Question about ASUS M2N-MX Motherboard
I need drivers for the Ethernet Controller & SMI bus controller
I have a CPU that has a diferent manufacture frm the motherboard?
CPU - [ Intel(R) Celeron(R) ]
Motherboard - Asus PSN AX
I've installed Audio, Video, Graphic Drivers etc..
But I need to install the Ethernet Controller & SMI Bus Controller &
theres one more? (there are still yellow exclamation marks) I lost the driver cds so I need advice on what to download?
  • 1,800 Answers
Use the Everest ultimate trial version to update drivers
http://www.softpedia.com/get/System/System-Info/EVEREST-Ultimate-Edition.shtml
Posted on Feb 27, 2009
Ethernet controller
If your Ethernet hardware is built in to your motherboard go to your computer manufacturer's website or your m/b manufacturer's website and download the drivers from there. If you have a separate Ethernet card, go to the card manufacturer's website and download the drivers from there.
15.April.2014
May 12, 2012 | Intel Cpu Pentium Dual-Core E2180 2.0Ghz...
Need specifications for Intel PM-865G1 mobo
Specifications
CPU
• Supports Intel® P4 Northwood/Prescott/P4 Extreme Edition processors.(PCB v1.1 only)
• FSB 400(Northwood only)/533/800MHz
• Supports up 3.2GHz and higher speed
Memory Speed/CPU FSB Support Matrix
FSB\Memory clock DDR266 DDR333 DDR400 800 MHz YES YES* YES 533 MHz YES YES NO 400 MHz YES NO NO
• Intel® 865G Chipset
- Supports 800/533/400MHz Intel NetBurst micro-architecture bus.
- Integrated graphic controller.
- Supports PC2100/PC2700 /PC3200 memory.
- Supports AGP 8X/4X at 0.8V (AGP 3.0) or 4X at 1.5V (not support 3.3V) interface.
• Intel® ICH5 Chipset
- AC'97 2.3 interface
- 8 USB 2.0/1.1 ports
- 2 channel Ultra ATA/100 Bus Master IDE controller
- SMBus 2.0 support
- 2 serial ATA Host Controllers
- Integrated LAN controller
• Support 100(Northwood only)/133/200MHz
• Support 400(Northwood only)/533/800MHz Intel NetBurst micro-architecture bus.
• Supports two 64-bit wide DDR data channels.
• Available bandwidth up to 3.2GB/s(DDR 400) for single-channel
mode and 6.4GB/s(DDR 400) for dual-channel mode.
• Supports four unbuffered DIMM of 2.5 Volt DDR SDRAM.
• Supports up to 4GB memory size without ECC.
• One AGP slot supports 8x/4x at 0.8V (AGP 3.0) or 4x at 1.5V (3.3V is not supported).
• Three PCI 2.2 32-bit Master PCI Bus slots.
- Supports 3.3v/5v PCI bus Interface.
• One CNR slot
• Dual Ultra DMA 66/100 IDE controllers integrated in ICH5
- Supports PIO, Bus Master operation modes.
- Can connect up to four Ultra ATA drives.
• Serial ATA/150 controller integrated in ICH5
- Up to 150MB/sec transfer speeds.
- Can connect up to two Serial ATA drives.
• AC'97 link controller integrated in ICH5
• 6 channels software audio codec C-Media 9739A
- Compliance with AC97 v2.2 Spec.
- Meet PC2001 audio performance requirement.
- Can support SPDIF Out via 3-pin SPDIF bracket only.
• Intel 82562EZ
- Integrated 10/100 Ethernet MAC and PHY in one chip
- Supports 10Mb/s and 100Mb/s auto-negotiation operation
- Compliant with PCI v2.2, and LAN on Motherboard (LOM) standard
Apr 27, 2010 | Intel Motherboard
Not install
Go to the manufacturers support driver page. Put in your exact model computer and operating system. Choose drivers....look for the driver marked as a "chipset" This will most likely have what you are looking for. Download the file and click onit, it will self install.
Sep 11, 2009 | Intel Motherboard
I82801@P4BGV-MX audio ctrler invisible in devmgmt.msc
open device manager and i m sure that it will be given under system devices because all the devices that does not come under
unidentified devices are in the system devices list check it there or instead use some software like driver detective to find all the devices connected to the computer and get their device drivers
Jul 08, 2009 | ASUS (P4BGV-MX) Motherboard
Ethernet controller problem
Find the network card manufacturer, and get those drivers. That is what you need
Jun 11, 2009 | Intel Motherboard
I need the motherboard manual for p4m266823x
I need driver VIA P4M266-823x, help me please!!!
Jun 10, 2009 | Computers & Internet
XP Pro reformat and lost drivers.
Just visit Foxconn's support website. They've got them all. just google : foxconn
and use common sense.
Feb 20, 2009 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
Hi I am ERION
Hello ERION,
this is your lucky day... we both have the same make and model of motherboard. i downloaded mine on the link below.
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=2229&OSFullName=Windows*+XP+Professional&lang=eng&strOSs=44&submit=Go%21
you can find all the drivers you need in this link.
hope you find this post helpful... :)
Jul 30, 2008 | Computers & Internet
How do I down load ethernet controller, PCI Device, SM Bus Controller, video Controller (VGA Compatible) & other devices driver
if you want to download from the same PC then you cant as the Ethernet driver will not be installed ..
if it is installed then you can download ....
check it in the
control panel>system(switch to classic view in case of XP)> hardware>device manager
in device manager go to network adapters there if the Ethernet driver is installed then you will be displayed there (if the driver is not installed then you will not see that network adapters also)
if it is not installed then you must download the Ethernet driver from some where else to your system from your manufacture(motherboard or chipset manufacture) website (if it is intel then http://downloadcenter.intel.com in this website you can search it & download)
if you have the Ethernet driver installed then you can download from your system only the other drivers from the manufacture website ....
any doubts you can reply me
i am always here to assist you
thank you
bye
rate my solution as per your satisfaction
Jul 04, 2008 | ASUS P5PE-VM Motherboard
Printer Driver and Manual for a Canon MultiPass C3000
yedya gandichya driver cd sambhalta yet nahi tar printer kashala gandit ghalayla ghetlas
Jan 03, 2007 | Canon MultiPASS C3000 All-In-One InkJet...
ASUS M2N-MX Motherboard Logo
383 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
