Question about Canon PIXMA iP1600 Printer
Cant print My printer is plugged in the electric and is on line yet the machine says it is off line...........how do I get back on line????
    President:
  • 2,692 Answers
F9-88 code on arm317
F9-88 = Print PCB to Main MFP Board Comm Timeout
You can clear this by turning your copier off and then on. Try turning it back on with the network cable unplugged, run your machine, then plug the network cable back in. If the error code comes back, its: 1) bad network cable 2) ungrounded electrical plug for copier or router 3) noise on network line 4) copier needs firmware update 5) replace the print board
Apr 02, 2014 | Sharp AR-M317 Black and White Copier
How do you clean the copper parts of the cartridge
Turn the printer on and then fill the paper tray with paper.
If this is an HP printer, press the "Setup" key until "Tools" is shown on the control panel display screen. Follow equivalent steps for other printers by reading the user manual.
Press "OK." If your printouts continue to be faint, show white line streaks or smudges, go to the next step to clean the contacts on the print cartridge.
Open the print cartridge access door. Wait until the print cartridge moves all the way to the right side and completely stops.
Remove the power cord from the electrical outlet.
Press down on the top of the cartridge and lift it up toward you holding it by its sides. Avoid touching the copper area when you lift it out of its slot. Sit it down on a flat surface, such as a table.
Wet a lint-free cloth with water and squeeze out any excess.
Pick up the cartridge by its sides and avoid touching the copper area.
Gently wipe the copper contacts of the print cartridge with the dampened, lint-free cloth. Be careful not to wipe the copper nozzle part on the bottom of the copper cartridge.
Let the print cartridge dry for 10 minutes and then plug the power cord back into the electrical outlet.
Reinstall the print cartridge. If your printouts continue to be faint, show white line streaks or smudges, go to the next step to clean the nozzle area (copper bottom part of the print cartridge.).
Repeat steps 4 through 7 and then gently wipe the nozzle area with a clean, dampened lint-free cloth.
Let the print cartridge dry for 10 minutes and then plug in the power cord back into the electrical outlet.
Reinstall the print cartridge. If the ink is faint, or streaks or lines show on your printed pages, the old print cartridge may be defective and cannot be cleaned. Replace the old print cartridge with a new one.
*If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Feb 26, 2013 | Dell 966 All-In-One InkJet Printer
I received a fax and it was in line to print, but I cant get it to print and now it's gone - when the machine receives a fax, why won't it print?
Hello Dear.. Printing problem with your HP Printer, let try first, See if any light are flashing on the panel indicating red flashing light. then At the back take off the cover you will see a little handle on both side take off the cover and see if any paper is jam in the machine.. then put cover back...Then press setup push the arrow bottom up or down for menu choose inck level... See if you need to replace your Inc.
Oct 13, 2010 | HP PSC 2410 All-In-One InkJet Printer
MY HP DESKJET F335 ALL IN ONE PRINTER ISNT PRINTING. I KNOCKED IT OFF LINE AND CANT REMEBER HOW TO GET IT BACK ONLINE. I THOUGHT I WENT TO CONTROL PANEL, BUT CANT REMEBER WHERE AFTER THAT.
Right click on printer Icon, and select "Enable". First Unplug from PC, & Power, Put power back on, wait a minute, plug into USB, wait a minute, select Icon, Enable. Also you can right click the Icon, and select Properties too.
Feb 05, 2010 | HP Deskjet F335 All-In-One InkJet Printer
Paper jam occurred, now printer wont print.
  1. Press the On button to turn off the HP All-in-One.
  2. Unplug the power cord from the back of the HP All-in-One.
  3. Unplug the power adapter from the wall outlet and wait 30 secs.
  4. Plug the power adapter back into the wall outlet.
  5. Plug the power cord to the back of the HP All-in-One.
  6. Press the On button to turn on the HP All-in-One.
Feb 03, 2009 | HP Office Equipment & Supplies
Cant fax
Are you sure the FAX line is connected to a working phone jack and plugged into the correct jack (line not phone) on the machine?
Step by step FAX instructions can be found here on the HP website.
Jan 07, 2009 | HP Officejet 5610 All-In-One InkJet...
Cant receive faxes
First make sure your line cable is plugged into the correct place. Most Brother machines have a plug for Line and a plug for Extension (EXT), make sure it's plugged into "Line".
Go into the menu on your Brother machine and select Fax, then Setup Receive and then select Easy Receive. This will usually solve most recieve problems.
Brother machines come with s default of 4 rings before they will answer, make sure none of your other devices (such as an answering machine) are set to a lower number of rings or the fax machine will never grab the line.
If you have distinctive ring, make sure you have it set up in the machine. There is a section in the owners manual for setting up discinctive ring.
If the machine grabs the line and goes through the motions but nothing comes out on the page (no black print) then make sure you are using a Brother ink cartridge (not refilled or generic) and print out the test page using the "ink" button. Allow the machine to clean a few times and see if the test page prints out correctly. If you are using refills or a generic black, you might have premanently damaged the print head. In this case take it to a service centre to have the head tested.
Sep 10, 2008 | Brother IntelliFAX 4100 Laser Fax
Printer Off-line after a paper jam
ty, Unplug the printer from the electrical source for about 2 minutes. Turn-off your computer. Turn the printer back on and then reboot the machine. If the driver wasn't corrupt it should load. You may need to uninstall the printer and then re-install it again. http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=1128309&lc=en&cc=us&dlc=en&lang=en&cc=us This site will have the latest drivers. Good Luck, Tim
Feb 03, 2007 | HP Deskjet F340 All-In-One Printer
Canon PIXMA iP1600 Printer Logo
old marine
old marine
