Question about Legacy LA938 Car Audio Amplifier
Over heated i was listening to my subs and all of a sudden the amp stoped working. any way to reset it?
  • sk8tr5 Feb 28, 2009
    it doesn't smell burnt
    k the fuse burnt out.
    where can i find a replacement?
  • 32 Answers
Check you fuses.if it got to hot it cooked..does it smell burned?
Posted on Feb 27, 2009
The subwoofer output on my Kenwood VR-606 has suddenly stopped working. I have tried the "setup" several times, turning the subwoofer off and back on. Also, when I first power up the system, it emits a low...
It sounds like the problem is not with your VR-606. If you hear a hum from the sub, the problem is more likely to be in the sub's built-in power amplifier. However, it is worth resetting the amplifier to factory presets. To do this, unplug the power cable from the mains supply and reconnect whilst holding down the power on/standby key. If the hum persists, connect any powered speaker to the sub-out socket, power on and listen for the hum. If no hum then suspect the powered sub amp. Turn the sub on with no connection to the Kenwood VR-606. If hum persists, the sub has a problem and will need to be replaced or repaired. By the way, you said there is a low frequency hum through the 'speakers' for about 30 mins. Is that all speakers or just the sub? Hope this helps.
Cheers, Don.
Jul 06, 2014 | Kenwood VR-606 Receiver
I was listening to my stereo system in my car and all the sudden all the speakers stopped working and the sub has a constant and quick vibration. I disconnected the sub but the other speakers still...
check the out put of the head unit . check the out put on amps check speakers do this all with a DMM Digital multi meter, check that amps aren't in protect. check ground on head unit. if you dont know how go to you tube and type in such as, this how to test speakers with a DMM many videos on all subjects.how to test amp out put with the humming you may have a short or a blown speaker some where.
May 03, 2013 | Car Audio & Video
Subwoofers don't work
the voice coils are probably fried. you may want to check your amps to see if they are putting out dc voltage. you may be abel to find a place that can fix the subs. otherwise you will need to replace them.
May 06, 2010 | Sony 12" Single-Voice-Coil 4-Ohm Subwoofer
Sub keeps loosin bass
Its probably not your subwoofer- its likely that your amp is showing its age after 2 years of bumping -But it could be that you have partially roasted the coil on the sub which is tripping your amp into protect mode-thus shutting down throw a different sub in there for a week and listen to it and if it stops acting up then its probably the sub if it still shuts down then it may be time for a new amp
May 29, 2009 | Fusion FEW12PK Car Subwoofer
Audiobahn 15s smell and stoped working
google "subwoofer wiring diagram" that will help you out,....you put in how many subs, DVC, SVC, and the ohms of the subs.....good stuff to know b4 hooking up a system....hopefully you didnt fry your subs or amp.....let me kno.....
Mar 14, 2009 | DHD NTX-6612 Car Subwoofer
Car Amp is on but not powering my subs
yes..ur assumptions r right..it cud b the rca jack or a bad wire..check the connection as it cud hav gone loose due to car vibrations.also check the fuse of the amp.
Thanks for using Fixya
Have a nice day!
Mar 13, 2009 | Car Audio & Video
What would be the ideal amplifier for these subs?
i have the same subs. i am running a total 500/1. i would say not a good idea, just today i was listening to bass mechanic and i could smell the voice coils heating up. so probaly a 300-400 watt amp would be good. just make sure it is a true wattage amplifier. not a cheap amp. pioneer amps that walmart sells are actually good amps.
Jun 23, 2008 | Dual XNBP12D Car Subwoofer
Car amp ( fusion fp-1002 powerplant ) is fried
blown capacitors. take to a friend or electronics repair that can replace with better capacitors. had same problem with an old comp 1200 amp. friend of mine replaced with better capacitors and wooohh mamma!
Feb 25, 2008 | Car Audio & Video
Amp and subs just stoped working
Sometimes power problems are not visible. Did you check the voltage at the amplifier with a multimeter?
Dec 13, 2007 | Sony Xplod XM-554ZR Car Audio Amplifier
Legacy LA938 Car Audio Amplifier Logo
37 people viewed this question
Top Legacy Car Audio & Video Experts
Tygh Duval
Tygh Duval
Putter71
Level 1 Expert
Robert Little
Level 1 Expert
Are you a Legacy Car Audio and Video Expert? Answer questions, earn points and help others
