Question about GE DBXR463EBWW Electric Dryer
Is it normal for the heat strip to pulse off and on ?
Is it normal for the heat strip on my electric dryer to pulse off and on every 15 to 30 seconds ?
  • 5,911 Answers
Yes. The heating element is controlled by an internal bias thermostat that regulates the temperature that you have the dryer set for. The heating element is not supposed to stay on continuously or the unit would overheat. The thermostat regualtes the internal temperature to prevent damage to the applaince and/or your clothes.
Posted on Feb 27, 2009
Dryer is cool not getting hot?
1. Close the dryer door and press the "Start" button for at least one second. Some dryer brands require the button to be pressed for several seconds. If the drum tumbles, you can eliminate the possibility of a problem with the electrical circuit that supplies the motor.
2. Check all the connections on the back of the dryer. Many dryers have two electrical circuits--one for the heat and one for the tumbling motor. If the motor works, but there is no heat, check to see if the larger plug is plugged into its receptacle. Your dryer may have two plugs--one small regular household plug and one larger 240-volt plug for the heat. Both must be plugged in for the dryer to work properly. The larger, three-pronged 240-volt plug will not fit in a normal household outlet; it needs a special dryer outlet. The plug cannot be cut down to fit.
3. Check the circuit breakers or fuse panel if the dryer runs but there is no heat.
Jan 14, 2011 | Maytag PYE2300AY Electric Dryer
Whirlpool electric dryer - looks like a WED5200T but no model number on the unit. The drum turns and air blows from the vent, but the timer has stopped working and there is no heat.
you have a white strip on the back of your dryer un plug your dryer first.....then un plug the strip and hook the two wires together that will allow the heat to start again.....the timer shouldnt have anything to do with the heat....turn it on and put your ear to the knob and you should here a clock sound if not your timer is bad
Nov 10, 2010 | Whirlpool WED5200T Electric Dryer
Coils get hot
Hi, as soon as you turn your dryer on, power is sent to these heat strips and they will glow red hot. This is normal. They will kick on and off through the drying cycle by several thermostats in the unit so it will not over heat. Nothing to worry about as you have 240 volts going to them.
Sincerely,
Shastalaker7
Apr 20, 2010 | Whirlpool LEB6300 Electric Dryer
Dryer will spin but not dry , heat element is fine
Try replacing the high limit switches if the element is fine. The limit switches will not allow power to the heat strips if they are blown. They are the little silver buttons on the heat strip. There are usually two wires connected to them one coming from the controls and one from the heat strip itself
Dave
Mar 05, 2010 | Magic Chef CYE4000AWW Electric Dryer
Whirlpool ler7646EQI Dryer runs for 5-10 seconds
sounds like u have a bad overheat sensor on the back on the electric strip housing and on fan housing they are round they are very cheap just take them off and replace both of them and that should fix your problem
Feb 25, 2010 | Whirlpool LER4634J Electric Dryer
Dryer wont heat up. It runs fine but no heat. Replaced the Thermal fuse"flat white with 2 wire terminals.
gas or electric ok gas replace gas coils check glow bar ignighter,check thermostates,,,,,,electric check power to both sides of wall outlet you need 220 volts and it will start and timer will advance on 110 vts second check second fuse looks like a thermostate normally located at top of heater coil call if you need to http://www.washerwizzards.com
Dec 24, 2009 | Maytag Neptune MDE5500AY Electric Dryer
The dryer doesnt get hot enough to dry clothes
Pull the dryer out and remove the lint hose . Turn on the dryer and feel if there is good air flow and if you feel heat . If there is good air flow and heat , dry a load of clothes , to see if they dry normally .
If there is not good air flow , then the blower wheel is probably stripped and needs to be replaced . If there is good air flow and heat , then the problem is in the vent ducting , between the dryer and to where it vents to the outside . Dryer could be pushed back too far , causing the hose to " kink " , restricting the air flow to the outside .
Remember , a dryer either heats or doesn't heat . If no heat , then a dryer problem exists . If heat , but dryer does not dry , then a vent problem is the cause ( except for maytag , which the blower wheel sometimes strips out ) .
Nov 08, 2009 | Maytag PYE2300AY Electric Dryer
My electric trips out when I switch the tumble dryer on
Sounds like the plug cord is wired wrong on the dryer, or the breaker is too small or going out. Or the heat strip could need to be replaced.You should have a 30 amp breaker for the dryer. Check the heat strip then your breaker.
Sep 02, 2009 | Hotpoint Dryers
Whirlpool dryer LEC8858EQ2
one of 2 things, over temp protection activating due to insufficient ventillation or motor is defective and heating up excessively.normally if both drum support wheels are worn or defective,plus if veld strip on drum is worn, motor will overwork and fail.
Nov 15, 2007 | Whirlpool LER5636P Electric Dryer
GE DBXR463EBWW Electric Dryer Logo
70 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
