Question about Dell 946 All-In-One InkJet Printer
It prints vertical lines where the text is.
Our 2 year old Dell 946 printer prints vertical lines over the text and pictures when you print a page. We put in new print cartridges and we have reinstalled the printer and we still have the problem. HELP!!!!
Check your drum unit. The toner cartridge mounts into the drum which can be permanently charged causing a constant streak to occur.
Solution:
Remove the toner and drum unit. Clean them off with a non-fuzzy non-rough cloth or paper towel. Pay particular attention to where the streaks are in relation to the toner cartridge and drum. If you clean it off and you still get streaks check whether they transfer from the toner or just from the drum.
There may be a way to discharge the drum, otherwise you need a new drum.
Posted on Feb 27, 2009
Why my Dell 946 printer wont print
Have you installed the printer driver? If you did and it won't print....uninstall it and reinstall the driver.
Jan 04, 2017 | Dell 946 All-In-One InkJet Printer
My daughter was messing with the printer. When I print anything now, the printer prints out a thick black line covering everything where the text should be. Is there a way to re-set the printer to get it...
Disconnect the printer from the computer momentarily. Allow to lay idle for a while, then reconnect to power on the computer. A new allignment instructions will be requested from computer on attempt to print with new settings.
Jan 29, 2011 | Dell 946 All-In-One InkJet Printer
My Dell 946 All in one printer prints all pages at an angle.. how do I fix this
go to your printing options... maybe, all the things you will print are set to a specific angle.
May 02, 2010 | Dell 946 All-In-One InkJet Printer
Kodak all in one printer
There's a problem on the black nozzle since you can only print text on double strike, try deep cleaning the printhead 3x
Oct 01, 2009 | Dell 946 All-In-One InkJet Printer
Far right side of the text or picture missing on Dell 3100cn.
Refer to the following table
Cause
Solution
How common*
Contamination in the laser path
1. Clean the laser path. (Remove the laser/scanner assembly and clean the lens.) 2. Replace the laser/scanner assembly
8
Defective fuser.
Replace the fuser assembly
Lack of toner or faulty toner cartridge.
Redistribute the toner in the toner cartridge. If the problem continues, replace the toner cartridge.
7
Sep 30, 2009 | Dell 3100cn Laser Printer
Dell 946 Printer
check on the series of the ink cartridge you got
946 all in one's has a lot of series for the cartridge
Sep 19, 2009 | Dell A940 All-In-One InkJet Printer
Vertical lines printed on right side of every page
Would be helpful to know the brand and model of the printer. Sometimes this is caused by not returning the slide used to clean the primary corona wire to its original position (usually to the extreme left side of the toner cartridge) after cleaning the corona wire. If you haven't cleaned the corona wire, you should follow instructions and do that first.
Jul 22, 2009 | Dell 3000cn Color Laser Printer
I have a Dell 946 printer that is a couple of years old. It has started printing crooked on the pages. I have done the alighnment and that did not fix the problem. Can you help?
probably no much you can do the correct the problem because The problems that users encounter while using a Dell printer
varies with the model. However the common problems all Dell printer models suffer from are their slow speed and faulty paper feed mechanism. Quality of prints varies from one model to another, but most of the models do not produce prints having very fine qualities. A Dell printer is particularly notorious for its poor and faulty feed mechanism. They tend to cripple the papers or take in large number of papers at a time and print parts of documents on each page. They keep on generating messages indicating lack of paper, no matter the paper is being supplied or not. Such a problem makes the printer absolutely useless
Nov 20, 2008 | Dell 946 All-In-One InkJet Printer
Dell 946 printer
You need to set the size of your page on the printer preferences.
If you need more help you can see the manual of your printer here: http://support.dell.com/support/edocs/systems/prn946/en/index.htm
Sep 07, 2008 | Dell 946 All-In-One InkJet Printer
Dell 946 printing problems
are you using for an application to print the pictures?
http://support.dell.com/support/topics/global.aspx/support/product_support/en/product_support_central?c=us&l=en&s=gen
Dec 13, 2007 | Dell 946 All-In-One InkJet Printer
Dell 946 All-In-One InkJet Printer Logo
160 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
