Question about Kensington PocketMouse 72214
Mouse does not move cursor -Kensington mouse and latitude laptop
I was having the same problem on Windows 7 and thought it might be a software issue. But then I found an online manual for the Kensington 72214 and got the solution.
You need to make sure to establish a wireless connection between the mouse and the USB receiver by first pressing the connect button on the end of the USB stick and then pressing the connect button on the bottom of the mouse. It is not simultaneous - do step one then two. This also has to be done any time your replace the batteries.
Here is the manual: http://files.acco.com/KENSINGTON/K72214/K72214-4697.pdf
Posted on Jun 02, 2010
  • 80 Answers
Probably the device driver is not detecting. unplug it and connect it to a different USB port and try. if that doesn't work assuming you are using winXP, then go to device manager check to see if there is any exclamation mark next to the mouse. If so then uninstall the driver and hit refresh. that would auto install the driver. if that doesn't solve the problem, then you probably change the mouse. it got defective.
Posted on Feb 27, 2009
My cursor will not move using the mouse pad on my Dell latitude 3330
If you have an external mouse, the mouse pad will be turned off.
There is a setting in the BIOS that allow both to function at the same time.
In windows control panel, there is an item to enable (the been disabled) mouse pad.
Aug 22, 2014 | Computers & Internet
Cursor doesn't move, but the mouse is "on"
Remove the battery of the mouse and install new one and then press connect button from the mouse side and the receiver side also.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Dec 11, 2011 | ACCO Brands Kensington Ci60 Mouse
Cursor tend to go spastic when I touch the keyboard on my Dell
hi,
I had this problem and it was solved by turning off the touchpad in the bios,
Pressing the f10 ? or f2 ? during startup will get you into the bios
are you sure the mouse is ok ?
Regards
GeWiz.
Dec 10, 2009 | Dell Latitude D800 Notebook
Stuck cursorDell Latitude D600 laptop.
using touchpad or external mouse..I would check into updating the drivers for the mouse
www.aa1consulting.com
Jul 26, 2009 | Dell X2033 - Latitude D600 D500 Inspiron...
Dell latitude d820 xp: Mouse inputs are moving
Mine did that too, its normal, the actions undearneath maybe stuck just a little and thinks it is required to move when not
Jul 15, 2009 | Dell Latitude D820 Notebook
Dell Lattiude D600 cursor locked in middle of screen - even after we turn on and off - no way to do anything because cursor won't move - not even little blue mouse in the middle of the screen
Try booting up after installing an external USB mouse. This may give you a mouse to install new keyboard drivers.
If the problem is the keyboard/tracking pad, (hardware) installing another keyboard may eliminate the issue.
Jun 14, 2009 | Dell Latitude D600 Notebook
Mouse or cursor mania
replace the mouse in at local shop they can order parts or but extrnal usb wilress mouse ok
Feb 01, 2008 | Dell Latitude D600 Notebook
My mouse dose not move
There is a connect button under the mouse.
and there is a button on the reciever. Please press both the buttons together for 2 minutes and after this it is supposed to work. However if it is not working replace the battries and do this sync process again.
If still not working contact kensington support they will replace for you.
click on the link below to contact through email.
http://kensington.custhelp.com/cgi-bin/kensington.cfg/php/enduser/ask.php?p_cat_lvl1=8
Regards,
Mohammed
Regards.
Mohammed.
Nov 24, 2007 | Kensington 72219 Mouse
Kensington Pilotmouse Mini Wireless Model 72314
check batteries
make sure the mouse and receiver can 'hear' each other
Oct 13, 2007 | Kensington 72223 (72213) Mouse
Re: kensignton wireless mouse, connected but not working
have you checked the battries in the mouse as the battries that com with the mouse don't last long and have you pressed the connect buttons on receiver and mouse as somtimes usb power receivers loose connection on laptops try this one. hope this works
Aug 13, 2007 | Kensington Mouse-In-A-Box Optical Elite...
Kensington PocketMouse 72214 Logo
1,778 people viewed this question
Top Kensington Computers & Internet Experts
dctocali
Level 1 Expert
Alun Cox
Are you a Kensington Computer and Internet Expert? Answer questions, earn points and help others
