Question about HP OfficeJet d145 InkJet Printer
Not printing My second hand hpofficejet d145 has new colour/black cartridges, cleaned printheads and been turned off & on again, but still not printing, it is very faint. What can I do next??
  • Ami Joy lines Feb 27, 2009
    Thanks, but now saying Bad Printhead! This was the message before I cleaned heads with metho, after, there was no message!! I don't think they need replacing, but it's asking to do that!
  • Ami Joy lines Mar 05, 2009
    I am still having printing troubles, and my computer technician has no answers,
  • 203 Answers
Try the cleaning cycle again and see if it gets and darker.
also try a test print as these utilise all colours and may help clear out any blockages.
Posted on Feb 27, 2009
  • 1 more comment
  • sean sutton
    sean sutton Feb 27, 2009
    HP Officejet D and 7100 Series and HP cp1160 Printers with HP 14 Printheads -
    No Printhead or Bad Printhead Error Messages
    Problem
    The
    printer will not print. The front panel display on the unit shows one
    of the following error messages. These messages are specific to the HP
    Officejet D series, the HP Officejet 7100 series, and the HP cp1160
    series printers.
    • No PrintHead...Will Damage the product...Insert [icon or icons shown in the figure below] printhead now
    • Bad
      PrintHead… Replace [icon or icons shown in the figure below]
      printhead... Press Enter (or Resume for the HP cp1160) to continue
    Figure 1: Printhead icons
    Solution
    Follow the steps below to solve the problem.
    Step 1 - Determine the problem printheads
    The
    No Printhead
    and
    Bad Printhead
    error messages indicate printheads by displaying an icon. These icons
    mark the printheads and slots in the printhead holder. See the
    illustration below.
    Figure 2: Printheads and printhead holder icons
    The error message can indicate only one printhead at a time. Follow the steps below to find all the failed printheads:
    1. Write down the icon indicated in the error message.
    2. Press the
      button.
    3. If the display indicates that another printhead is faulty, write the new icon down and then press
      again. Repeat these steps until the display shows the date and time rather than an error message.
    Step 2 - Remove the Problem Printheads
    CAUTION:
    Do not touch the printhead tower. Do not remove the printhead handle. Keep printheads out of the reach of children.
    Figure 3: HP 14 printhead
    1 - Handle
    2 - Tower
    1. Make sure the unit is plugged in and the power is turned on.
    2. Open the print carriage access door by lifting the handle until the door locks in place. The print carriage moves to the center.
    3. Wait two or three seconds, then unplug the power cord.
    4. Open the printhead latch. See the illustration below.
      Figure 4: Open the printhead latch
    5. Remove each problem printhead by lifting the printhead handle and pulling up. See the illustration below.
      Figure 5: Remove the printhead
  • sean sutton
    Step 3 - Inspect the problem printheads
    A common cause of failure for new printheads is tape on the contacts and nozzles.
    • The
      illustration below shows tape on the nozzles. In this example, the
      person who installed the cartridge removed the tab from the tape, but
      did not peel the tape itself off.
      Figure 6: Tape on contacts
    • The illustration below shows the tape being removed correctly.
      If there is any tape on the nozzles, remove it.
      Figure 7: Remove tape
    Step 4 - Gather cleaning materials
    Gather the following materials:
    • Five or six cotton swabs, or any clean, soft, lint-free material that will not come apart or leave fibers behind when wet.
    • Enough
      distilled, filtered, or bottled water to moisten the swabs. Avoid using
      tap water, which could contain damaging contaminants.
    • Sheets of paper or paper towels to rest the printheads on during cleaning.
    Step 5 - Clean the printhead contacts
    NOTE:
    Clean the printheads only as a last resort before replacing them.
    1. Wipe the printhead contacts with a dry cotton swab (or another clean, soft, lint-free material).
    2. If
      some residue remains, slightly moisten the swab with distilled,
      filtered, or bottled water and continue wiping until the contacts are
      clean. See the illustrations below.
    3. After cleaning, place the printheads on a paper towel.
    Figure 8: Dirty contacts
    Figure 9: Clean contacts
    Step 6 - Clean the contacts in the problem printhead holder
    Clean
    the contact points in the problem printhead holder inside the printer
    with a dampened cotton swab. See the illustration below.
    Figure 10: Clean the printhead holder contacts
  • sean sutton
    Clean
    Step 7 - Reset the internal error state
    NOTE:
    This step must be performed before the printheads are re-installed.
