Question about Lexmark X5150 All-In-One InkJet Printer
Lexmark 5150 all in one printer fax copier
I'm having a problem printing from my computer. I can use the copier but the printer and I don't know about the faxing.
  • 1,800 Answers
Well a phone cable is required on the FAx connector plz use ur manual for more info!!
Posted on Feb 27, 2009
  • Jalal Sordo
    Jalal Sordo Feb 27, 2009
    well a phone cable is required on the FAx connector plz use ur manual for more info!!
Printer operates unexpectedly but soesn't draw through paper or print
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
You may also try to update your printer driver by visiting the Lexmark website. Select your operating system, download and execute the file.
Dec 08, 2011 | Lexmark Office Equipment & Supplies
The Fax driver was not installed when I installed the Lexmark X2500 all in one from online
If you still have the installation disc that came with your printer, please insert it in your computer hard drive to install the Lexmark fax software.
If you don't have the disc, please contact Lexmark Technical Support Center for additional assistance. Thanks.
Nov 11, 2011 | Lexmark X2500 All-In-One Printer
Before I moved, my Lexmark all-in-one printer worked perfectly, but after I moved, everything worked EXCEPT printing of an incoming fax. Everything sounds the same through the sounds the telephone makes as...
Please go through the following checklist:
  • Make sure to plug the telephone fax line from the phone jack in the wall to the Line port on the back of your printer. For more info, please refer to the Lexmark X125 User's Guide.
  • If you have an answering machine connected to the same fax line, be sure to configure it so that it answers first before the fax machine (e.g. if your answering machine picks up on the 3rd ring, set your fax to pick up on the 6th ring or more)
  • If the line has a voicemail feature, disable it or request for a distinctive ring from your phone company.
Sep 14, 2011 | Lexmark X125 All-In-One InkJet Printer
I have a Lexmark X1240 that I have tried to use the scanner (never used but 1 time-it was too slow) NOW i can find my manual & don't know how to use it. HELP! I can print, but not scan from it!...
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
4. Reboot your pc.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
Aug 26, 2011 | Lexmark C533DN InkJet Printer
I have a lexmark x2350 (all-in-one,2300 Series).In the troubleshoot ,said printer status ready.But when i try print,or take a print page text,i hear:printing started,printing complete,but the machine don`t...
Try to update your printer driver. Please visit the Lexmark website at http://bit.ly/qQJd8g. Select your operating system to download the file.
If that doesn't help, follow the steps below: 1. Disconnect the printer from your computer. 2. On your computer, go to Control Panel > Printers and Faxes. Delete the Lexmark X2350 print object. 3. Reboot your pc. 4. Once the pc completely boots up, reconnect the printer into the pc. Wait until your pc fully recognizes the USB connection. 5. To ensure the print object has been successfully created automatically. Go to Control Panel > Printers and Faxes. You should see a new Lexmark X2350 print object in the list. 6. Try to print again.
Jul 28, 2011 | Lexmark X2350 All-In-One InkJet Printer
Can"t get Lexmark 5150 to print off my computor
Yes - Computer need driver software for printer to print
Download Software drivers by click on the Lexmark x5150
Lexmark X5150
Jan 04, 2010 | Lexmark X5150 All-In-One InkJet Printer
Unable to load new cartrige in my hp 5150 printer
Open the unit to where you would normally access the printer cartridges. Unplug and after a minute replug the power cord. Printers are designed so that when the unit is open it stops at the middle so you can access the printer cartridges. Here is the manual for the 5150. There is a link on the left of the screen to give visual directions for replacing the cartridges.
http://www.viking-direct.co.uk/speciallinks/gb/vkg/source/DJ5150.pdf
Richard
Jul 07, 2009 | HP Office Equipment & Supplies
New computer won't print on old Lexmark 5150 printer
You can download the latest driver from lexmark.com .
May 05, 2009 | Lexmark X5150 All-In-One InkJet Printer
I don`t have the fax software
You can download it here:
http://downloads.lexmark.com/perl/downloads/downloads.cgi#
Mar 13, 2009 | Lexmark X5150 All-In-One InkJet Printer
Lexmark X5150 All-In-One InkJet Printer Logo
67 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
