Question about Sunbeam Ultrasonic 81696 Humidifier
I need the rubber o-ring on the water fill cover for my Senbeam humidifier model 696 please help get this part. my phone # 320 269 9368
  • 3 Answers
Please call the Venta Customer service team.
1-888-333-8218
If you have proof of purchase the part ( cap) is covered under warranty. If you do not it will cost $13
Posted on Feb 27, 2009
Humidifier model 758.743303. How many gallons of water does it hold? Needing to put water treatment in my water don't know how much water it holds.
Use a container of known capacity, e.g., measuring cup or milk bottle, to fill the humidifier. When full, you can estimate capacity.
Jan 24, 2017 | Humidifiers
Water leaking from tank cap HM495
is the rubber seal in place on the cap or did you lose it could be a small crack where the threads are look for both , good luck
Mar 07, 2015 | Humidifiers
Wont run in unit lift out and lift level control works fine put it back in unit [ very tight fit] lift level control wont work
Hello.
The GE humidifier adds a continuous stream of cool mist intothe air, giving moisture to dry air due to cold weather or dry climate or tohelp those who desire additional moisture because of respiratory problems orallergies. Sold online and in many department or home retail stores, thehumidifier requires regular cleaning and maintenance for proper functioning andto help keep mineral scale or bacteria from growing in the humidifier. ·1 Connect the power cord on the GE humidifier firmly to a power outlet if thehumidifier is not working. Replace or reset the circuit breaker as necessary.Turn the power switch to "On" if there is power but the unit is notoperating. · 2 Fill thewater tank to the "Fill" mark if the mist output is low or notpresent. Wait 15 minutes after filling the tank and before starting thehumidifier to allow the wick filter to absorb the water for proper function.Turn the humidistat knob to a higher setting for higher output. · 3 Check the capon the water tank and close the cap firmly. Check the rubber tank cap ring onthe cap and reseat firmly to help provide a better seal. · 4 Replace thewick filter with a new wick filter, available through General Electric, if thewick filter inside the base turns brown. Replacement parts may be ordered bycalling 877-207-0923. · 5 Clean thewater tank with vinegar and a soft brush if the water begins to get cloudy.Rinse well before refilling with water. Use cold water in the tank, as warm orhot water may make the water appear cloudy. · 6 Loosen thetank cap slightly if the humidifier cycles on and off unexpectedly. Turn theknob to a higher or lower setting. Thanks.
Sep 09, 2011 | Sunbeam Humidifiers
I love the 696-3 humidifier but cannot find another on any suggestions?
Well, that's going to be difficult to do, as the 696 models have been discontinued. However, on the up side, parts are still somewhat available through a number of sources.
Sorry I didn't have better news for you.
Apr 21, 2011 | Sunbeam 699 Humidifier
How do you fill the venta humidifier I don't have
http://www.appliancefactoryparts.com/content/pdfs/123738.pdf
Fill Water Tank.
Turn off humidifier and unplug the power cord from A/C outlet. Remove tank from
base. Turn upside down and unscrew filling cap. Fill tank with clean, cool, distilled,
filtered, or tap water. Do not attempt to fill unit through Vapor Nozzle. Water temperature
should NEVER be too hot or too cold. Extreme temperatures can damage the
unit. Tighten filling cap firmly. Return tank to base and let it sit for a few minutes. For
first time use or when replacing the demineralization cartridge filter, please soak the
filter in warm water for several minutes.
Dec 24, 2010 | Venta Airwasher VS 207 3.7 Gallon...
Honeywell HWM 450
I found a solution to our problem with the fill cap failing/leaking. It was/is not the cap, it’s the gasket/grommet/o-ring. Remember “THE MAGIC BULLET”, well the gasket, that’s where you tighten the top to the bottom, some are white and some are black, THEY FIT the Honeywell HWM450!!! ------- Problem solved.
SEE EBAY: NEW AUTHENTIC MAGIC BULLET 4 REPLACEMENT GASKETS SEALS
Dec 31, 2009 | Honeywell HWM-450 4 Gallon Humidifier
Vicks V3100 1.2 Gallon Humidifier leaking
Check if the cap has a gasket or o-ring and is not worn. There are two designs for this model. The older model has the fill cap and valve together. The new design the fill cap and valve are at different locations. The new design has no hole in the bottom of the unit.
You can fixed the problem using a 1-1/2 inch washer for brass tubular found in the plumbing isles in HD or L. The rubber washer is 1 or 2 mm smaller then the grooves in the fill/valve cap. You can stretch the washer and it will fit perfectly in the grooves. When putting the fill/valve cap back with the washer, it will be tighter then before. Firmly turn and you should not have any leaks and make sure unit is level. You can plug the hole because the new design does not have a hole in the bottom of the unit.
Nov 28, 2008 | Vicks V3100 1.2 Gallon Humidifier
Sunbeam Ultrasonic 81696 Humidifier Logo
192 people viewed this question
Top Sunbeam Humidifiers Experts
Oloyede Monsuru
mike
Are you a Sunbeam Humidifier Expert? Answer questions, earn points and help others
