Question about Microsoft Windows 98 for PC
I have a IBM ThinkPad 2647 I'm booting
IBM ThinkPad 2647- I'm trying to boot but keep getting A:\> Invailid drive specification. Where or what now?
  • 203 Answers
Go into bios and change the order of boot devices.
first one should be cd, then ide, then floppy.
Posted on Feb 27, 2009
Formatting ibmthinkpad 2647
Power on, when you see the IBM logo, press F12 once to load the boot menu options, provided that you already have an Operating System CD / DVD in the drive, which should allow you to format your HDD.
Mar 08, 2013 | IBM ThinkPad T23 2647 Notebook
IBM Thinkpad 2647 will not power on , i plug it in to charge and orange light flashes 5 times then stays solid orange . I can leave it plugged in for days and will not change , it will also not turn on...
This is a tricky problem, you need to troubleshoot this bit by bit - first take the memory out one stick at a time and try to turn it on each time, then try the hard drive. If it boots further with one of these things out then you know thats the problem. If it still doesnt boot after trying these components then you need a repair as it will be an onboard component.
My immediate guess would be the onboard power supply unit, unless your charger is broken and you can test with another charger to rule that out too.
Feb 26, 2011 | IBM ThinkPad T20 2647 Notebook
Evey time I try to boot my ibm thinkpad type 2647 nothing happens and the fan keeps going from high to low any ideas?
Whe you switch on the laptop please go to Bios and check the hard disc is dictacted or not. Other wise when you switch on the computer please press F11 button 4 to 5 times and select the boot option from the hard disc. If it not working need to show service center.
Sep 23, 2010 | IBM ThinkPad T23 2647 Notebook
ThinkPad T20 2647 PC Notebook: The lap top will not boot. It's a thinkpad T20...
Hi, During the boot at the THINKPAD SCREEN press the Thinkvantage key ( Blue button ) it will launch rescue and recovery and allow you to reboot factory. This only works if you did not corrupted/deleted the rescue and recovery hidden partition on the HDD. Otherwise you will need the rescue and recovery CD to proceed. IBM/Lenovo support should be able to provide you the CD. Might be a defective hdd aswell, in this case to make sure you can run a DFT test, www.google.com -> Look up for " Test DFT " ( Drive fitness tool from hitachi, will make an hardware diag if hdd failure - error code 0x00 = everything fine, other code = Issue - You can look up for accurate code explanation on hitachi website ) thanks and have a nice day J-
May 17, 2010 | IBM ThinkPad T20 2647 Notebook
I have a 2647 thinkpad. I am having problems trying to boot windows xp on to it. It keeps telling me that operating systems cant be found????
It can be that the OS is corrupted or the hard drive is bad. Does the ahrd drive show up in the BIOS setup?
Nov 30, 2009 | IBM ThinkPad T23 2647 Notebook
IBM T20,inaccessible boot device
The Innaccessable Boot Device message means one of 2 things:
1: your hard drive has died - not much here, must replace drive.
2: The master boot record has become corrupt. Without any media, this will be hard to fix. You will need to boot to the Windows CD and either run the recovery console or perform a windows repair to fix this issue.
Jun 23, 2009 | IBM ThinkPad T20 2647 Notebook
How to get into safemode with ibm t26 thinkpad
To get into safemode on a windows operating system then you must press F8 at startup. Keep tapping the F8 key and you should get a menu that says Start windows in safe mode and some other options. Choose safe mode and your there.
Sometimes a computer may have a boot menu set to F8 and you will be asked to load from the CD drive or hard driver. If thats the case then select the hard drive and then tap F8 again until the menu at the top appears.
Dec 14, 2008 | IBM ThinkPad T23 2647 Notebook
Stuck at IBM Thinkpad Splash Screen
Sound like a memory chip has failed. Try removing the memory, I believe these have on board, but not sure. If it doesn't have on board, you will need at least one chip in. If the problem is still there, try removing the CD drive, occasionally they can cause a no start. If it's not the memory or the CD drive, then try a bios flash. You will need to create a bootable disc from IBM's support site using a different machine (obviously).
If the bios flash doesn't fix it, them the problem will lie with the motherboard.
Jun 27, 2008 | IBM ThinkPad T20 2647 Notebook
Replaced Hard Drive
you may need to boot from install cd, and then configure that drive with F2 prompt at log in screen. Of course, with IBM, there's always a chance of having some arcane approach, but you might get lucky.
Mar 04, 2008 | IBM ThinkPad T23 2647 Notebook
Microsoft Windows 98 for PC Logo
63 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
