Question about Acer Computers & Internet
Acer 22 in monitor
Screen goes black after loading to desktop. Says no signal.
  • 2,229 Answers
From what you say, I'll assume you see stuff on the monitor like the BIOS info,and the Windows splash screen. Then it goes black.
This happens when Windows loads the video drivers for your video card. Up until that point, you are using generic VGA drivers. I would guess the drivers are corrupt and the video card just stops working when it tries to access them.
You'll need new drivers for your card (you'll need to determine that--you can ask me directly by clicking on my name if you need help there). Then you'll need to start your computer in safe mode and remove the video card from the device manager. Depending on the directions you have for your video card, you may have to tell the computer not to install drivers when you restart your computer, but run the install program first.
Posted on Feb 27, 2009
No signal pops up on the screen
make sure your cables are tight. make sure you have the correct input selected on your monitor. swap your monitor on the pc with one from a freind that works. this rules out your graphics card and the pc. if all of these are correct you probably have a bad video input on the monitor. you may need it repaired.
Dec 25, 2009 | Acer 22" X223w LCD Monitor
Screen comes on says Acer then No Signal, and goes out. if shut power off and then back on get same result.
This means the monitor believes it's not connected to the computer. Verify the cables first of all. Then try booting in safe mode (F8 key at PC startup) in order to verify that the PC is sending data to the proper video port (you might have a dual VGA / Digital output, for example, and the monitor might be connected to the wrong PC port). Quite often, a "bad signal" will be the same of "no signal"; and you can have a bad signal if the monitor resolution on the PC is set too high. This could happen if you installed a high-resolution capable monitor, and then replaced it with a not-completely-plug-and-play, lower resolution one. The PC would keep sending hi-res signals to a monitor which can neither interpret them, nor tell the PC "please slow down". To check this last possibility, reboot your computer while the monitor is ON. When PCs reboot, they usually drop back to standard VGA signaling, which all monitors understand. If the monitor abruptly comes to life and displays a boot screen, then goes No Signal again after several seconds, you've got a resolution issue; get in Safe Mode with F8 key at boot, and modify the screen properties (right-mouse button on the desktop, then Properties).
If everything else fails, try also connecting the monitor to another PC or laptop, to see if it works there.
Dec 04, 2009 | Acer AL2223W 22" LCD Monitor
Black screen
the broblem is either in the backlight of the screen or in the converter of this screen and you need one knowing electronics to change the backlight and check the board but it appers to be backlight
Nov 15, 2009 | Acer 22" X223w LCD Monitor
Monitor keeps losing the screen and goes black several times before it finally stays on
it happened may b due to inproper power supply.So check the monitor data cable & other connections also.
Aug 08, 2009 | Acer 22" X223w LCD Monitor
ACER 22" monitor flashes on at PC startup, then goes black
Your monitor has a bad INVERTER, look on eBay.
Jun 27, 2009 | Computers & Internet
Acer AL1916W pluged into lap top but can't get both to run.
Have you used the Fn button on your laptop and changed the video display Icon on the Blue Function keys. You need to change the display wait a few seconds for it to take affect. There are several modes try them all so you know how to use them.
Mar 20, 2009 | Acer AL1916W 19" LCD Monitor
After loading windows Vista screen says no signal
steve, i dont think there is any problem with monitor. restart ur pc in safe mode, change resolution to 1440X900.
Mar 02, 2009 | Acer AL1916W 19" LCD Monitor
Monitor goes to black and back on
MY LCD 22 ACER MONITOR GOES O BLACK AND I CAN'T SEE THE MENU
Nov 21, 2008 | Acer 22" X223w LCD Monitor
No Signal message displaying after screen goes black
Try loading drivers for the LCD monitor.Right click empty part of desktop>>Properties>> settings It should show monitor name instead of plug and play monitor on ---- Video board.Go to Advanced>monitor>driver on this screen.
Samir
May 06, 2008 | Acer AL2017 20" LCD Monitor
Computers & Internet Logo
162 people viewed this question
Brian Sullivan
Brian Sullivan
