Question about IBM Infoprint 40 Laser Printer
Reset toner counter on IBM Infoprint 40
I've replaced the toner in our Infoprint 40 but each job sent to the printer still says 'low toner.' How do I reset ther counter?
  • 624 Answers
SOURCE: IBM INFOPRINT 1120
Julie1665, Here are some things that could be causing your problem: -Could be the paper you are printing does not meet the printer specifications. -Could be toner leaking out of the cartridge. -Could be environmental issues, too hot or cold or humid. -The toner density could be set too high. -The electrical contacts that connect the toner cartridge to the printer could be dirty or just not making good contact. -the printer power supply could be defective. -With regards to your toner cartridge are you using new IBM cartridges or refilled/remanufactured? I?ve had many customers call me to fix a printer problem that turned out to be a bad cartridge. All of these are within the capabilities of the typical user except changing the power supply. Let us know if you have any other questions and please don?t forget to rate this post.
Posted on Feb 23, 2007
SOURCE: resetting IBM infoprint 1552 maintenance counter
Go Here: it's a PDF file which explains how to reset the printer's maintenance count.
http://www.marketpoint.com/files/pdfs/mk_ibm_1532.pdf
Posted on May 15, 2008
SOURCE: system requirements for ibm infoprint 1422
not supported
Posted on May 01, 2009
  • 32 Answers
SOURCE: IBM infoprint 1312 toner and error light.
If both Lights are solid, it means that the top cover is still open and the toner is low. Please make sure the top cover is closed all the way. If the toner light is blinking and the errror light is solid, it means there is a toner cartridge error. Please try a new cartridge. If that solves the issue, then you should return the damaged one.
Posted on Jul 24, 2009
SOURCE: I just installed a new
IBM infoprint 1622 - Photoconductor
When replacing a photoconductor on an IBM infoprint 1622 you must follow these following steps to reset the counter.
1. Open up the printer front cover and Install the photoconductor. 2. Close the cover. 3. Turn the printer off. Press and hold the 'Select' and 'Return' buttons, then turn on the printer. 'Config Menu' should appear on the display. 4. Press 'Menu' until 'Reset PC Cnt' appears. Press 'Select'. 5. Press 'Menu' until 'Exit Config Menu' appears. Press 'Select'. 6. Open the front cover. 7. Press and hold the red 'Cancel' button with the triangle on it for 3 seconds. All the lights should then cycle. 8. Close the front cover. The Photoconductor Maintenance counter is now reset.
Posted on Jul 27, 2011
Why is it displaying 'low toner' message?
have you check the expiry date of the toner
Nov 06, 2015 | IBM Infoprint 1532 Laser Printer
I just installed a new photoconductor into my IBM InfoPrint 1622 and I need to reset the page counter and the instructions have been lost. I need instructions on how to reset the counter.
Feb 21, 2011 | IBM Infoprint 1622 Laser Printer
IBM INFOPRINT SAYS IT IS READY BUT WHEN SENT A PRINT JOB DOES NOTHING
hmf..insturctions or send it back and get another one have the ricept (sorry im italian) sned it back
Jan 02, 2011 | IBM Infoprint 1572 Laser Printer
1422 Printing fades with use.
The only reason shaking would help, is if there was low toner or a problem with the toner cartridge, so "yes" it is the Cartridge(s) causing the problem.
Jan 20, 2009 | IBM Infoprint 1422 Laser Printer
Factory reset for IBM Infoprint 1412
open toner door, press and hold stop button whilst powering on printer. or Telnet into printer i.e telnet <ip addr> then use command 'set http on' then 'save'
Jul 13, 2008 | IBM Infoprint 1412 Laser Printer
Error Light
The error is "toner cartridge error" you could try cleaning the contacts inside the printer (with the power off, of course). If that doesn't work you will need to try another cartridge.
Jun 14, 2008 | IBM Infoprint 1116 Laser Printer
Resetting IBM infoprint 1552 maintenance counter
Apr 22, 2008 | IBM Infoprint 1552n Printer
Mar 10, 2008 | IBM Infoprint 1312 Laser Printer
IBM infoprint 1312 toner light
open the toner door then press and hold down the stop button, whilst holding this down switch on printer and hopfully this will reset the page count, i think.
Jan 23, 2008 | IBM Infoprint 1312 Laser Printer
IBM INFOPRINT 1120
Feb 22, 2007 | IBM Infoprint 1120 Laser Printer
IBM Infoprint 40 Laser Printer Logo
167 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