    1. Close the printhead chute.
    2. Close the access door.
    3. Plug the power cord back in.
    4. Turn on the power. The front panel should read
      No Printhead. Will damage Product. Insert [color name] [icon] printhead now
      NOTE:
      The carriage may make a grinding noise when you turn the power on. This noise is normal.
    5. Open the print carriage access door by lifting the handle until the door locks in place. The print carriage moves to the center.
    6. Wait two or three seconds, then unplug the power cord.
    7. Open the printhead latch.
    Before re-inserting the printheads, make sure all the electrical contacts have had at least five minutes to dry.
    Step 8 - Insert the printheads
    1. Place
      each printhead in its slot in the printhead carriage. The colored shape
      on the top of the printhead should match the colored shape on the
      proper slot on the printhead carriage.
    2. Press
      down firmly and evenly on both the front and back of the printhead, as
      shown in the illustration below. Proper seating is essential to making
      good electrical contact.
    Figure 11: Seat the printhead
    Step 9 - Close and check the printer
    1. Close the printhead carriage latch and make sure the loops catch the hooks. See the illustration below.
      Figure 12: Loops catch hooks
    2. Snap the latch into place.
    3. Plug in the power cord.
    4. Close the print carriage access door.
    5. Turn on the power.
    6. If the error clears, a message to align the printheads may appear on the HP Officejet D and HP Officejet 7100. Press
      Enter
      to align.
    7. If the error persists, replace the indicated printheads.
In my pixma ip2772,when I print photo then black colors are printing properly but when I print any types of documents then my black color is not working.It's not showing dark.What can I do?
This printer has a separate cartridge for black and colour. When you print pictures, the printer uses all three colours mixed together to make black and does not use the black cartridge. Your black cartridge may be empty or the printhead may just be dried out. Try a head-clean from the maintenance menu and then print a nozzle test. If still no result then try replacing the black cartridge with a new one which has a new printhead as part of the cartridge.
Apr 14, 2015 | Office Equipment & Supplies
Epson xp 305 help
It's quite likely that at some point in time you will have attempted to print in black only to receive an error message that you cannot print until a colour cartridge is replaced.
"If ink is not in the tubes from the head to the cartridge, air will be sucked in and therefore cause damage to the print head. This is because the nozzles are in the print head and not in the cartridge. "
What Epson are basically saying is... if this safeguard was not in place, and you sent a print request for black when a colour cartridge was empty, there is a risk of air being pulled into the printhead. This air will ruin the vacuum effect needed for the printhead to pull ink in, meaning your printhead would be at risk of never printing again.
Additionally, if any air is allowed go get into the aformentioned tubes from the head to the cartridge, any remaining ink will coagulate. Just in case you're not a scientist - coagulation in a tube/cartridge is bad, and will lead to you not being able to print again with that cartridge, or to a blocked nozzle/printhead which will require a significant amount of cleaning cycles to budge.
Aug 08, 2014 | Epson Expression XP-305 Inkjet...
I replaced all my printheads. Also Both the black
call the manufacture or tech support. Maybe there is a printhead reset on the printer??
Sep 26, 2009 | HP OfficeJet d145 InkJet Printer
Printing with my second hand hp officejet d145
You can clean it with maybe a little alcohol then go thru the motions of cleaning from the printer controls
Feb 26, 2009 | HP OfficeJet D145xi All-In-One InkJet...
Blank Ink not pumping to print head
Turn off the device after removing the printhead After removing the printhead, turn off the device, wait about 20 seconds, and turn it on again without the printhead installed. After it has restarted, reinsert the printhead.
it will go through this long routine of perhaps 20 min or so. after its compleate it should print great.
Nov 22, 2008 | HP Officejet Pro L7590 All-in-One InkJet...
HP Officejet d145 print head problem
Did you replace the PRINTHEAD, or did you replace the INK CARTRIDGE? They are not the same on the D145.
Good chance that you may have replaced the ink cartridge, not the magenta PRINTHEAD which sits under the ink cartridge.
PS - in my experience, non-HP ink cartridges clog up HP printers with separate printhead mechanisms... any possibility here?
Jul 26, 2008 | HP OfficeJet d145 InkJet Printer
Printhead problem
Any chance the ink cartridges, which are separate from the printheads, are empty or dried out? If the printheads were exposed to air for more than a few hours without an ink cartridge on top of them, they may have dried out. HPs are especially bad for this, and BTW, never use a non-HP cartridge in a D145 - the inks aren't compatible and clog up everything (at least it happened to me..) You could also replace all the printheads and cartridges, but that'll cost you more than a new printer.
Jun 17, 2008 | HP OfficeJet d145 InkJet Printer
HP OfficeJet d145 InkJet Printer Logo
223 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
