Question about Garmin StreetPilot C330 GPS Receiver
Garmin C330 truns on, but buttons do not work
I have to press very hard to even get any response, but most of the time no response to the buttons.
Reset button does not help
It turns on and off just fine and battery is very good.
Unit is 3 yrs old
  • Alkaye Feb 27, 2009
    I took it all apart....sorry....all thats there are metal contacts and wires....could not get to the area under the screen... I also cleaned the screen becuase I know finger grease can create a problem...but it did not help...
  • 1,800 Answers
Well its the influence of humidty on the under buttons plz try take it apart and clean the under buttons witha brush and alchol medci.
Posted on Feb 27, 2009
My Garmin does not connect to sateliyes
Try Raising the antenna and then press the reset button when the C330 is on,this should restore the garmin, then: Make sure the C330 is fully charged and
I would try updating the C330 by connecting to to a usb port on your computer and then downloading Garmin Communicator. If that does not help then try contacting Garmin. I will attach a link to Garmin customer support. thanks for using FixYa
http://www.garmin.com/garmin/cms/site/us/support/supportcontact
May 05, 2011 | Garmin StreetPilot C330 GPS Receiver
The unit will not turn on, even when plugged into a power source. Unit was working fine a week ago. Garmin Streetpilot C330.
Have you checked the fuses in the power cable? There is a reset button under the front bezel. Try pressing that to see if your unit comes back to life too.
Cheers
Jul 19, 2010 | Garmin StreetPilot C330 GPS Receiver
Garmin won't turn on
I hope this helps, I had the same thing happen today. I noticed on the face under the word Garmin you can pop the face off and underneath on the right side is a reset button I held it down for 10 seconds popped the face back on and pressed the power button it came on. I hope this works for you.
Mar 20, 2009 | Garmin StreetPilot C330 GPS Receiver
My streetpilot c330 won"t shut off.
IT'S CALLED A FROZEN SCREEN...
2 OPTIONS
ONE, RESET IT !!! (See resetting instructions below)
TWO, let the battery die out!
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Mar 12, 2009 | Garmin StreetPilot C330 GPS Receiver
Display image has shifted, difficult to use
ok, first you will have to unplug the power and usb cables to remove external power. Secondly, place your thumbnail in the groove located under the Garmin logo on the face plate and gently pull off the face plate. Next, press the reset button for three seconds. Finally, connect the c330 to a power source using the power cable. the c330 should automatically turn back on and operate normally.
Please rate my response and have a wonderful nite.
Mar 10, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin c 340 froze- what do I do
This solution is for c330 but it should work the same...
It took a nap...
Jan 21, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin c330 gps will not turn on
try this just worked for mine
1.Under the face plate by the Garmin Logo.Use your thumbnail to remove the plate.
2.Press the reset button.
Information located on page 28 of the owners manual if you need a diagram.
Nov 14, 2008 | Garmin StreetPilot C330 GPS Receiver
Cannot upload update
Problem resolved. It seems to have taken several hours for gps to update.
Thanks anyway.
Jul 21, 2008 | Garmin StreetPilot C330 GPS Receiver
Failure to acquire satellite
To reset the unit, pry off the silver faceplate.
Turn the unit on using the power button on the right side.
Press the reset button that was hidden behind the face plate.
The GPS unit should restart, and display its software version.
Make a note of the software version in case you have to call customer service.
To acquire satellites make sure the GPS has a clear view of the sky.
For Garmin customer service, call 800-800-1020.
You can also go to this link for complete customer service info:
Garmin Customer Service
Good luck, please rate this response favorably.
Jan 24, 2008 | Garmin StreetPilot C330 GPS Receiver
No signal
Try and replace the antenna
Aug 11, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
41 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
