Question about KitchenAid KSRS25IL Side by Side Refrigerator
I have a Kitchen Aid side by side KSRS25IL. The ice maker after
Filling the ice bucket freezes up.There is frost all over the ice maker and ice frozen in the bottom of the freezer. You can thaw the ice maker with a blow dryer and it will start making ice again.
  • 150 Answers
Sounds like you need to defrost.
if you can move everything out unplug it ,turn it off w/ doors open,you can put pans of hot water in the freezer to speed up the process 12 to 24 hrs this will free up any clogged tubes.After its completely defrosted Only turn it up to 4 or 5. Good luck.
Len West
Posted on Feb 27, 2009
I hooked up my refrigerator and the ice maker is not working.it's a kitchen aid superba kscs251
First make sure your water valve is working . If so , look for fill tube that fills ice maker to be frozen. If it is frozen , unthaw tube. If its not then replace the ice maker.
May 31, 2013 | Refrigerators
Kitchen Aid side by side ksra2scnss00 ice maker not working....Water dispenser is working fine
The simple solution for your refrigerator is to replace dual water control valve.For example if your model was the IKSCS25INSS the replacement part would be the=> W10247725 Water Inlet Valve It also could be your ice maker itself so if the ice slots ar empty fill with tap water and allow to freeze. If the ice freezes and drops into the ice bucket and then does not refill with water then replace the water control valve. If not then it nis possible the ice maker is defective and will need replaced.Not knowing the correct model number I think it wouls better that you call Repair Clinic at 1-800-269-2609 and they will be happy to help you find the correct ice maker. 2198597 Ice Maker Assembly Should you have any questions I will be here to assist you, Thank You, Sea Breeze
believe you have your model number wrong so I will give you this link=> product literature search
Oct 03, 2011 | KitchenAid Superba Architect KSCS25INSS...
I turned my water off when we left town for a month. After turning my water back on the ice maker has stopped working. Our refrigerator is a Kitchen-aid superba model and is approximately 4 - 5 years...
The issue is likely that the icemaker fill tube is frozen due to poor water pressure. You can use a turkey baster to thaw this tube which fills the icemaker. Make sure you use plenty of hot water because they often freeze back several inches!
Sep 11, 2010 | KitchenAid KSCS25FKSS Side by Side...
Freezer and icemaker freezes, jams.
I have run into this before and found it very helpful to re-level the refrigerator. By leaning the fridge back toward the wall about an inch helped keep the water and ice in the tray. Remember to remove items that block air flow in the freezer. Remove the ice bin and clean it then start over with the fridge leaning back a little. Hope this helps.
May 01, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Ice maker is frozen in a kitchen aid side by side
Try pouring HOT water into the ice molds to release the frozen cubes. Hopefully the ice maker will restart the cycle and get back to normal!
Apr 09, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice maker problems
If the ice bucket is over filling there may be a problem with the ice maker as this should stop making ice when the bucket is full. The ice in the bucket can freeze together just due to the weight of ice cubes . I suggest you check the ice within the bucket is all broken up and not frozen into big lumps
Aug 23, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
No Ice From Kitchen Aid
Mark, your water valve has screwed the pooch. Replace it. The part number is 2199838.
What's happening is this... the valve that fills your ice maker is by-passing a small amount of water. This water has to flow through that tube, right? When very small amounts (drop by drop) go through the IM fill tube, they flash freeze. Eventually they (the frozen drops of water) form a big block of ice inside the fill tube. This ice creates a blockage which creates back-pressure whenever the IM "calls" for water. The back pressure eventually blows the tube off of the connection behind the fridge.
You say that this happened over night... no way. If you look closely at the ice cubes that you IM has been making, you'll see that they are hollow. Hollow cubes means that your IM isn't getting enough water... (because the fill tube is blocked).
Tracy
Mar 15, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchen Aid Ice maker Stopped working
The ice maker has stopped working. The red led light blinks when the freezer door is opened. Any thoughts?
Nov 22, 2007 | KitchenAid Superba Architect KSCS25INSS...
Ice maker will not eject the ice.
I don't know if this is your problem but I had a similar problem and it was low water pressure causing the blades to freeze up. The valve on the water tubing leading to the refridgerator was not fully open and the tubing was kinked.
May 15, 2007 | KitchenAid KSRS25IL Side by Side...
KitchenAid KSRS25IL Side by Side Refrigerator Logo
264 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
