Question about Brother Office Equipment & Supplies
My typewriter doesn't type..won't display letters, but keys work.
I know the ribbon is good, because I replaced it. This is a daisy wheel typewriter: The letters just don't show up on the paper...what's wrong?
  • 215 Answers
Alot of the brother t/w's have 2 cam assemblies under ribbon holder. 1 operates the print hammer and 1 operates the correction ribbon lift. sometimes these will hang or lockup. sometimes turning on and off a few times will take care of it, but sometimes it needs to be worked on by a t/w tech. if you look when you type a character, most likely the print hammer is not firing or it is striking the correction ribbon instead of the black ribbon.
hth,
razors
Posted on Feb 27, 2009
4 Suggested Answers
  • 3594 Answers
SOURCE: HELP..BROTHER DAISY WHEEL TYPING RANDOM LETTERS AND SYMBOLS
Check to see if your pitch setting is in PS if so try 10 or 12.
DickyO
Posted on Feb 12, 2009
squipps
  • 204 Answers
SOURCE: how do you fix the daisy wheel for Mastertype 1
It is usually that the printwheel is in wrong. Make sure the pw does not have any bent "petals" on it making it bind.
After it snaps in and closes it should go to it home position. If not keep trying a couple of more times and it should seat in.
Posted on Oct 08, 2009
  • 3594 Answers
SOURCE: Attempting to change the print ribbon on the
Go to brother.com, click on support. Poke around in there you will find a manual for your T/W.
Dickyo
Posted on Dec 03, 2010
When i press a key a different letter appears
First tun it off and on. If no help, Make sure ribbon is not cuaght up in the daisy wheel. Daisy wheel petals may be bent. Change the Daisy wheel. Possibility you have
setting for language.
Feb 23, 2015 | Nakajima AX-150 Typewriter
My typewriter will not type the correct letters I have replaced the wheel twice any suggestions?
Make sure that ps pitch is not selected. check if ribbon or corr. tape is in printwheel
Sep 26, 2014 | Brother ML100 Daisy Wheel Electronic...
How do I insert the daisy wheel on my Swintec 2416 DM typewriter?
Remove the ribbon, then remove the daisywheel, reinsert daisywheel, replace ribbon and it should work.
Jul 01, 2014 | Swintec Office Equipment & Supplies
WP3400 & AX-12M
  1. Is the daisy wheel locked in the forward position?
    1. Pull the black lever back, away from the platen.
    2. Lift out the daisy wheel and inspect it for damage; replace the daisy wheel if it is damaged.
    3. Re-insert the daisy wheel and push the black lever towards the platen until it locks in place.
  2. Is the ribbon moving?
    1. Lift the ribbon cartridge out of the typewriter
    2. Inspect the ribbon for damage
    3. If the ribbon is silver, it is exhausted and must be replaced
    4. If the hammer has been striking in one place, there will be a clear area near the center of the ribbon.
    5. Turn the colored knob on the left side of the ribbon cartridge counter-clockwise to advance the ribbon a small amount. Replace the ribbon if it will not advance.
    6. Re-insert the ribbon
  3. Turn on the typewriter, insert a piece of paper into the typewriter and type a few letters
    1. Did the hammer move forward?
    2. If the hammer moved, did the ribbon advance with each keystroke?
If the hammer did not move or the ribbon did not advance, the typewriter will require service. If the typewriter still does not make an impression on the paper, your typewriter will require service.
Dec 09, 2013 | Brother Office Equipment & Supplies
Letters don't show on paper no imprint on ribbon. keys sound like they are typing but nothing shows on paper
Chances are that the print head is not locked forward. This happens when the daisy wheel or either of the ribbons are replaced. Just push it forward until it clicks
Oct 25, 2011 | Brother GX-6750 Typewriter
When you type, each character you strike actually types another letter.
first try turn typewriter off, (button on left panel toward the back), then turn it back on, and while hold down the CODE button, press RESET key, the whole print head will move and reset
if that doesn't work, power off again, open the cover, release the lever to the Daisy Wheel, and inspect that Daisy Wheel - mine has a bent forward letter, and another letter was kinda stuck to the side of another letter... I gently fix both letters, put the Daisy Wheel back in, firmly lock it in place with the lever, close the cover... and voila, it works like a charm.
While you have it open you might want to dust (use the cleaning spray can duster)... You wouldn't believe what I found in my typewriter... Good luck!
If that doesn't work, I would replace the Daisy Wheel.
gkt
Jan 12, 2011 | Brother GX-6750 Typewriter
Typewriter
1 - Is the dailsy whell properly installed ? (Has the lever been pressed firmnly ?) is the correct daisy wheel installed?
2 - Have you run out of ribbon ?
3 - Have you pressed the 'spider web' key with + // keys after replacing cassette ribbon, correction tape or daisy wheel?
I have the instruction manual if that helps..
Pleas feel free to advise your email, and I will gladly forward :
Regards TC
Aug 11, 2008 | Brother GX-6750 Typewriter
No Characters Typing
could be the ribbon is not lifting, do you see an image on the ribbon, also may be twisted inside the cartridge the shiny side has to be facing the keyboard.
Jul 09, 2008 | Brother EM-630 Typewriter
Not typing the correct letters
The ML-300 needs to be reset each time the Daisy Wheel is removed or replaced or if the Keyboard Switch changes position. According to Brother, if this is not done the typewriter will print incorrect characters. Try these steps: 1) Open the Top Cover. There is a lever directly behind the Daisy Wheel. Pull the lever back towards you. Remove the Daisy Wheel by pulling it up and out. 2) Verify that it is the Standard Daisy Wheel that came with your machine and not a Symbol or International Daisey Wheel. Write down the Pitch (10, 12, or dual pitch 1012) printed on the wheel. 3) Reinstall the Daisy Wheel (the plastic top ear goes to your right.) Push the lever (step 1) forward. 4) Press the ALT key plus the PITCH key and the number 1 key simultaneously. Verify the Pitch setting is the same as is printed on the Daisy Wheel. 5) Press the CODE key plus the RESET key and the letter Q key simultaneously. This will reset the typewriter mechanism and align (or time, in technical terms) the carriage mechanism. Check if the typewriter prints correctly now. If still incorrect, perform these additional steps. 6) Verify the three position Keyboard Switch (inside the top cover, on the right side, at the bottom) is in the I=Standard position. The other positions are: II=International and III=Symbol. 7) If the Keyboard Switch is in the correct position, slide it to position III and then back to I. (This will clean the switch contacts in case they are dirty and not making good electrical contact. 8) Press the CODE key plus the RESET key and the letter Q key combination again to reset the typewriter mechanism. Check if the typewriter prints correctly now. If still incorrect, the only other things I can think of is that: 1) an incorrect Daisy Wheel is installed that does not work in the ML-300. Brother sell a "B type" Daisy Wheel with two plastic ridges/raised slots below the center of the Daisy Wheel (viewed with the raised top tab on your left.) The B type are incompatible with your machine. 2) the typewriter has failed and needs repair.
Sep 28, 2007 | Brother ML-300 Typewriter
1,943 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
