Over time the automatic document feeder (ADF) will get dirty, occasionally causing vertical black streaks or lines in scans and copies .
Manual cleaning of the ADF might be necessary. Follow the procedure below to manually clean the ADF .
You will need the following materials:
Soft lint-free cloths
Glass cleaner
if you look carefully on the left side of ADF ( top feeder ) there is an assembly which u can lift , there wud be a set of rollers if u lift that part there would be a glass strip . u are suppose to clean that strip .
While holding up the inside of the ADF, clean the glass in the location of the vertical streak with one of the cotton swabs. Try cleaning the glass first with a dry cotton swab. If that does not correct the problem, then moisten the swab with glass cleaner .
If the vertical lines or streaks still appear, go through the above cleaning process again, this time cleaning the entire surface of the ADF scanner glass.
and after this try the following steps as well .
CAUTION:
Use only glass cleaner. Avoid abrasives, acetone, benzene, and carbon tetrachloride, all of which can damage the scanner glass.
Found the problem. The glass of the ADF has a scratch in it. Is it repairable?
