Question about Brother HL 1440 Laser Printer
Brother HL 1440 Laser printer-horizontal black streaks
This printer has worked great for years, but today it suddenly started printing big black horizontal stripes all over the page.
  • 114 Answers
Check your drum may the corona ware is broken . change the drum.
Posted on Jul 18, 2010
Brother HL-1250 owner's manual
Three Horizontal lines indicates a 'Light Burnt Drum'. The drum units are light sensitive. If they are left in the light too long they will be affected and it will show as black horizontal bars. The number of bars really depends on the circumference of the drum some are 2 some are 3 some can be 5 etc.
Solving this you can only replace the drum unit. Check with your local remanufacturing outlet to source a replacement drum unit at a price WAY better than buying new.
Apr 02, 2014 | Brother HL 1440 Laser Printer
Stopped printing envelopes in proper direction
What software are you printing from? It sounds more likely to be software causing the issue.
Sep 05, 2007 | Brother HL 1440 Laser Printer
What is the cause of problem where my printer (HL 1440) prints with black smudges & streaks of ink on the paper.
sounds like a possible problem with possibly the drum or the transfer belt. trying a different toner cartridge may fix the problem but it may not. Most likely given the cost of repair, replacement may be your best option.
thank you,
Lee
Jun 09, 2011 | Brother HL 1440 Laser Printer
I have a Brother HL 1440 Laser printer & I've put in a new toner cartridge. When I try to print, I get 1 line of symbols at the top of the page. I haven't replaced the drum in 10 years...could the...
The first thing I would try is to fix the corona wire. Here is a link to Brother's website outlining the process (clean corona wire).
What you need to do is pull out the drum and look for a blue tab on the top of the cartridge. Slide that tab back and forth along the wire and see if that clears things up.
I have had some luck cleaning the drum when I get black streaks but I have also hear this can be dangerous and make the problem worse.
http://welcome.solutions.brother.com/BSC/public/us/ca/en/faq/faq/000000/000200/000008/faq000208_022.html?reg=us&c=ca&lang=en&prod=mfc7340_us_as&Cat=7
Jan 31, 2011 | Brother HL 1440 Laser Printer
BIG BLACK STREAK ON PAPER
If you're experiencing horizontal streaks, and already tried changing cartridges but that don't help, look in the bottom of the paper tray. If that small metal ground terminal gets ditry or bent, that could be the cause.
May 08, 2009 | Brother HL-2070N Laser Printer
Brother 1440 laser printer. Started printing with
may some dust in corona ware or drum clean the drum.
Apr 06, 2009 | Brother HL 1440 Laser Printer
Black horizontal lines in printout
Seems like the drum needs changing. This is the most common cause for print problems in these printers. If using the high yield TN 6600 toner then you need to change the drum every 3-4 toners. If using the low yield TN 6300 toner then the drum will need replacing every 6-7 toners. Hope this helps
Nov 16, 2008 | Brother HL 1440 Laser Printer
Brother hl-1440 laser printer
Did you mean 'vertical' (from top to bottom) line rather than horizontal? If it goes 'straight down,' it has to be. I think so, otherwise the added info that it is closer to the right wouldn't make sense.
This problem is normally due to contaminents on the surface of the drum itself although can also occur if a wire that discharges the excess toner from blank areas could be dirty.
Changing the drum cartridge will correct either of those problems since they are contained in the drum cartridge. If you are using 'recharged' cartridges and it only has a few copies on it, most companies will exchange it for you.
Oct 23, 2008 | Brother HL 1440 Laser Printer
Won't turn on
try the fuse in the plug
Apr 26, 2008 | Brother HL 1440 Laser Printer
Brother HL 1440 Laser Printer Logo
1,374 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
