Question about KitchenAid 24 in. KUDI01FL - Multiple Color Built-in Dishwasher
The door to my dishwasher swings open to fast
When i open my dishwasher the door just slams down fast, unless i keep my hand on the door. This happened before when i was under warranty and a repairman came out and adjusted something with the spring or something, or i believe that a spring came loose and i need to fix it. Can you tell me how to do this. It is a kitchenaid style kudio1flblo if this helps
  • 360 Answers
You will need to bring the DW about 8-10 inches out from under the counter to access the door springs on the side of the unit.
Any questions, let me know
Please take the time to give this solution a fix ya rating
clarkco
Posted on Feb 27, 2009
The door just flys open and slams down with no support. Won't stay closed unless pushed in all the way.
I'm no sure why the door is flying open but it the door is falling without any tension, it sounds like 1 or both of the cheezy nylon lines that hold the door springs or their plastic accessories have bit the dust. Look at page 24 of your installation instructions if you have them. Shows what they look like. If you pull the dishwasher out, you will see them in the front on the lower left and right. Our dishwasher is 7 years old and they have broken twice now.
Nov 23, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
How do I install a friction pad?
Have you had any luck, mine have both broken, and my door opens fast, slamming down.
Apr 10, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
Repair door springs - LG dishwasher - LD-2040WH.
my lg door keeps on falling done something wrong with door springs ; how do i repair it.
Nov 28, 2009 | LG Dishwashers
Power drive side window will not go up passenage side works fine
NO COST and fast PROCEDURE TO (try to) FIX IT:
1. Sit in vehicle, on seat next to problematic window
2. Ignition key is on
3. Door in question is opened (in case you closed it)
4. While door is open, press and hold power window button in desired window travel, keep button pressed !!
5. SLAM hard the door closed with one hand while other hand holds button as per #4.
6. Watch window operate as it should.
7. Repeat 3-6 if necessary, but usually the first try works!
Oct 16, 2009 | 2003 Dodge Caravan
Driver sided power window not working
NO COST and fast PROCEDURE TO try to FIX IT:
Sep 27, 2009 | 2005 Dodge Caravan
My whirlpool dishwasher soap dispenser is apparently not opening during cleaning. I find dirty dishes and clumps of soap in the hopper. Whirlpool quiet partner II
I bet your clumps of soap began with the beginning of the use of a different DW detergent powder.
Try this (trust me) Go buy a box of brand name Dishwasher powder (e.g. Electrosol or Cascade) Use it for two loads of dishes and report your results back here. OK?
Apr 17, 2009 | Dishwashers
Dishwasher problem
Symptoms:
Dispenser lid is open. Caked powder at (what would be during normal operation) bottom edge of soap dispenser or caked powder fallen onto dishes or dishwasher bottom. There may be loose powder in rest of dispenser or spilled down inside door or onto dishes underneath dispenser.
Solution:
Keep the area around the soap dispenser lid clear when loading the top tray.
Explanation:
The soap dispenser needs to swing open during the wash cycle. In many dishwashers the top tray has an indentation as wide as the lid of the dispenser. This allows the top tray to be as large deep as possible while still allowing space for the dispenser lid to open. People often pack their dishwasher with things overhanging this gap.
During the wash cycle the catch will release but the overhanging cutlery or crockery prevents the lid from opening all but a few degrees. Some water will splash in but not enough to wash out the soap powder. The soap powder at the bottom of the dispenser will then cake.
When the front door is opened the spring loaded lid, which is partly open, will of course swing fully open and you'll be convinced that the lid opened normally during operation. If this is the problem then if you're very careful and open the door very slowly you can actually hear the lid flip open. Also, depending on when the lid opens, how far it opened during operation and how fast you open the door you may find soap powder spilled down to cover the dishes at the front or down the inside of the door. This happens when you first open the door and obviously there couldn't be loose powder there if the powder had emerged while there was water washing around. Seeing the lid open as you open the door is a lot harder but can be done on some machines.
Oct 24, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
KitchenAid Dishwasher KUDSO2FRSS
I recently had the same problem. One of the cords that attaches the door to a spring had snapped. I purchased cord replacments at the following URL and completed the repair myself. http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1059756&PPStack=1
Good Luck, Tim K.
Jun 30, 2008 | KitchenAid 24 in. KUDS02FRSS Stainless...
GE Monogram DIshwasher
Before taking anything to bits, check you aren't just loading the machine in such a way that something (for us, it's usually a frying pan) is stopping the soap dispenser from springing open all the way. A.
Apr 21, 2007 | GE 24 in. Monogram ZBD6880KSS Stainless...
KitchenAid 24 in. KUDI01FL - Multiple Color Built-in Dishwasher Logo
500 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
