Question about Ricoh Aficio 3800CMF Laser Printer
Image bounce from copy to copy
I have a Ricoh 3800c which I print a lot of multiple copy jobs, the problem I am have is that the image shifts from page to page (if you place one copy on top of the other they do not line up).  Since this started the machine is also making kind of a clicking noise.  I cleaned the register roller and the sensor where the paper feed into the printer.
  • Bob Feb 27, 2009
    Do you know if this is an expensive repair? I have almost 200,000 prints on this machine, I was wondering if you think the machine is worth fixing.
  • Bob Feb 27, 2009
    Thanks for your help, I will call my service company.
    Problem Solver:
  • 13 Answers
Forget it friend... the ricoh 4 drum colour printer is already on its 4th or 5th generation... it was replaced by cl7000 cl7100 and cl7200... the main problem with its original engine on the 3800c was drum shifting and unstable transfer... they replace it with a sterdier frame and drum support shafts and inserted a independant motor on the transfer belt...amongst other things... the only soultion here is really replacing the whole machine
Posted on Mar 09, 2009
You have a registration clutch problem, you'll need a tech for this
Posted on Feb 27, 2009
  • Anonymous Feb 27, 2009
    depends on the labour rate and quality of the service comapany of course, but the part shouldn't be overly expensive and 1-2 hours labour -depending on how they charge.....certainly a lot less expensive than replacing a machine of this type and capability, which could easily be a few thousand dollars.
    It is aging, but parts and supplies are still readily available....good luck.:)
Print copy white
If the copies is whitw possible causes:
toner empty,not toner
developer drive transmission mechanism failure
image transfer current terminal poor intact
Feb 09, 2013 | Ricoh Aficio 2035 Copier
My Ricoh aficio 3800c keeps stalling with error code sc220-4. How do I fix it?
Hi. The SC220 issue is a known one on the 3800c. It's a firmware related problem, and the code, which points to the synchronizing detector boards, is erroneous. You can read more about it, and possible ways to avoid it here.
Updating the firmware to get rid of this problem is not an easy job.
Nov 07, 2011 | Ricoh Aficio AP3800C Laser Printer
MY HP LaserJet 2840 has a brand new Toner cartridge. Now it won't print at all and we are getting a "OPC at end of life" prompt. What does this mean?
Imaging drum reach 20,000 (black only) or 5,000 (color), replace the image drum.
Supplies life
The life of the imaging drum depends on the number of black-only or color pages that print jobs
require. Imaging-drum life is also affected each time the device calibrates because calibrating causes the imaging drum to rotate. Imaging-drum life is measured in terms of number of rotations rather than number of pages printed.
The type and length of print jobs also affects drum life. A series of short print jobs uses more drum
life than an equivalent number of pages printed in a single large job. To extend drum life, print
multiple copies of a print job at one time rather than sending the same job to the device multiple times.
The life of a print cartridge depends on the amount of toner that print jobs require. When printing text at 5% coverage, black print cartridges last an average of 5,000 pages and cyan, magenta, and
yellow print cartridges last an average of 2,000 pages. High-capacity cyan, magenta, and yellow print cartridges last an average of 4,000 pages. (A typical business letter has 5% coverage.)
Aug 18, 2011 | HP LaserJet 2840 Printer
Trying to find an operators guide tyo using a recho 3800c printer
Do you mean Ricoh 3800C if so see below webpage and download the guide
http://www.ricoh-usa.com/downloads/downloads.aspx
If page does not work copy and paste in browser!
Hope this helps.
Apr 14, 2011 | Office Equipment & Supplies
The colors and images are printing well, but there are black streaks when it prints, especially when printing multiple copies. It seems to get worse as it is used.
sounds like the drum or drums needs replacing or possibly transfer belt cleaning blade not doing its job worn out or spring fell of it. Most likeley to be a drum though.
i think they r 60 or 80 k life
Nov 10, 2010 | Ricoh Aficio CL7200 Laser Printer
I have a Ricoh Priport VT2250 duplicator. I keep getting an error
ls lt an image problem? image problem can be occurred if the solid black part of the image is on top. try to reverse the image by scanning it invert the image on the other side meaning the solid part be placed at the bottom.
May 26, 2010 | Ricoh Priport VT6000 Copier
HP Laserjet prints everything multiple times
Is it the same image being repeated ?
If so then it is the drum not the developer unit.
There is a device for discharging the image once it has been transfered to the paper from the drum.
If that is broken then the image is not cleaned off and will repeat.
The other thing to look at is your setup to make sure it is set at A4 and it is being told to print one copy per sheet
Jun 23, 2009 | Office Equipment & Supplies
Image is rotated
Select the correct paper size by rotating the green paper size selector in front of the papertray.There is two selection for A4 paper.A4 lengthwise and breadthwise.select it correctly
Aug 21, 2007 | Ricoh Aficio 2020 All-In-One Laser Printer
Ricoh Aficio 3800CMF Laser Printer Logo
139 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
