that model right, it
changes it to one of several ranges, depending on how many times you
press the button.
Most sequencers handle input transposition easily. Cubase, Sonar
(Cakewalk), Powertracks -- most of them do, just check around. There
are also separate software utilities to do the same thing -- changing
the note number in the MIDI message is pretty trivial.
But I'd check out the keyboard features, see if it has an option for
key range transposition.
Jeffery Jones| *Starfire* |
** Muskego WI Access Channel 14/25 <# *Starfire Design Studio* <#>
Thank You!
Solution #5
Not Rated (0)
Pasty
Rating: 0%, 0 votes
I'm using Vienna to play the soundfonts. I have Cubais VST 4, Sonar XL,
Project 5, Cakewalk Studio 2004 installed but I have to figure out how to
load and play the soundfonts. Since I'm new to this all this software is
confusing.
Thank You!
Can you Help with these Graphics Publishing and Multimedia Software problems?
hi, until a while ago I could use Flash Player but one day...
sound driver is can' t so please give ur solution
Cakewalk Project5 Version 2 (787537911008)
first track will record then the other tracks will be...
I cannot locate the midi keyboard controller in project 5...
i just had to set up cakewalk on a different laptop. the...
Loading problems.
Repair Service
Find Graphics Pub. Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
