Question about Acer Aspire 3100-1405 Notebook
DVD Drive is Missing?
I have an Acer Aspire 3100 and when I put a CD/DVD in it will not read or anything and when I went to click on the Drive button is was not there. It is like it was never there to begin with. It has done this before in the past. I have no clue what to do...
    President:
  • 2,653 Answers
This works for most.
Manually delete the registry entries loadTOCNode(2, 'whattotry'); Important This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and restore the registry, click the following article number to view the article in the Microsoft Knowledge Base: 322756 (http://support.microsoft.com/kb/322756/ ) How to back up and restore the registry in WindowsNote Before you use this method, uninstall all CD or DVD writing or recording programs. Deleting the corrupted registry entries might cause problems with any other CD or DVD writing or recording programs that are installed on your computer. Uninstalling these programs before you start will help you avoid any problems that removing the registry entries might cause. You can reinstall these programs after the problem is resolved.
This method provides step-by-step instructions for how to use Registry Editor to delete the following corrupted Registry entries:
  • UpperFilters
  • LowerFilters
Step 1: Start Registry Editor loadTOCNode(3, 'whattotry'); Start Registry Editor. Step 2: Delete the UpperFilters registry entry loadTOCNode(3, 'whattotry');
  1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE.
  2. Expand SYSTEM, and then expand CurrentControlSet.
  3. Expand Control, and then expand Class.
  4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}.
  5. In the details pane of Registry Editor, on the right side, click UpperFilters.
    Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only.
    • If you see the UpperFilters registry entry in the details pane of Registry Editor, go to step 6.
    • If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to "Step 3: Delete the LowerFilters registry entry."
  6. On the Edit menu, click Delete.
  7. Click Yes when you receive the following message: Are you sure you want to delete this value?
The UpperFilters registry entry is removed. Step 3: Delete the LowerFilters registry entry loadTOCNode(3, 'whattotry');
  1. In the details pane of Registry Editor, on the right side, click LowerFilters.
    Note You might see a LowerFilters.bak registry entry. You do not have to remove that entry. Click LowerFilters only.
    If you do not see the LowerFilters registry entry, unfortunately this content is unable to help you any more. Go to the "Next Steps" section for information about how you can find more solutions or more help on the Microsoft Web site.
  2. On the Edit menu, click Delete.
  3. Click Yes when you receive the following message: Are you sure you want to delete this value?The LowerFilters registry entry is removed.
  4. Exit Registry Editor.
Step 4: Restart your computer loadTOCNode(3, 'whattotry'); Restart your computer. After you have done this, try to access the CD or DVD drive. If you can access the CD or DVD drive, and if you do not receive an error message, the problem is resolved. You can reinstall your CD or DVD writing or recording software.
If not, let me know.
Best of luck!
Posted on Feb 27, 2009
When i put in a disc the drive light is lit up and you can hear it spin and then nothing. Won't autoplay and doesn't reconized the cd drive as even being attached anymore.How can I fix this or do I need to...
If you open My Computer, and there is no icon for the CD/DVD drive, then your computer has a "hardware" problem. Take it to a qualified technician for trouble-shooting, and possibly for disassembly/replacement of the drive/reassembly.
May 30, 2010 | Acer Aspire 3100 Notebook
Boot Acer 3100 Aspire. Shows NTLDR is missing Press any key to restart. Will just go to the same screen over and over.Will not boot at all. Do not have a boot disk.
Remove any 3.5" diskette from the A: drive.
Remove any CD from the CD/DVD drive.
Reboot.
If you still have the problem, then borrow a Windows XP disk.
Boot from it. Choose "repair", not "install".
If the disk-drive is "detected", then "repair" will attempt to fix any file-system errors.
If *NO* disk-drive is detected, your disk-drive has "died".
Nov 01, 2009 | Acer Aspire 3100-1405 Notebook
DVD/CD-ROM drive missing
Problem with missing dvd-drive with Acer 5101 solved.
Problem was that depending on boot, even bios couldn?t detect dvd-drive. I
opened my laptop and found out that there were one small screw that wasn?t
connected to anywhere. I opened the screw that locks dvd-drive in to 2.5? slot. In the back of the
dvd-drive is L- shaped peace of metal. One of it?s screws were already dropped
and 2 that were left were loose. I tightened those screws, but drive back and
got my laptop working fine.
http://www.vapaakoodarit.fi/~puontis/cd-drive.jpg
Please feel free to post this solution to other forums as
well.
Jul 12, 2009 | Acer Aspire 5100 Notebook
Acer Aspire cd/dvd/rw drive 'missing'
Go to device manager and look for the dvd/cd on the list. Click on the "+" sign and you may have a yellow, red or black symbol. right-click on the device and reinstall the driver. That should get it working again. If not then try the troubleshooting in the device manager, same place you reinstall the driver. Follow the instructions. If none of that works then it needs to be replaced.
Pls rate this solution.
May 07, 2009 | Acer Aspire 5630 Notebook
Acer 5315 elock
Go to device manager and click on your dvd/cd drive. Double click on this and enable the drive.
If driver is missing, go to Acer's website and download your dvd/cd device driver.
Dec 08, 2008 | Acer Aspire 5315 Notebook
Dvd playr
Just the whole DVD/CD Drive isn't there, there is a CD Drive on my laptop but it just does not work, doesn't read anything nor does anything work.
In My Computer, there is no icon for the CD Drive.
Aug 11, 2008 | Acer Aspire 3680 Laptop
ACER ASPIRE 3100...PROBLEM DVD WRITER
Sounds like the driver is missing. Do you have the driver disc, if you do then reinstall it. Have you also reinstalled the program to run cd/dvd ie Nero. You should have all the drivers on a disc that came with laptop. If not, try going to the following site and see if the missing driver is available.
http://support.acer-euro.com/
Failing that, you may get it at one of the driver download sites
Jun 29, 2008 | Acer Aspire 5500 5570-2609 Laptop
Optiarc CD-RW CRX880A
You need to edit your registry.
Click the Start button, click run, type in the run window regedit than click OK
Close any opend Keys. Open HKEY_LOCAL_MACHINE than open SYSTEM next open CURRENTCONTROLSET than open CONTROL than open CLASS & find
{4D36E965-E325-11CE-BFC1-08002BE10318} listed in the right half of the window right click on LOWERFILTERS & left click delete, then right click on UPPERFILTERS & left click delete.
Exit the registry, and reboot the laptop.
Good luck.
Mar 11, 2008 | Microsoft Windows Vista Ultimate Edition
Cd/dvd tray won't open, no response from button to open
Follow this solution below, or use a paperclip inserted into the tray hole and it will open for a temporary measure, or go to your drive in my computer, right click and select eject and see if it will open. Try also uninstaling your dvd in system properties, by right clicking and select delete, then restart pc to see if it's found again, but when the pc boots it should check the drive, you will notice the light on front of dvd light up, if not there is no power or the dvd is dead.
Jan 09, 2007 | Acer Aspire 3000 Notebook
Acer Aspire 3100-1405 Notebook Logo
159 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
