Question about Kenmore Dryers
Kenmore 90 series dryer works but won't get hot
The dryer has been working fine for years, now it just blows cold air. Have a rental dryer plugged up in same spot and works fine.
  • markdpman Mar 09, 2009
    Thanks so much for your help, it led me straight to the probem. In these hard times it's nice to have information like this available to help save some money.
  • 5,911 Answers
The following link explains how to troubleshoot a dryer no heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
If the dryer is blowing cold air, and you stated that a replacement dryer works fine plugged into the same receptacle, you may have a problem with your power cord, or the internal heating circuits.
First, locate the terminal block at the back of the unit (this is where the power cord is installed) and plug the dryer back in. Verify that you have 220-240VAC across the two hot leads (RED and BLACK wires). If the voltage is not correct, you may just have a bad power cord. If the voltage reading is normal, you have an internal heating circuit problem.
Read through the link provided and let me know if you have any questions. If you require additional assistance, please let me know before you rate the solution. I hope this helps you.
Posted on Feb 27, 2009
  • Jeff Rockwell
    Jeff Rockwell Mar 09, 2009
    Glad you appreciated the advice and that I was able to assist you. Keep me in mind you need any assistance in the future.
I have a kenmore 90 series dryer, it was working fine last night but this morning it was only blowing cold air. I checked the dryer vent and checked the heating element and there are no broken coils. What...
check the thermal fuse on the blower housing,if its ok then some units have a heater relay located behind the control panel thats controlled by the moisture sensor board its in the center of the panel but without a model number i cant be sure if this one has it
Jul 17, 2012 | Kenmore Dryers
My Kenmore 90 series won't heat up. Only blows cold air. Why?
could be a saftey or a bad heater in the dryer
Aug 27, 2010 | Kenmore Dryers
Gas dryer starts blowing cold air after 5 minutes
This sounds like the dryer coils are failing. They tend to fail as they heat up. Here is a link that should help http://appliancehelponline.com/gdryertroublevideo.html
Jun 24, 2010 | Kenmore 73932 Gas Dryer
The dryer runs but only blows cold air. It's a gas dryer. Kenmore 90 series
Have you checked the igniter yet or tried replacing it?
It is generally the first thing to go when this happens.
Benjamin
May 24, 2010 | Kenmore 73952 Gas Dryer
Kenmore 90 series electric dryer blowing cold air only
1st check the breakers
2nd check wiring in back to see connections are secure.
3rd check element. It would be burned in two.
4th check thermal overload switch which is located underneath top of dryer. Easy to remove top. Probably 4-6 screws.
Jan 15, 2009 | Zanussi TC7102W Electric Dryer
Kenmore 90 Series Dryer will not DRY
first check the vent outside to see if it is blowing air out strong, then check for heat.
Dec 24, 2008 | Kenmore 62602 Electric Dryer
Kenmore dryer replaced heting element now it does not blow any air
HI danon this dryer its common to have the blower wear out, it slides on the motor shaft, and what they do is wear out the flat in the blower. that could have caused the element to fail. check the blower thanks the appliance doc. please rate my answer. thanks
Sep 30, 2008 | Kenmore 62602 Electric Dryer
No heat
vpflueger,
I am not sure why.
But I will tell you that at only 5 years old you should repair it.
This is a fine machine!
Try our premium service and they will fix you up!
Sep 22, 2008 | Kenmore 64982 Electric Dryer
Dryers Logo
102 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
